    startup
    11 Posts 2 Posters 2.9k Views 2 Watching
    • G Offline
      geo
      hi,my mm has been running ok but unable to download updates.read that github was needed so did so or thought i had,now mirror will not open
      when i boot am asked for raspberry login tried pi ok but cant input p/word raspberry
      can anyone tell me where i have gone wrong
      cheers
        sdetweil @geo
        @geo did u change the password?
        tell me more about unable to download updates and then did something
        • G Offline
          geo
          hi i am asked for plword etc at boot but still dont get to homepage.i do get a stream of info headed by raspbian GNU/Linux 10raspberrypi tty1.
          i thought i had loaded something to do with github cant remember what and then got in to this mess.cheers
          • G Offline
            geo @geo
            @geo also this appears init version 2.93 booting
            raspbian gnu/linux 10 raspberrypi.tty1
              sdetweil @geo
              @geo don’t know what that means. I’m guessing you may have to rebuild the SD card and start over
              • G Offline
                geo
                hi thx for the reply altho to start again is not something i could consider because of my lack of knowledge and the time it took me to get the mm up and running.
                i think my age,i’m 80, makes a daunting project.
                thx again for your input.
                regards,
                geo
                  sdetweil @geo
                  @geo I’ll be 69 next week. don’t let it stop you. my install script will make fast work of getting running
                  see
                  • G Offline
                    geo
                    hi,your command gives a no such file or directory
                    when i try to start get llectron2214 Gtk-warning cannot open display :0
                    npm err codeelifecycle
                    npm errmagicmirror@2.9.0 start: 'sh run-start.sh
                    npm errexit status 1
                    err failed atthe magicmirror@2.9.0 start script
                    npm errthis is not a problem with npm there is likely additional logging output above
                    err a complete log of this run can be found in
                    npm err /home/pi/.nmp/_logs/2020-07-02t19_18_26_6512-debug.log
                    hope this makes
                    cheers, geo
                      sdetweil @geo
                      @geo are u running in text mode? CLI
                      you must have a graphical desktop
                      if that is ok, display:0 is the physical display, do u have one attached?
                      • G Offline
                        geo
                        sorry but i have no idea what any of that is
