    MMM-awesome-alexa
    241 Posts 43 Posters 452.9k Views 47 Watching
    • U
      uok825 @sdetweil
      mmstart
      #!/bin/bash
      node serveronly &
      sleep 30
      xinit /home/pi/chromium_start.sh
      chromium_start
      #!/bin/sh
      xset -dpms # disable DPMS (Energy Star) features.
      xset s off # disable screen saver
      xset s noblank # don’t blank the video device
      matchbox-window-manager &
      #midori -e Fullscreen -a http://localhost:8080
      chromium-browser http://localhost:8080/ --window-size=1920,1080 --start-fullscreen --kiosk --incognito --noerrdialogs --disable-translate --no-first-run --fast --fast-start --disable-infobars --disable-features=TranslateUI --disk-cache-dir=/dev/null
        sdetweil @uok825
        @uok825 such a shame you rebuilt all this yourself… if u had used my install script it would have set it all up for you…
        just use raspian buster full and voila…
        U 1 Reply Last reply
        • U
          uok825 @sdetweil
          @sdetweil Sorry i saw this first http://emmanuelcontreras.com/how-to/how-to-create-a-magic-mirror-2-with-pi-zero-w/
            sdetweil @uok825
            @uok825 yeh, old stuff…
            • U
              uok825 @sdetweil
              @sdetweil Can you share link your script i flash another sd card raspian and try yourse thx for the help
                sdetweil @uok825
                @uok825 all my scripts are here
                just copy/paste the command for install
                use raspian buster
                https://www.raspberrypi.org/downloads/raspberry-pi-os/
                i test on my pi0w all the time
                • U
                  uok825 @sdetweil
                  @sdetweil okey thx the raspian is downloading
                    sdetweil @uok825
                    @uok825 not lite, right?
                    • U
                      uok825 @sdetweil
                      @sdetweil not lite but “Raspberry Pi OS (32-bit) with desktop” is it problem?
                      • not recommend software
                        sdetweil @uok825
                        @uok825 thats the correct version, all good…
                        • U
                          uok825 @sdetweil
                          pi@raspberrypi:~ $ pm2 logs --lines=100
                          PM2        | 2020-06-26T19:32:13: PM2 log: App [MagicMirror:0] starting in -fork mode-
                          PM2        | 2020-06-26T19:32:14: PM2 log: App [MagicMirror:0] online
                          /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
                          /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
                          0|MagicMir |
                          0|MagicMir | > magicmirror@2.11.0 start /home/pi/MagicMirror
                          0|MagicMir | > ./run-start.sh $1
                          0|MagicMir |
                          0|MagicMir | [2020-06-26 19:32:39.858] [LOG] Starting MagicMirror: v2.11.0
                          0|MagicMir | [2020-06-26 19:32:40.063] [LOG] Loading config ...
                          0|MagicMir | [2020-06-26 19:32:40.158] [LOG] Loading module helpers ...
                          0|MagicMir | [2020-06-26 19:32:40.196] [LOG] No helper found for module: alert.
                          0|MagicMir | [2020-06-26 19:32:41.395] [LOG] Initializing new module helper ...
                          0|MagicMir | [2020-06-26 19:32:41.428] [LOG] Module helper loaded: updatenotification
                          0|MagicMir | [2020-06-26 19:32:41.451] [LOG] No helper found for module: clock.
                          0|MagicMirror  | [2020-06-26 19:32:48.510] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:32:48.525] [LOG] Module helper loaded: calendar
                          0|MagicMirror  | [2020-06-26 19:32:48.537] [LOG] No helper found for module: currentweather.
                          0|MagicMirror  | [2020-06-26 19:32:48.551] [LOG] No helper found for module: weatherforecast.
                          0|MagicMirror  | [2020-06-26 19:32:49.314] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:32:49.334] [LOG] Module helper loaded: newsfeed
                          0|MagicMirror  | [2020-06-26 19:32:53.427] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:32:53.442] [LOG] Module helper loaded: MMM-Screencast
                          0|MagicMirror  | [2020-06-26 19:32:53.478] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:32:53.505] [LOG] Module helper loaded: MMM-LICE
                          0|MagicMirror  | [2020-06-26 19:33:03.595] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:33:03.605] [LOG] Module helper loaded: MMM-awesome-alexa
                          0|MagicMirror  | [2020-06-26 19:33:03.624] [LOG] All module helpers loaded.
                          0|MagicMirror  | [2020-06-26 19:33:05.811] [LOG] Starting server on port 8080 ...
                          0|MagicMirror  | [2020-06-26 19:33:05.999] [LOG] Server started ...
                          0|MagicMirror  | [2020-06-26 19:33:06.043] [LOG] Connecting socket for: updatenotification
                          0|MagicMirror  | [2020-06-26 19:33:06.071] [LOG] Connecting socket for: calendar
                          0|MagicMirror  | [2020-06-26 19:33:06.113] [LOG] Starting node helper for: calendar
                          0|MagicMirror  | [2020-06-26 19:33:06.134] [LOG] Connecting socket for: newsfeed
                          0|MagicMirror  | [2020-06-26 19:33:06.160] [LOG] Starting module: newsfeed
                          0|MagicMirror  | [2020-06-26 19:33:06.165] [LOG] Connecting socket for: MMM-Screencast
                          0|MagicMirror  | [2020-06-26 19:33:06.207] [LOG] Connecting socket for: MMM-LICE
                          0|MagicMirror  | [2020-06-26 19:33:06.231] [LOG] Starting node_helper for: MMM-LICE
                          0|MagicMirror  | [2020-06-26 19:33:06.265] [LOG] Connecting socket for: MMM-awesome-alexa
                          0|MagicMirror  | [2020-06-26 19:33:06.293] [LOG] Sockets connected & modules started ...
                          0|MagicMirror  | [2020-06-26 19:33:06.320] [LOG]
                          0|MagicMirror  | Ready to go! Please point your browser to: http://0.0.0.0:8080
                          0|MagicMirror  | Starting chromium browser now, have patience, it takes a minute
                          0|MagicMirror  | [2020-06-26 19:33:06.989] [LOG]
                          0|MagicMirror  | Whoops! There was an uncaught exception...
                          0|MagicMirror  | [2020-06-26 19:33:07.071] [ERROR]
                          0|MagicMirror  | { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                          0|MagicMirror  |     at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                          0|MagicMirror  |     at listenInCluster (net.js:1328:12)
                          0|MagicMirror  |     at doListen (net.js:1461:7)
                          0|MagicMirror  |     at process._tickCallback (internal/process/next_tick.js:63:19)
                          0|MagicMirror  |     at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
                          0|MagicMirror  |     at startup (internal/bootstrap/node.js:283:19)
                          0|MagicMirror  |     at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                          0|MagicMirror  |   code: 'EADDRINUSE',
                          0|MagicMirror  |   errno: 'EADDRINUSE',
                          0|MagicMirror  |   syscall: 'listen',
                          0|MagicMirror  |   address: '0.0.0.0',
                          0|MagicMirror  |   port: 8080 }
                          0|MagicMirror  | [2020-06-26 19:33:07.445] [LOG]
                          0|MagicMirror  | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          0|MagicMirror  | [2020-06-26 19:33:07.470] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          0|MagicMirror  | [2020-06-26 19:34:39.220] [LOG]
                          0|MagicMirror  | Use existing news fetcher for url: http://www.cumhuriyet.com.tr/rss/son_dakika.xml
                          0|MagicMirror  | [2020-06-26 19:34:46.507] [LOG]
                          0|MagicMirror  | Use existing news fetcher for url: https://www.birgun.net/xml/rss.xml
                          0|MagicMirror  | [2020-06-26 19:34:46.823] [LOG]
                          0|MagicMirror  | Use existing news fetcher for url: https://www.sozcu.com.tr/sitemap_google_news.xml
                          PM2            | App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                          PM2            | App [MagicMirror:0] starting in -fork mode-
                          PM2            | App [MagicMirror:0] online
                          0|MagicMirror  | > magicmirror@2.11.0 start /home/pi/MagicMirror
                          0|MagicMirror  | > ./run-start.sh $1
                          0|MagicMirror  | [2020-06-26 19:35:35.559] [LOG] Starting MagicMirror: v2.11.0
                          0|MagicMirror  | [2020-06-26 19:35:35.698] [LOG] Loading config ...
                          0|MagicMirror  | [2020-06-26 19:35:35.787] [LOG] Loading module helpers ...
                          0|MagicMirror  | [2020-06-26 19:35:35.832] [LOG] No helper found for module: alert.
                          0|MagicMirror  | [2020-06-26 19:35:36.721] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:35:36.746] [LOG] Module helper loaded: updatenotification
                          0|MagicMirror  | [2020-06-26 19:35:36.775] [LOG] No helper found for module: clock.
                          0|MagicMirror  | [2020-06-26 19:35:42.002] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:35:42.018] [LOG] Module helper loaded: calendar
                          0|MagicMirror  | [2020-06-26 19:35:42.042] [LOG] No helper found for module: currentweather.
                          0|MagicMirror  | [2020-06-26 19:35:42.061] [LOG] No helper found for module: weatherforecast.
                          0|MagicMirror  | [2020-06-26 19:35:42.609] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:35:42.622] [LOG] Module helper loaded: newsfeed
                          0|MagicMirror  | [2020-06-26 19:35:46.278] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:35:46.292] [LOG] Module helper loaded: MMM-Screencast
                          0|MagicMirror  | [2020-06-26 19:35:46.347] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:35:46.355] [LOG] Module helper loaded: MMM-LICE
                          0|MagicMirror  | [2020-06-26 19:35:58.302] [LOG] Initializing new module helper ...
                          0|MagicMirror  | [2020-06-26 19:35:58.317] [LOG] Module helper loaded: MMM-awesome-alexa
                          0|MagicMirror  | [2020-06-26 19:35:58.344] [LOG] All module helpers loaded.
                          0|MagicMirror  | [2020-06-26 19:36:00.278] [LOG] Starting server on port 8080 ...
                          0|MagicMirror  | [2020-06-26 19:36:00.469] [LOG] Server started ...
                          0|MagicMirror  | [2020-06-26 19:36:00.497] [LOG] Connecting socket for: updatenotification
                          0|MagicMirror  | [2020-06-26 19:36:00.543] [LOG] Connecting socket for: calendar
                          0|MagicMirror  | [2020-06-26 19:36:00.571] [LOG] Starting node helper for: calendar
                          0|MagicMirror  | [2020-06-26 19:36:00.605] [LOG] Connecting socket for: newsfeed
                          0|MagicMirror  | [2020-06-26 19:36:00.621] [LOG] Starting module: newsfeed
                          0|MagicMirror  | [2020-06-26 19:36:00.651] [LOG] Connecting socket for: MMM-Screencast
                          0|MagicMirror  | [2020-06-26 19:36:00.694] [LOG] Connecting socket for: MMM-LICE
                          0|MagicMirror  | [2020-06-26 19:36:00.725] [LOG] Starting node_helper for: MMM-LICE
                          0|MagicMirror  | [2020-06-26 19:36:00.755] [LOG] Connecting socket for: MMM-awesome-alexa
                          0|MagicMirror  | [2020-06-26 19:36:00.780] [LOG] Sockets connected & modules started ...
                          0|MagicMirror  | [2020-06-26 19:36:00.815] [LOG]
                          0|MagicMirror  | [2020-06-26 19:36:01.577] [LOG]
                          0|MagicMirror  | [2020-06-26 19:36:01.640] [ERROR]
                          0|MagicMirror  | [2020-06-26 19:36:02.095] [LOG]
                          0|MagicMirror  | [2020-06-26 19:36:02.111] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          She is not wake up with “Alexa”
                          S U 2 Replies Last reply
                            sdetweil @uok825
                            @uok825 u have it running already at boot…
                            pm2 stop all
                            • U
                              uok825 @uok825
                              @uok825 How can i fix the problem? Alexa don’t wake up.
                                sdetweil @uok825
                                @uok825 shut down all the magic Mirror servers…
                                do
                                pm2 status
                                show the results here
                                then
                                pm2 stop all
                                check to make sure none are running
                                ps -ef | grep MagicMirror
                                once all are stopped, then
                                pm2 start 0
                                then test
                                • U
                                  uok825 @sdetweil
                                  @sdetweil Still same, don’t wake up
                                    sdetweil @uok825
                                    @uok825 show me the logs
                                    • U
                                      uok825 @sdetweil
                                      @sdetweil ```
                                      PM2 | 2020-06-26T22:31:59: PM2 log: pid=2328 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T22:32:00: PM2 log: pid=2328 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T22:32:00: PM2 log: Process with pid 2328 still alive after 1600ms, sending it SIGKILL now…
                                      PM2 | 2020-06-26T22:32:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                                      PM2 | 2020-06-26T22:32:04: PM2 log: pid=2328 msg=process killed
                                      PM2 | 2020-06-26T22:32:04: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                      PM2 | 2020-06-26T22:32:04: PM2 log: App [MagicMirror:0] online
                                      PM2 | 2020-06-26T22:43:21: PM2 log: Stopping app:MagicMirror id:0
                                      PM2 | 2020-06-26T22:43:25: PM2 log: pid=2675 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T22:43:26: PM2 log: pid=2675 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T22:43:27: PM2 log: pid=2675 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T22:43:27: PM2 log: Process with pid 2675 still alive after 1600ms, sending it SIGKILL now…
                                      PM2 | 2020-06-26T22:43:30: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                                      PM2 | 2020-06-26T22:43:30: PM2 log: pid=2675 msg=process killed
                                      PM2 | 2020-06-26T22:43:30: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                      PM2 | 2020-06-26T22:43:30: PM2 log: App [MagicMirror:0] online
                                      PM2 | 2020-06-26T23:37:35: PM2 log: Stopping app:MagicMirror id:0
                                      PM2 | 2020-06-26T23:37:38: PM2 log: pid=3078 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T23:37:39: PM2 log: pid=3078 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T23:37:40: PM2 log: pid=3078 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T23:37:40: PM2 log: Process with pid 3078 still alive after 1600ms, sending it SIGKILL now…
                                      PM2 | 2020-06-26T23:37:43: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                                      PM2 | 2020-06-26T23:37:43: PM2 log: pid=3078 msg=process killed
                                      PM2 | 2020-06-26T23:37:43: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                      PM2 | 2020-06-26T23:37:43: PM2 log: App [MagicMirror:0] online
                                      PM2 | 2020-06-26T23:40:55: PM2 log: Stopping app:MagicMirror id:0
                                      PM2 | 2020-06-26T23:40:58: PM2 log: pid=3768 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T23:40:59: PM2 log: pid=3768 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T23:40:59: PM2 log: Process with pid 3768 still alive after 1600ms, sending it SIGKILL now…
                                      PM2 | 2020-06-26T23:41:03: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                                      PM2 | 2020-06-26T23:41:03: PM2 log: pid=3768 msg=process killed
                                      PM2 | 2020-06-26T23:41:03: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                      PM2 | 2020-06-26T23:41:03: PM2 log: App [MagicMirror:0] online
                                      PM2 | 2020-06-26T23:45:57: PM2 log: Stopping app:MagicMirror id:0
                                      PM2 | 2020-06-26T23:45:59: PM2 log: pid=4108 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T23:46:00: PM2 log: pid=4108 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T23:46:01: PM2 log: pid=4108 msg=failed to kill - retrying in 100ms
                                      PM2 | 2020-06-26T23:46:01: PM2 log: Process with pid 4108 still alive after 1600ms, sending it SIGKILL now…
                                      PM2 | 2020-06-26T23:46:04: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGKILL]
                                      PM2 | 2020-06-26T23:46:04: PM2 log: pid=4108 msg=process killed
                                      PM2 | 2020-06-26T23:48:57: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                      PM2 | 2020-06-26T23:48:57: PM2 log: App [MagicMirror:0] online
                                      0|MagicMir | errno: ‘EADDRINUSE’,
                                      0|MagicMir | syscall: ‘listen’,
                                      0|MagicMir | address: ‘0.0.0.0’,
                                      0|MagicMir | port: 8080 }
                                      0|MagicMir | [2020-06-26 22:01:07.509] [ERROR] (node:804) UnhandledPromiseRejectionWarning: Error: Error: socket hang up
                                      0|MagicMir | at obtainToken.then.catch.e (/home/pi/MagicMirror/modules/MMM-awesome-alexa/node_helper.js:1:6073)
                                      0|MagicMir | at process._tickCallback (internal/process/next_tick.js:68:7)
                                      0|MagicMir | [2020-06-26 22:01:07.556] [ERROR] (node:804) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
                                      0|MagicMir | [2020-06-26 22:01:07.585] [ERROR] (node:804) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                                      0|MagicMir | [2020-06-26 22:10:57.436] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                      0|MagicMir | at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                                      0|MagicMir | at listenInCluster (net.js:1328:12)
                                      0|MagicMir | at doListen (net.js:1461:7)
                                      0|MagicMir | at process._tickCallback (internal/process/next_tick.js:63:19)
                                      0|MagicMir | at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
                                      0|MagicMir | at startup (internal/bootstrap/node.js:283:19)
                                      0|MagicMir | at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                      0|MagicMir | code: ‘EADDRINUSE’,
                                      0|MagicMir | [2020-06-26 22:29:48.332] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                      0|MagicMir | [2020-06-26 22:32:38.374] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                      0|MagicMir | [2020-06-26 22:44:05.320] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                      0|MagicMir | [2020-06-26 23:38:17.501] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                      0|MagicMir | [2020-06-26 23:41:37.375] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                      0|MagicMir | [2020-06-26 23:49:31.461] [ERROR] { Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                      0|MagicMir | [2020-06-26 23:38:16.062] [LOG] Module helper loaded: MMM-awesome-alexa
                                      0|MagicMir | [2020-06-26 23:38:16.072] [LOG] All module helpers loaded.
                                      0|MagicMir | [2020-06-26 23:38:17.060] [LOG] Starting server on port 8080 …
                                      0|MagicMir | [2020-06-26 23:38:17.151] [LOG] Server started …
                                      0|MagicMir | [2020-06-26 23:38:17.163] [LOG] Connecting socket for: updatenotification
                                      0|MagicMir | [2020-06-26 23:38:17.177] [LOG] Connecting socket for: calendar
                                      0|MagicMir | [2020-06-26 23:38:17.189] [LOG] Starting node helper for: calendar
                                      0|MagicMir | [2020-06-26 23:38:17.201] [LOG] Connecting socket for: newsfeed
                                      0|MagicMir | [2020-06-26 23:38:17.212] [LOG] Starting module: newsfeed
                                      0|MagicMir | [2020-06-26 23:38:17.222] [LOG] Connecting socket for: MMM-Screencast
                                      0|MagicMir | [2020-06-26 23:38:17.233] [LOG] Connecting socket for: MMM-LICE
                                      0|MagicMir | [2020-06-26 23:38:17.250] [LOG] Starting node_helper for: MMM-LICE
                                      0|MagicMir | [2020-06-26 23:38:17.256] [LOG] Connecting socket for: MMM-awesome-alexa
                                      0|MagicMir | [2020-06-26 23:38:17.268] [LOG] Sockets connected & modules started …
                                      0|MagicMir | [2020-06-26 23:38:17.284] [LOG]
                                      0|MagicMir | Ready to go! Please point your browser to: http://0.0.0.0:8080
                                      0|MagicMir | Starting chromium browser now, have patience, it takes a minute
                                      0|MagicMir | [2020-06-26 23:38:17.481] [LOG] Whoops! There was an uncaught exception…
                                      0|MagicMir | [2020-06-26 23:38:17.613] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMir | [2020-06-26 23:38:17.629] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|MagicMir |
                                      0|MagicMir |
                                      0|MagicMir | [2020-06-26 23:41:19.020] [LOG] Starting MagicMirror: v2.11.0
                                      0|MagicMir | [2020-06-26 23:41:19.145] [LOG] Loading config …
                                      0|MagicMir | [2020-06-26 23:41:19.195] [LOG] Loading module helpers …
                                      0|MagicMir | [2020-06-26 23:41:19.212] [LOG] No helper found for module: alert.
                                      0|MagicMir | [2020-06-26 23:41:19.638] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:41:19.649] [LOG] Module helper loaded: updatenotification
                                      0|MagicMir | [2020-06-26 23:41:19.661] [LOG] No helper found for module: clock.
                                      0|MagicMir | [2020-06-26 23:41:23.649] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:41:23.659] [LOG] Module helper loaded: calendar
                                      0|MagicMir | [2020-06-26 23:41:23.670] [LOG] No helper found for module: currentweather.
                                      0|MagicMir | [2020-06-26 23:41:23.678] [LOG] No helper found for module: weatherforecast.
                                      0|MagicMir | [2020-06-26 23:41:23.923] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:41:23.933] [LOG] Module helper loaded: newsfeed
                                      0|MagicMir | [2020-06-26 23:41:26.712] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:41:26.721] [LOG] Module helper loaded: MMM-Screencast
                                      0|MagicMir | [2020-06-26 23:41:26.745] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:41:26.754] [LOG] Module helper loaded: MMM-LICE
                                      0|MagicMir | [2020-06-26 23:41:35.901] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:41:35.912] [LOG] Module helper loaded: MMM-awesome-alexa
                                      0|MagicMir | [2020-06-26 23:41:35.923] [LOG] All module helpers loaded.
                                      0|MagicMir | [2020-06-26 23:41:36.918] [LOG] Starting server on port 8080 …
                                      0|MagicMir | [2020-06-26 23:41:37.012] [LOG] Server started …
                                      0|MagicMir | [2020-06-26 23:41:37.026] [LOG] Connecting socket for: updatenotification
                                      0|MagicMir | [2020-06-26 23:41:37.037] [LOG] Connecting socket for: calendar
                                      0|MagicMir | [2020-06-26 23:41:37.049] [LOG] Starting node helper for: calendar
                                      0|MagicMir | [2020-06-26 23:41:37.062] [LOG] Connecting socket for: newsfeed
                                      0|MagicMir | [2020-06-26 23:41:37.074] [LOG] Starting module: newsfeed
                                      0|MagicMir | [2020-06-26 23:41:37.085] [LOG] Connecting socket for: MMM-Screencast
                                      0|MagicMir | [2020-06-26 23:41:37.099] [LOG] Connecting socket for: MMM-LICE
                                      0|MagicMir | [2020-06-26 23:41:37.111] [LOG] Starting node_helper for: MMM-LICE
                                      0|MagicMir | [2020-06-26 23:41:37.123] [LOG] Connecting socket for: MMM-awesome-alexa
                                      0|MagicMir | [2020-06-26 23:41:37.135] [LOG] Sockets connected & modules started …
                                      0|MagicMir | [2020-06-26 23:41:37.144] [LOG]
                                      0|MagicMir | [2020-06-26 23:41:37.349] [LOG] Whoops! There was an uncaught exception…
                                      0|MagicMir | [2020-06-26 23:41:37.489] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMir | [2020-06-26 23:41:37.497] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|MagicMir |
                                      0|MagicMir |
                                      0|MagicMir | [2020-06-26 23:49:13.064] [LOG] Starting MagicMirror: v2.11.0
                                      0|MagicMir | [2020-06-26 23:49:13.190] [LOG] Loading config …
                                      0|MagicMir | [2020-06-26 23:49:13.237] [LOG] Loading module helpers …
                                      0|MagicMir | [2020-06-26 23:49:13.252] [LOG] No helper found for module: alert.
                                      0|MagicMir | [2020-06-26 23:49:13.678] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:49:13.689] [LOG] Module helper loaded: updatenotification
                                      0|MagicMir | [2020-06-26 23:49:13.701] [LOG] No helper found for module: clock.
                                      0|MagicMir | [2020-06-26 23:49:17.732] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:49:17.741] [LOG] Module helper loaded: calendar
                                      0|MagicMir | [2020-06-26 23:49:17.753] [LOG] No helper found for module: currentweather.
                                      0|MagicMir | [2020-06-26 23:49:17.763] [LOG] No helper found for module: weatherforecast.
                                      0|MagicMir | [2020-06-26 23:49:18.002] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:49:18.011] [LOG] Module helper loaded: newsfeed
                                      0|MagicMir | [2020-06-26 23:49:20.774] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:49:20.784] [LOG] Module helper loaded: MMM-Screencast
                                      0|MagicMir | [2020-06-26 23:49:30.044] [LOG] Initializing new module helper …
                                      0|MagicMir | [2020-06-26 23:49:30.054] [LOG] Module helper loaded: MMM-awesome-alexa
                                      0|MagicMir | [2020-06-26 23:49:30.064] [LOG] All module helpers loaded.
                                      0|MagicMir | [2020-06-26 23:49:31.041] [LOG] Starting server on port 8080 …
                                      0|MagicMir | [2020-06-26 23:49:31.128] [LOG] Server started …
                                      0|MagicMir | [2020-06-26 23:49:31.140] [LOG] Connecting socket for: updatenotification
                                      0|MagicMir | [2020-06-26 23:49:31.155] [LOG] Connecting socket for: calendar
                                      0|MagicMir | [2020-06-26 23:49:31.165] [LOG] Starting node helper for: calendar
                                      0|MagicMir | [2020-06-26 23:49:31.175] [LOG] Connecting socket for: newsfeed
                                      0|MagicMir | [2020-06-26 23:49:31.189] [LOG] Starting module: newsfeed
                                      0|MagicMir | [2020-06-26 23:49:31.200] [LOG] Connecting socket for: MMM-Screencast
                                      0|MagicMir | [2020-06-26 23:49:31.208] [LOG] Connecting socket for: MMM-awesome-alexa
                                      0|MagicMir | [2020-06-26 23:49:31.226] [LOG] Sockets connected & modules started …
                                      0|MagicMir | [2020-06-26 23:49:31.232] [LOG]
                                      0|MagicMir | [2020-06-26 23:49:31.441] [LOG] Whoops! There was an uncaught exception…
                                      0|MagicMir | [2020-06-26 23:49:31.570] [LOG] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|MagicMir | [2020-06-26 23:49:31.585] [LOG] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        sdetweil @uok825
                                        @uok825 still says address in use… do you have it stopped or not? what does pm2 status show?
                                        do NOT reboot
                                        • U
                                          uok825 @sdetweil
                                          @sdetweil i “pm2 stop all”
                                            sdetweil @uok825
                                            @uok825 pm2 status please
                                            • 12
                                            • 13
                                            • 7 / 13
