    MMM-DHT22 : Temperature and Humidity : Undefined
    9 Posts 2 Posters 1.6k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer @RIKKO14
      @RIKKO14
      Make sure to change the sensor pin to your pin
      		sensorPin: 2, ← This line
        RIKKO14
        My MMM-DHT-Sensor.js :
        Module.register("MMM-DHT-Sensor", {
        	defaults: {
        		updateInterval: 60 * 60 * 1000, // Every hour.
        		initialLoadDelay: 0, // No delay/
        		animationSpeed: 1000, // One second.
        		units: config.units, // Celsius
        		relativeScale: 30,
        		debug: false,
        		sensorPin: 2,
        		sensorType: 22
        My config.js :
        	module: "MMM-DHT-Sensor",
        	header: "Upstairs",
        		sensorPin: 2,
        		sensorType: 22,
        		units: "metric",
        		relativeScale: 35,
        		debug: false
        • BKeyportB Offline
          @RIKKO14
          The following config.js snippet would match your graphic allowing for DHT-22 rather than DHT-11,
          	header: "Upstairs",
          		sensorPin: 20, // use BCM/GPIO numbering, not physical Pin # or wiringPi.
          		sensorType: 22,
          		units: "metric",
          		relativeScale: 35,
          		debug: false
            RIKKO14
            I do this in first and i retry now but it’s always display “loading sensor data”, then i modify sensorPin: 20,in the MMM-DHT-Sensor.js because it stayed code_sensorPin: 20, but the problem stay here…
            I even connected DHT22 directly to my raspi (GND in pin 6 and VCC in pin 4)
            it’s annoying because it sounds simple …
            my DHT22 would it be broken, how to know it …
            • BKeyportB Offline
              @RIKKO14 First things first.
              1. Check your pinout according to http://pinout.xyz
              2. make sure you installed exactly to their instructions.
              3. reboot after install.
                RIKKO14
                I remove MMM-DHT Sensor, MMM-DHT22 and MMM-dht22, I did not removel node-dht-sensor because I don’t know how to remove, I reinstall MMM-DHT Sensor, I left in GPIO 2 (3) not to change the config.js and the MMM-DHT-Sensor.js, it does not work either, after several relaunch of MM, it worked one time but after a relaunch again it does not work anymore. .
                It’s crazy, I ordered a new DHT22 because it may be defective …
