    startup
    11 Posts 2 Posters 2.9k Views 2 Watching
      sdetweil @geo
      @geo did u change the password?
      tell me more about unable to download updates and then did something
      • G Offline
        geo
        hi i am asked for plword etc at boot but still dont get to homepage.i do get a stream of info headed by raspbian GNU/Linux 10raspberrypi tty1.
        i thought i had loaded something to do with github cant remember what and then got in to this mess.cheers
        • G Offline
          geo @geo
          @geo also this appears init version 2.93 booting
          raspbian gnu/linux 10 raspberrypi.tty1
            sdetweil @geo
            @geo don’t know what that means. I’m guessing you may have to rebuild the SD card and start over
            • G Offline
              geo
              hi thx for the reply altho to start again is not something i could consider because of my lack of knowledge and the time it took me to get the mm up and running.
              i think my age,i’m 80, makes a daunting project.
              thx again for your input.
              regards,
              geo
                sdetweil @geo
                @geo I’ll be 69 next week. don’t let it stop you. my install script will make fast work of getting running
                see
                • G Offline
                  geo
                  hi,your command gives a no such file or directory
                  when i try to start get llectron2214 Gtk-warning cannot open display :0
                  npm err codeelifecycle
                  npm errmagicmirror@2.9.0 start: 'sh run-start.sh
                  npm errexit status 1
                  err failed atthe magicmirror@2.9.0 start script
                  npm errthis is not a problem with npm there is likely additional logging output above
                  err a complete log of this run can be found in
                  npm err /home/pi/.nmp/_logs/2020-07-02t19_18_26_6512-debug.log
                  hope this makes
                  cheers, geo
                    sdetweil @geo
                    @geo are u running in text mode? CLI
                    you must have a graphical desktop
                    if that is ok, display:0 is the physical display, do u have one attached?
                    • G Offline
                      geo
                      sorry but i have no idea what any of that is
                        sdetweil @geo
                        @geo when u boot your pi, do you see the temples on the background? using raspian buster) or do you see a black screen with a command prompt
