    MMM-DHT22 : Temperature and Humidity : Undefined
    9 Posts 2 Posters 1.8k Views 3 Watching
      RIKKO14
      I just installed the MMM-DHT22 module
      here is my installation with a RasberryPi and DTH 22 (not 11) :
      I modified in my config.js and in MMM-DTH22.js: sensorPIN: 20,,
      but the temperature is displayed in Undefined and I have nothing in humidity. I tried with sensorPIN: 38, while leaving my DTH22 connected to GPIO 20 but that does not change anything.
      Thank you for your help.
      • BKeyportB Offline
        BKeyport Module Developer
        I found that module isn’t working for me, either. ended up using MMM-DHT-Sensor
        https://github.com/ryck/MMM-DHT-Sensor
          RIKKO14
          thank you for the info, it worked with MMM-DHT-Sensor by plugging it into the GPIO 2 as a prerequisite then rebooting it does not work anymore it displays all the time “loading sensor data”
          • BKeyportB Offline
            BKeyport Module Developer @RIKKO14
            @RIKKO14
            Make sure to change the sensor pin to your pin
            		sensorPin: 2, ← This line
              RIKKO14
              My MMM-DHT-Sensor.js :
              Module.register("MMM-DHT-Sensor", {
              	defaults: {
              		updateInterval: 60 * 60 * 1000, // Every hour.
              		initialLoadDelay: 0, // No delay/
              		animationSpeed: 1000, // One second.
              		units: config.units, // Celsius
              		relativeScale: 30,
              		debug: false,
              		sensorPin: 2,
              		sensorType: 22
              My config.js :
              	module: "MMM-DHT-Sensor",
              	header: "Upstairs",
              		sensorPin: 2,
              		sensorType: 22,
              		units: "metric",
              		relativeScale: 35,
              		debug: false
              • BKeyportB Offline
                @RIKKO14
                The following config.js snippet would match your graphic allowing for DHT-22 rather than DHT-11,
                	header: "Upstairs",
                		sensorPin: 20, // use BCM/GPIO numbering, not physical Pin # or wiringPi.
                		sensorType: 22,
                		units: "metric",
                		relativeScale: 35,
                		debug: false
                  RIKKO14
                  I do this in first and i retry now but it’s always display “loading sensor data”, then i modify sensorPin: 20,in the MMM-DHT-Sensor.js because it stayed code_sensorPin: 20, but the problem stay here…
                  I even connected DHT22 directly to my raspi (GND in pin 6 and VCC in pin 4)
                  it’s annoying because it sounds simple …
                  my DHT22 would it be broken, how to know it …
                  • BKeyportB Offline
                    @RIKKO14 First things first.
                    1. Check your pinout according to http://pinout.xyz
                    2. make sure you installed exactly to their instructions.
                    3. reboot after install.
                      RIKKO14
                      I remove MMM-DHT Sensor, MMM-DHT22 and MMM-dht22, I did not removel node-dht-sensor because I don’t know how to remove, I reinstall MMM-DHT Sensor, I left in GPIO 2 (3) not to change the config.js and the MMM-DHT-Sensor.js, it does not work either, after several relaunch of MM, it worked one time but after a relaunch again it does not work anymore. .
                      It’s crazy, I ordered a new DHT22 because it may be defective …
