MMM-DHT22 : Temperature and Humidity : Undefined
9 Posts 2 Posters 1.3k Views 3 Watching
    RIKKO14
    I just installed the MMM-DHT22 module
    here is my installation with a RasberryPi and DTH 22 (not 11) :
    I modified in my config.js and in MMM-DTH22.js: sensorPIN: 20,,
    but the temperature is displayed in Undefined and I have nothing in humidity. I tried with sensorPIN: 38, while leaving my DTH22 connected to GPIO 20 but that does not change anything.
    Thank you for your help.
      BKeyport Module Developer
      I found that module isn’t working for me, either. ended up using MMM-DHT-Sensor
      https://github.com/ryck/MMM-DHT-Sensor
        RIKKO14
        thank you for the info, it worked with MMM-DHT-Sensor by plugging it into the GPIO 2 as a prerequisite then rebooting it does not work anymore it displays all the time “loading sensor data”
        B 1 Reply Last reply Jul 8, 2020, 12:01 AM Reply Quote 0
          BKeyport Module Developer @RIKKO14
          @RIKKO14
          Make sure to change the sensor pin to your pin
          		sensorPin: 2, ← This line
            RIKKO14
            My MMM-DHT-Sensor.js :
            Module.register("MMM-DHT-Sensor", {
            	defaults: {
            		updateInterval: 60 * 60 * 1000, // Every hour.
            		initialLoadDelay: 0, // No delay/
            		animationSpeed: 1000, // One second.
            		units: config.units, // Celsius
            		relativeScale: 30,
            		debug: false,
            		sensorPin: 2,
            		sensorType: 22
            My config.js :
            	module: "MMM-DHT-Sensor",
            	header: "Upstairs",
            		sensorPin: 2,
            		sensorType: 22,
            		units: "metric",
            		relativeScale: 35,
            		debug: false
            B 1 Reply Last reply Jul 8, 2020, 8:16 AM Reply Quote 0
              @RIKKO14
              The following config.js snippet would match your graphic allowing for DHT-22 rather than DHT-11,
              	header: "Upstairs",
              		sensorPin: 20, // use BCM/GPIO numbering, not physical Pin # or wiringPi.
              		sensorType: 22,
              		units: "metric",
              		relativeScale: 35,
              		debug: false
                RIKKO14
                I do this in first and i retry now but it’s always display “loading sensor data”, then i modify sensorPin: 20,in the MMM-DHT-Sensor.js because it stayed code_sensorPin: 20, but the problem stay here…
                I even connected DHT22 directly to my raspi (GND in pin 6 and VCC in pin 4)
                it’s annoying because it sounds simple …
                my DHT22 would it be broken, how to know it …
                B 1 Reply Last reply Jul 8, 2020, 11:59 PM Reply Quote 0
                  @RIKKO14 First things first.
                  1. Check your pinout according to http://pinout.xyz
                  2. make sure you installed exactly to their instructions.
                  3. reboot after install.
                    RIKKO14
                    I remove MMM-DHT Sensor, MMM-DHT22 and MMM-dht22, I did not removel node-dht-sensor because I don’t know how to remove, I reinstall MMM-DHT Sensor, I left in GPIO 2 (3) not to change the config.js and the MMM-DHT-Sensor.js, it does not work either, after several relaunch of MM, it worked one time but after a relaunch again it does not work anymore. .
                    It’s crazy, I ordered a new DHT22 because it may be defective …
