    MMM-Tube-Status (London Underground)
    25 Posts 5 Posters 24.8k Views 6 Watching
      djbenny07
      thanks very much. not installed a new module before so we’ll see how it goes!
      Is there any instructions on module installation? to put in the config.js as to the location of the module on the screen?
      N 1 Reply Last reply
      • N
        nigel-daniels @djbenny07
        @djbenny07 check out the read me file on Github, it details the options and provides an example.
        D 1 Reply Last reply
        • N
          nigel-daniels @yawns
          @yawns I was thinking of making the font the line colours but then the Northern line would have never shown up :( It turns out TfL provide detailed UI and colour guides so I was able to get the correct colours for each line.
            djbenny07 @nigel-daniels
            @nigel-daniels I have done as the config suggests however the display says it needs a valid config file.
            yawnsY 1 Reply Last reply
            • yawnsY
              yawns Moderator @djbenny07
              @djbenny07
              Then please show your entire config file. If the config.js file is there but the mirror says it is missing then there is something missing, most of the time , or }
              Please put ` (back ticks) before and after your config file content when posting, then it will be parsed and shown correctly. Also please remove appids/app tokens, they should be kept private.
                djbenny07
                var config = {
                port: 8080,
                    language: 'en',
                    timeFormat: 24,
                    units: 'metric',
                                    module: 'alert',
                                    module: 'clock',
                                    position: 'top_left'
                                    module: 'calendar',
                                    header: 'Public Holidays',
                                    position: 'top_left',
                                                            symbol: 'calendar-check-o ',
                                                            url: 'webcal://www.calendarlabs.com/templates/ical/UK-Holidays.ics'
                                    module: 'compliments',
                                    position: 'lower_third'
                                    module: 'currentweather',
                                    position: 'top_right',
                                            locationID: '245613',  //ID from http://www.openweathermap.org
                                            appid: 'ID Number taken out'
                                    module: 'weatherforecast',
                                    header: 'Weather Forecast',
                  djbenny07 @djbenny07
                  @djbenny07 i took it out of there as it didnt work. could it be corrected? is it possible to get it on the right hand upper corner underneath the clock?
                  bheplerB 1 Reply Last reply
                  • bheplerB
                    bhepler Module Developer @djbenny07
                    @djbenny07 Is that the entire config file? I ask because it’s not closed properly.
                    Please put the module configuration that you’re trying to get to work back in and post the entire file for us so we can check it all. We’ll get you running.
                      djbenny07
                      • N
                        @djbenny07 I noticed that at the end of the file the last two lines should change and it should end something like:
                        If you then want to add the tube status module something like this should work:
                        module: 'MMM-Tube-Status',
                        header: 'Tube Status'
                        I hope that helps.
                        • N
                          nigel-daniels
                          BTW I have just updated the code so that if the optional show_all=false config is used and all of the lines are offering a good service there is a line displayed to indicate this rather than the module just disappearing.
                            djbenny07
                            OK I have found that i didn’t copy all the text. the below does not work
                            var config = {
                            port: 8080,
                                language: 'en',
                                timeFormat: 24,
                                units: 'metric',
                                                module: 'alert',
                                                module: 'clock',
                                                module: 'calendar',
                                                        locationID: '264443',  //ID from http://www.openweathermap.org
                                                        appid: 'number'
                                            appid: 'Number'
                                        header: 'Tube'
                                                module: 'newsfeed',
                                                position: 'bottom_bar',
                                                        feeds: [
        title: "BBC Top Stories",
        url: "http://feeds.bbci.co.uk/news/rss.xml"
                                                        showSourceTitle: true,
                                                        showPublishDate: true
                            if (typeof module !== ‘undefined’) {module.exports = config;}
                            strawberry 3.141S N 2 Replies Last reply
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @djbenny07
                              @djbenny07 you missed 3 commas in there
                                  header: 'Tube'
                              • N
                                @djbenny07 ok there were a couple issues here that my linter picked up:
                                1. the tube module must look like this:
                                header: 'Tube'
                                Note the terminating commas on each line bar the last one in the braces.
                                1. The final line seems to use ticks to quote undefined not single quotes so it should be:
                                It can happen that copying between editors, email clients, browsers, etc introduces this sort of error and it’s a real pain to spot!
                                I hope this fixes it up for you.
                                  djbenny07
                                  can the position be the same as another module though? i still get the message to saying ‘Please create config file’
                                  as my clock is in top_left
                                  EDIT: Just noticed that i missed the ’ from the module name. added that in and still issue
                                  • yawnsY
                                    @djbenny07 you are still missing the closing , at the end of the tube module lines, as several users mentioned above
                                      djbenny07 @yawns
                                      @yawns yes my bad. i noticed this and corrected it. still same message
                                      • yawnsY
                                        @djbenny07 are you kidding? Look at the three lines you got there for the tube module. All three lines MUST end with a comma
                                          djbenny07 @yawns
                                          @yawns haha, im being really dumb i know. i have finally seen it, long day. thats what im going to blame it on.
                                          its working now!
                                          • yawnsY
                                            yawns Moderator
                                            Sometimes a knock at the back of ones head is worth a try.
                                            Good to see it’s finally working :-)
