    Gosund SP111
    15 Posts 2 Posters 2.5k Views 2 Watching
    • L Offline
      lordhelix
      i´m new in this community. i search a module for my Gosund SP111 without flashing Tasmota.
      This one https://forum.magicmirror.builders/topic/13030/mmm-tasmota-beta?_=1591963282471 from @lavolp3 is for Tasmota only.
      Everybody can do it for the original firmware?
      best regards
      • lavolp3L Offline
        lavolp3 Module Developer @lordhelix
        @lordhelix Go flash it with Tasmota, use mine and have fun!
        Bummer that you can’t use it.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • L Offline
          lordhelix
          Hello @lavolp3 ,
          i have flashed 5 pieces with tasmota. My MQTT broker also runs on the Raspian Pi. I have access to it with MQTT fx. But I don’t get any values. I tried two possible ports: 1883 and 8033. Can you help me a little, please.
              module: "MMM-Tasmota",
                  host: 'http://192.168.178.94:1883',  // also i try http://192.168.178.94:8033
                  updateInterval: 60 * 1000,
                  devices: [
                        topic: 'Testdose', name: 'dose', showPowerStats: true,
                  chartxAxisFormat: "dd HH:mm",
          other question: What time means the updateInterval 60*1000? seconds, minutes or milliseconds?
          lavolp3L 2 Replies Last reply Reply Quote 0
          • lavolp3L Offline
            @lordhelix what models have you flashed?
            If the broker runs on the pi, i guess you should use http://localhost:1883 as host.
            Also try to set debug: true in your config, start the mirror with npm start dev and have a look at the console messages.
            • lavolp3L Offline
              @lordhelix updateinterval is the interval for an update of the module DOM in ms, so 60 seconds. Can not be the source of error.
              • L Offline
                lordhelix
                Gosund SP 111 and SP112
                i tried with localhost first, but nothing happens. I will try out with your tips.
                • L Offline
                  lordhelix
                  @lavolp3 said in Gosund SP111:
                  npm start dev
                  pi@raspberrypi:~/MagicMirror $ npm start dev
                  > magicmirror@2.11.0 start /home/pi/MagicMirror
                  > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
                  [2020-06-21 00:39:48.599] [LOG]    Starting MagicMirror: v2.11.0
                  [2020-06-21 00:39:48.613] [LOG]    Loading config ...
                  [2020-06-21 00:39:48.623] [LOG]    Loading module helpers ...
                  [2020-06-21 00:39:48.663] [LOG]    Initializing new module helper ...
                  [2020-06-21 00:39:48.665] [LOG]    Module helper loaded: MMM-Admin-Interface
                  [2020-06-21 00:39:48.668] [LOG]    No helper found for module: alert.
                  [2020-06-21 00:39:48.739] [LOG]    Initializing new module helper ...
                  [2020-06-21 00:39:48.740] [LOG]    Module helper loaded: updatenotification
                  [2020-06-21 00:39:48.741] [LOG]    No helper found for module: clock.
                  [2020-06-21 00:39:49.470] [LOG]    Initializing new module helper ...
                  [2020-06-21 00:39:49.472] [LOG]    Module helper loaded: calendar
                  [2020-06-21 00:39:49.474] [LOG]    No helper found for module: currentweather.
                  [2020-06-21 00:39:49.476] [LOG]    No helper found for module: weatherforecast.
                  [2020-06-21 00:39:49.477] [LOG]    No helper found for module: MMM-WiFiPassword.
                  [2020-06-21 00:39:49.481] [LOG]    Initializing new module helper ...
                  [2020-06-21 00:39:49.482] [LOG]    Module helper loaded: MMM-BurnIn
                  [2020-06-21 00:39:49.486] [LOG]    Initializing new module helper ...
                  [2020-06-21 00:39:49.487] [LOG]    Module helper loaded: MMM-COVID19
                  [2020-06-21 00:39:49.749] [LOG]    Initializing new module helper ...
                  [2020-06-21 00:39:49.750] [LOG]    Module helper loaded: MMM-Tasmota
                  [2020-06-21 00:39:49.751] [LOG]    No helper found for module: MMM-MQTT.
                  [2020-06-21 00:39:49.752] [LOG]    All module helpers loaded.
                  [2020-06-21 00:39:49.955] [LOG]    Starting server on port 8080 ...
                  [2020-06-21 00:39:49.985] [INFO]   You're using a full whitelist configuration to allow for all IPs
                  [2020-06-21 00:39:50.000] [LOG]    Server started ...
                  [2020-06-21 00:39:50.012] [LOG]    Connecting socket for: MMM-Admin-Interface
                  [2020-06-21 00:39:50.016] [LOG]    Starting node helper for: MMM-Admin-Interface
                  [2020-06-21 00:39:50.147] [LOG]    Connecting socket for: updatenotification
                  [2020-06-21 00:39:50.149] [LOG]    Connecting socket for: calendar
                  [2020-06-21 00:39:50.151] [LOG]    Starting node helper for: calendar
                  [2020-06-21 00:39:50.153] [LOG]    Connecting socket for: MMM-BurnIn
                  [2020-06-21 00:39:50.155] [LOG]    Connecting socket for: MMM-COVID19
                  [2020-06-21 00:39:50.156] [LOG]    Starting node helper for: MMM-COVID19
                  [2020-06-21 00:39:50.158] [LOG]    Connecting socket for: MMM-Tasmota
                  [2020-06-21 00:39:50.166] [LOG]    Sockets connected & modules started ...
                  [2020-06-21 00:39:50.299] [LOG]    Whoops! There was an uncaught exception...
                  [2020-06-21 00:39:50.300] [ERROR]  Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                      at Server.setupListenHandle [as _listen2] (net.js:1226:14)
                      at listenInCluster (net.js:1274:12)
                      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
                    code: 'EADDRINUSE',
                    errno: 'EADDRINUSE',
                    syscall: 'listen',
                    address: '127.0.0.1',
                    port: 8080
                  [2020-06-21 00:39:50.314] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2020-06-21 00:39:50.316] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [2020-06-21 00:39:50.323] [LOG]    Launching application.
                  Sorry, i cant read this information. There is an issus, but i cant located them.
                  • lavolp3L Offline
                    @lordhelix you have the mirror running via pm2 already.
                    You need to do
                    pm2 stop all
                    npm start dev
                    • L Offline
                      lordhelix
                      @lavolp3 Thank you. It looks like the topic isn’t subscribed.
                      My MQTT-DATA
                      09:31:09 MQT: tele/Testdose/STATE = {"Time":"2020-06-21T09:31:09","Uptime":"0T10:37:28","UptimeSec":38248,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":2,"SSId":"XXX2,4GHz","BSSId":"44:4E:6D:94:88:30","Channel":1,"RSSI":94,"Signal":-53,"LinkCount":1,"Downtime":"0T00:00:03"}}
                      09:31:09 MQT: tele/Testdose/SENSOR = {"Time":"2020-06-21T09:31:09","ENERGY":{"TotalStartTime":"2020-06-20T19:39:40","Total":0.195,"Yesterday":0.195,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
                      09:31:11 MQT: stat/Testdose/RESULT = {"POWER":"ON"}
                      09:31:11 MQT: stat/Testdose/POWER = ON
                      09:31:16 MQT: stat/Testdose/RESULT = {"POWER":"OFF"}
                      09:31:16 MQT: stat/Testdose/POWER = OFF
                      09:36:09 MQT: tele/Testdose/STATE = {"Time":"2020-06-21T09:36:09","Uptime":"0T10:42:28","UptimeSec":38548,"Heap":27,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":3,"POWER":"OFF","Wifi":{"AP":2,"SSId":"XXX2,4GHz","BSSId":"44:4E:6D:94:88:30","Channel":1,"RSSI":96,"Signal":-52,"LinkCount":1,"Downtime":"0T00:00:03"}}
                      09:36:09 MQT: tele/Testdose/SENSOR = {"Time":"2020-06-21T09:36:09","ENERGY":{"TotalStartTime":"2020-06-20T19:39:40","Total":0.195,"Yesterday":0.195,"Today":0.000,"Period":0,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}
                      pi@raspberrypi:~ $ pm2 stop all
                      [PM2] Applying action stopProcessId on app [all](ids: 0)
                      [PM2] [MagicMirror](0) ✓
                      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                      │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                      pi@raspberrypi:~ $ cd MagicMirror
                      [2020-06-21 10:29:22.516] [LOG]    Starting MagicMirror: v2.11.0
                      [2020-06-21 10:29:22.528] [LOG]    Loading config ...
                      [2020-06-21 10:29:22.537] [LOG]    Loading module helpers ...
                      [2020-06-21 10:29:22.572] [LOG]    Initializing new module helper ...
                      [2020-06-21 10:29:22.574] [LOG]    Module helper loaded: MMM-Admin-Interface
                      [2020-06-21 10:29:22.577] [LOG]    No helper found for module: alert.
                      [2020-06-21 10:29:22.654] [LOG]    Initializing new module helper ...
                      [2020-06-21 10:29:22.654] [LOG]    Module helper loaded: updatenotification
                      [2020-06-21 10:29:22.656] [LOG]    No helper found for module: clock.
                      [2020-06-21 10:29:23.293] [LOG]    Initializing new module helper ...
                      [2020-06-21 10:29:23.294] [LOG]    Module helper loaded: calendar
                      [2020-06-21 10:29:23.295] [LOG]    No helper found for module: currentweather.
                      [2020-06-21 10:29:23.296] [LOG]    No helper found for module: weatherforecast.
                      [2020-06-21 10:29:23.297] [LOG]    No helper found for module: MMM-WiFiPassword.
                      [2020-06-21 10:29:23.301] [LOG]    Initializing new module helper ...
                      [2020-06-21 10:29:23.302] [LOG]    Module helper loaded: MMM-BurnIn
                      [2020-06-21 10:29:23.305] [LOG]    Initializing new module helper ...
                      [2020-06-21 10:29:23.306] [LOG]    Module helper loaded: MMM-COVID19
                      [2020-06-21 10:29:23.541] [LOG]    Initializing new module helper ...
                      [2020-06-21 10:29:23.543] [LOG]    Module helper loaded: MMM-Tasmota
                      [2020-06-21 10:29:23.544] [LOG]    All module helpers loaded.
                      [2020-06-21 10:29:23.723] [LOG]    Starting server on port 8080 ...
                      [2020-06-21 10:29:23.739] [INFO]   You're using a full whitelist configuration t        o allow for all IPs
                      [2020-06-21 10:29:23.752] [LOG]    Server started ...
                      [2020-06-21 10:29:23.754] [LOG]    Connecting socket for: MMM-Admin-Interface
                      [2020-06-21 10:29:23.756] [LOG]    Starting node helper for: MMM-Admin-Interface
                      [2020-06-21 10:29:23.874] [LOG]    Connecting socket for: updatenotification
                      [2020-06-21 10:29:23.876] [LOG]    Connecting socket for: calendar
                      [2020-06-21 10:29:23.877] [LOG]    Starting node helper for: calendar
                      [2020-06-21 10:29:23.878] [LOG]    Connecting socket for: MMM-BurnIn
                      [2020-06-21 10:29:23.879] [LOG]    Connecting socket for: MMM-COVID19
                      [2020-06-21 10:29:23.881] [LOG]    Starting node helper for: MMM-COVID19
                      [2020-06-21 10:29:23.882] [LOG]    Connecting socket for: MMM-Tasmota
                      [2020-06-21 10:29:23.888] [LOG]    Sockets connected & modules started ...
                      [2020-06-21 10:29:24.008] [LOG]    Launching application.
                      [2020-06-21 10:29:29.805] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXXXX/basic.ics - Interval: 300000
                      [2020-06-21 10:29:31.246] [LOG]    MMM-Tasmota: "Connected to host: http://localhost:1883"
                      [2020-06-21 10:29:31.248] [LOG]    MMM-Tasmota: "Subscribing to topic: stat/Testdose/#"
                      [2020-06-21 10:29:31.296] [LOG]    MMM-Tasmota: "Subscribed to topic: stat/Testdose/#"
                      [2020-06-21 10:31:12.139] [LOG]    MMM-Tasmota: "Received message from: stat/Testdose/RESULT"
                      [2020-06-21 10:31:12.145] [LOG]    MMM-Tasmota: "Received message from: stat/Testdose/POWER"
                      • lavolp3L Offline
                        @lordhelix Can you please do a git pull and do the whole thing again (npm start dev)?
                        I have increased debugging output so we can see the data that has been transferred to the module.
                        Thank you!
                        • L Offline
                          lordhelix
                          Hello @lavolp3 ,
                          i try the git pull…
                          pi@raspberrypi:~ $ cd MagicMirror/modules/MMM-Tasmota
                          pi@raspberrypi:~/MagicMirror/modules/MMM-Tasmota $ git pull
                          error: Objektdatei .git/objects/e3/ac23aabf6431dd82b8c207f734f8c046831f05 ist leer.
                          fatal: Loses Objekt e3ac23aabf6431dd82b8c207f734f8c046831f05 (gespeichert in .git/objects/e3/ac23aabf6431dd82b8c207f734f8c046831f05) ist beschädigt.
                          fatal: Die Gegenseite hat unerwartet abgebrochen.
                          I change the node-helper.js manually. Error. i delete the module and clone new.
                          [2020-06-22 19:22:16.259] [LOG]    Starting MagicMirror: v2.11.0
                          [2020-06-22 19:22:16.275] [LOG]    Loading config ...
                          [2020-06-22 19:22:16.284] [LOG]    Loading module helpers ...
                          [2020-06-22 19:22:16.325] [LOG]    Initializing new module helper ...
                          [2020-06-22 19:22:16.326] [LOG]    Module helper loaded: MMM-Admin-Interface
                          [2020-06-22 19:22:16.329] [LOG]    No helper found for module: alert.
                          [2020-06-22 19:22:16.399] [LOG]    Initializing new module helper ...
                          [2020-06-22 19:22:16.400] [LOG]    Module helper loaded: updatenotification
                          [2020-06-22 19:22:16.401] [LOG]    No helper found for module: clock.
                          [2020-06-22 19:22:17.118] [LOG]    Initializing new module helper ...
                          [2020-06-22 19:22:17.119] [LOG]    Module helper loaded: calendar
                          [2020-06-22 19:22:17.120] [LOG]    No helper found for module: currentweather.
                          [2020-06-22 19:22:17.122] [LOG]    No helper found for module: weatherforecast.
                          [2020-06-22 19:22:17.123] [LOG]    No helper found for module: MMM-WiFiPassword.
                          [2020-06-22 19:22:17.126] [LOG]    Initializing new module helper ...
                          [2020-06-22 19:22:17.127] [LOG]    Module helper loaded: MMM-BurnIn
                          [2020-06-22 19:22:17.131] [LOG]    Initializing new module helper ...
                          [2020-06-22 19:22:17.132] [LOG]    Module helper loaded: MMM-COVID19
                          [2020-06-22 19:22:17.406] [LOG]    Initializing new module helper ...
                          [2020-06-22 19:22:17.407] [LOG]    Module helper loaded: MMM-Tasmota
                          [2020-06-22 19:22:17.408] [LOG]    All module helpers loaded.
                          [2020-06-22 19:22:17.611] [LOG]    Starting server on port 8080 ...
                          [2020-06-22 19:22:17.629] [INFO]   You're using a full whitelist configuration to allow for all IPs
                          [2020-06-22 19:22:17.642] [LOG]    Server started ...
                          [2020-06-22 19:22:17.645] [LOG]    Connecting socket for: MMM-Admin-Interface
                          [2020-06-22 19:22:17.647] [LOG]    Starting node helper for: MMM-Admin-Interface
                          [2020-06-22 19:22:17.780] [LOG]    Connecting socket for: updatenotification
                          [2020-06-22 19:22:17.781] [LOG]    Connecting socket for: calendar
                          [2020-06-22 19:22:17.783] [LOG]    Starting node helper for: calendar
                          [2020-06-22 19:22:17.784] [LOG]    Connecting socket for: MMM-BurnIn
                          [2020-06-22 19:22:17.785] [LOG]    Connecting socket for: MMM-COVID19
                          [2020-06-22 19:22:17.786] [LOG]    Starting node helper for: MMM-COVID19
                          [2020-06-22 19:22:17.788] [LOG]    Connecting socket for: MMM-Tasmota
                          [2020-06-22 19:22:17.795] [LOG]    Sockets connected & modules started ...
                          [2020-06-22 19:22:17.933] [LOG]    Launching application.
                          [2020-06-22 19:22:24.276] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXXXXX/basic.ics - Interval: 300000
                          [2020-06-22 19:22:25.493] [LOG]    MMM-Tasmota: "Connected to host: http://localhost:1883"
                          [2020-06-22 19:22:25.495] [LOG]    MMM-Tasmota: "Subscribing to topic: stat/Testdose/#"
                          [2020-06-22 19:22:25.545] [LOG]    MMM-Tasmota: "Subscribed to topic: stat/Testdose/#"
                          [2020-06-22 19:25:12.232] [LOG]    MMM-Tasmota: "Received message from stat/Testdose/RESULT: {\"POWER\":\"ON\"}"
                          [2020-06-22 19:25:12.342] [LOG]    MMM-Tasmota: "Received message from stat/Testdose/POWER: ON"
                          • lavolp3L Offline
                            @lordhelix what is your mqtt configuration in the devices? Especially the telemetry interval? It seems you see a message that power state has changed but no state and power data that gets distributed in intervals. Have you waited long enough?
                            • L Offline
                              lordhelix
                              Hello @lavolp3 ,
                              i wait 25 minutes yesterday.
                              interval: 300 // 5 minutes, i don´t change it, this is default.
                              I change the Period to 10 seconds, but the same problem.
                              • lavolp3L Offline
                                @lordhelix we should track this on github to not spam here, can you please open an issue?
                                I’m currently out of ideas, but will follow up on github. I need your input to see that my module works for others :-)
                                • lavolp3L Offline
                                  @lordhelix I have again increased debugging output.
                                  Please update the module again and report back on github.
                                  Thanks!
