    CSS: Color And Style
    15 Posts 2 Posters 3.8k Views 2 Watching
      agentJames
      These are the pictures. This is what it looks like right now.
      I want it to look like:
      • mumblebajM Offline
        mumblebaj Module Developer @agentJames
        @agentJames Have you set the config option for colored to true?
        colored: true,
          agentJames @mumblebaj
          @mumblebaj Someone else told me to do that, so I did. Now it looks like this:
          Next is like how do I remove “United States” and how do I add multiple-colors so it will look like:5836d3d7-0ee6-4231-b833-2b2798ade9e0-image.png
            @agentJames Can you share your config for the module? Which calendar are you using?
              agentJames
                @agentJames The URL you are using does not look right. Can you swop it for the following? http://www.calendarlabs.com/templates/ical/US-Holidays.ics
                I think what you might be seeing is the example calendar
                  @mumblebaj I tried this URL and it gave me:e4df5d0f-1a79-4ba8-87aa-7e930e513f62-image.png
                    agentJames
                    I did some changing and now it looks like this:
                    The next question is what do I need to write in the config file to have 2 columns?
                      @agentJames I just installed the module and it works fine for me.
                      The config:
                                      module: "MMM-MyCalendar",
                                      header: "Events + Holidays",
                                              colored: true,
                                                      url: "https://www.officeholidays.com/ics/ics_country_iso.php?tbl_country=ZA"
                                                      symbol: 'calendar',
                                                      color: "#ffb350"
                      Although, I used a different calendar to test with.
                        @mumblebaj It works for me as well, thanks for the help, do you know how to make it into 2 columns so more events/holidays can show? Like this:aedf8b76-26e2-4190-b089-fe7a4cb8e3c3-image.png
                          @agentJames You should be able to set the config
                          columns: true
                            @mumblebaj If it is suppose to be written like this, I am getting no change.
                              @agentJames seems like there was a branch for the using-nunjucks. Maybe @j-e-f-f can advise on how to grab that branch as I don’t see the option in the default branch
