    Controller Board issue
    6 Posts 6 Posters 3.3k Views 5 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      Might have to figure out how to adjust the brightness and contrast. Some boards they’re backwards from normal.
        dhallgb
        I had a similar issue on a different panel where the back light and on/off would function, but no menu would show. I found that I’d inserted the LVDS ribbon cable the wrong way up on the controller connector.
          A Former User
          hi, try with another device than RPI
          If works, tune your config.txt in /boot directory and force HDMI ouput on start
            sonicgoose
            That looks suspiciously like the controller board I ordered off eBay and which didn’t work. Power to the monitor was fine, the backlight would turn on, but no signal through the LVDS cable. After much back and forth with the seller, including confirmation I had given them the correct LCD model number and confirmation they had shipped the correct board, they shipped me a second one, which also didn’t work. So I bought one off a different eBay seller that unbeknownst to me worked in the same warehouse as the first seller, so the third controller also didn’t work.
            After many months of trying different things, I finally tracked down the source of the problem with the help of a friend. The controller boards are soldered to output 16:9, but the display I had was natively set to 16:10. There was no way in hell it was ever going to work.
              MadScientist @sonicgoose
              @sonicgoose said in Controller Board issue:
              Soldered? I think the board was just shipped with the wrong firmware. Unfortunately for these boards you need extra flashing equipment to change the firmware.
