    Mirror Crashing
    11 Posts 2 Posters 2.2k Views 2 Watching
    • mumblebajM Offline
      mumblebaj Module Developer
      Hey Guys. I am having an issue. I recently updated my mirror to 2.12.0 and I have noticed that it crashes a few times a day. Below the error log.
      1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start' ]
      2 info using npm@6.1.0
      3 info using node@v9.11.2
      5 info lifecycle magicmirror@2.12.0~prestart: magicmirror@2.12.0
      6 info lifecycle magicmirror@2.12.0~start: magicmirror@2.12.0
      7 verbose lifecycle magicmirror@2.12.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.12.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/nod$
      9 verbose lifecycle magicmirror@2.12.0~start: CWD: /home/pi/MagicMirror
      10 silly lifecycle magicmirror@2.12.0~start: Args: [ '-c',
      10 silly lifecycle   'DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js' ]
      11 silly lifecycle magicmirror@2.12.0~start: Returned: code: 1  signal: null
      12 info lifecycle magicmirror@2.12.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      13 verbose stack Exit status 1
      13 verbose stack     at EventEmitter.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:304:16)
      13 verbose stack     at EventEmitter.emit (events.js:180:13)
      13 verbose stack     at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack     at ChildProcess.emit (events.js:180:13)
      13 verbose stack     at maybeClose (internal/child_process.js:936:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:220:5)
      14 verbose pkgid magicmirror@2.12.0
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.14.52-v7+
      17 verbose argv "/usr/bin/node" "/usr/bin/npm" "start"
      18 verbose node v9.11.2
      19 verbose npm  v6.1.0
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      22 error Exit status 1
      23 error Failed at the magicmirror@2.12.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [ 1, true ]
      I have also noticed this font error in the pm2 logs. Not sure if this is an issue and which module it refers to.
      Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
      ATTENTION: default value of option force_s3tc_enable overridden by environment.
      [2020-07-09 20:17:13.954] [ERROR]  Thu Jul 09 2020 20:17:13 GMT+0200 (South Africa Standard Time) - WatchDog: Heartbeat timeout. Frontend migh$
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.12.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.12.0 start script.
      npm ERR!     /home/pi/.npm/_logs/2020-07-09T18_17_14_885Z-debug.log
      Any help or advice would be appreciated.
        A Former User
        can you try this :
        pm2 stop 0
        npm start
        and give me full log result because PM2 log don’t speak enough
          mumblebaj Module Developer @Guest
          @Bugsounet Hi. Below from the npm log on start of mirror.
          1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'mm' ]
          4 verbose stack Error: ENOENT: no such file or directory, open '/home/pi/.npm/_logs/package.json'
          5 verbose cwd /home/pi/.npm/_logs
          7 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "mm"
          10 error path /home/pi/.npm/_logs/package.json
          11 error code ENOENT
          12 error errno -2
          13 error syscall open
          14 error enoent ENOENT: no such file or directory, open '/home/pi/.npm/_logs/package.json'
          15 error enoent This is related to npm not being able to find a file.
          16 verbose exit [ -2, true ]
          And from the NPM tail on npm start I can see only 1 error:
          [2020-07-10 20:06:50.717] [LOG]    Connecting socket for: MMM-NOAA3
          [2020-07-10 20:06:50.724] [LOG]    Sockets connected & modules started ...
          [2020-07-10 20:06:51.372] [LOG]    Launching application.
          Username for 'https://github.com': [2020-07-10 20:07:13.490] [LOG]    [20:07:13] - DEBUG - MMM-OpeningHours : Notification - SETUP
          [2020-07-10 20:07:13.499] [LOG]    [20:07:13] - DEBUG - MMM-OpeningHours : Started - false
          [2020-07-10 20:07:13.502] [LOG]    [20:07:13] - DEBUG - MMM-OpeningHours : Config -  {
            A Former User
            I say don’t want this…
            I want the log when you start it …
            pi@Raspberry:~/MagicMirror $ npm start
            magicmirror@2.12.0 start /home/pi/MagicMirror
            DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js        [2020-07-10 20:17:18.854] [LOG]    Starting MagicMirror: v2.12.0
            [2020-07-10 20:17:18.871] [LOG]    Loading config ...
            [2020-07-10 20:17:18.884] [LOG]    Loading module helpers ...
            [2020-07-10 20:17:18.888] [LOG]    No helper found for module: alert.
            [2020-07-10 20:17:18.988] [LOG]    Initializing new module helper ...
            [2020-07-10 20:17:18.990] [LOG]    Module helper loaded: updatenotification
            sorry if I ask a complex thing for you
            mumblebajM 3 Replies Last reply Reply Quote 0
              @Bugsounet Hi. Not complex at all.
              It seems that a module I installed previously was failing looking for my github credentials. I have removed the module and am tailing to log to see if any other errors pop up. It is just after 23:00 here. I will post tomorrow morning if there is anything else.
                @Bugsounet So, it seems like after removing that module the mirror hasn’t crashed again. It has been steady since around 23:00 last night. I will monitor today and see what it does.
                  @Bugsounet Ok, so mirror is still crashing. [0_1594471563735_log3.txt](Uploading 100%)
                  This is from the npm log: Not sure if it is electron related or not. I have also attached the npm log which I piped to file when running
                  npm start
                  8 verbose lifecycle magicmirror@2.12.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/hom$
                  21 error errno 1
                    mumblebaj Module Developer @mumblebaj
                    Seems like one can’t upload text files. So here is the log:
                    [2020-07-11 14:38:29.082] [LOG]    Starting MagicMirror: v2.12.0
                    [2020-07-11 14:38:29.107] [LOG]    Loading config ...
                    [2020-07-11 14:38:29.126] [LOG]    Loading module helpers ...
                    [2020-07-11 14:38:29.134] [LOG]    No helper found for module: alert.
                    [2020-07-11 14:38:29.327] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:29.336] [LOG]    Module helper loaded: updatenotification
                    [2020-07-11 14:38:29.339] [LOG]    No helper found for module: clock.
                    [2020-07-11 14:38:29.375] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:29.377] [LOG]    Module helper loaded: MMM-Admin-Interface
                    [2020-07-11 14:38:30.746] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:30.747] [LOG]    Module helper loaded: MMM-COVID19
                    [2020-07-11 14:38:30.893] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:30.895] [LOG]    Module helper loaded: MMM-OpeningHours
                    [2020-07-11 14:38:30.897] [LOG]    No helper found for module: MMM-QRCode.
                    [2020-07-11 14:38:30.899] [LOG]    No helper found for module: MMM-pages.
                    [2020-07-11 14:38:30.901] [LOG]    No helper found for module: MMM-page-indicator.
                    [2020-07-11 14:38:31.040] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:31.042] [LOG]    Module helper loaded: MMM-NetworkScanner
                    [2020-07-11 14:38:31.322] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:31.325] [LOG]    Module helper loaded: calendar
                    [2020-07-11 14:38:31.327] [LOG]    No helper found for module: compliments.
                    [2020-07-11 14:38:31.452] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:31.454] [LOG]    Module helper loaded: newsfeed
                    [2020-07-11 14:38:31.456] [LOG]    No helper found for module: MMM-Hue.
                    [2020-07-11 14:38:31.520] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:31.522] [LOG]    Module helper loaded: MMM-RandomQuranAyah
                    [2020-07-11 14:38:31.728] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:31.730] [LOG]    Module helper loaded: MMM-Remote-Control
                    [2020-07-11 14:38:31.805] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:31.807] [LOG]    Module helper loaded: MMM-SystemStats
                    [2020-07-11 14:38:31.816] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:31.817] [LOG]    Module helper loaded: MMM-WatchDog
                    [2020-07-11 14:38:33.536] [LOG]    Initializing new module helper ...
                    [2020-07-11 14:38:33.538] [LOG]    Module helper loaded: MMM-NOAA3
                    [2020-07-11 14:38:33.539] [LOG]    All module helpers loaded.
                    [2020-07-11 14:38:34.140] [LOG]    Starting server on port 8080 ...
                    [2020-07-11 14:38:34.180] [LOG]    Server started ...
                    [2020-07-11 14:38:34.182] [LOG]    Connecting socket for: updatenotification
                    [2020-07-11 14:38:34.184] [LOG]    Connecting socket for: MMM-Admin-Interface
                    [2020-07-11 14:38:34.186] [LOG]    Starting node helper for: MMM-Admin-Interface
                    [2020-07-11 14:38:34.540] [LOG]    Connecting socket for: MMM-COVID19
                    [2020-07-11 14:38:34.548] [LOG]    Starting node helper for: MMM-COVID19
                    [2020-07-11 14:38:34.550] [LOG]    Connecting socket for: MMM-OpeningHours
                    [2020-07-11 14:38:34.755] [LOG]    [14:38:34] - MMM-OpeningHours : Starting helper:  MMM-OpeningHours
                    [2020-07-11 14:38:34.759] [LOG]    Connecting socket for: MMM-NetworkScanner
                    [2020-07-11 14:38:34.761] [LOG]    Starting module: MMM-NetworkScanner
                    [2020-07-11 14:38:34.763] [LOG]    Connecting socket for: calendar
                    [2020-07-11 14:38:34.765] [LOG]    Starting node helper for: calendar
                    [2020-07-11 14:38:34.767] [LOG]    Connecting socket for: newsfeed
                    [2020-07-11 14:38:34.768] [LOG]    Starting node helper for: newsfeed
                    [2020-07-11 14:38:34.770] [LOG]    Connecting socket for: MMM-RandomQuranAyah
                    [2020-07-11 14:38:34.771] [LOG]    Starting node_helper.js for MMM-RandomQuranAyah.
                    [2020-07-11 14:38:34.773] [LOG]    Connecting socket for: MMM-Remote-Control
                    [2020-07-11 14:38:34.775] [LOG]    Starting node helper for: MMM-Remote-Control
                    [2020-07-11 14:38:34.803] [LOG]    Connecting socket for: MMM-SystemStats
                    [2020-07-11 14:38:34.806] [LOG]    Connecting socket for: MMM-WatchDog
                    [2020-07-11 14:38:34.808] [LOG]    Starting module helper: MMM-WatchDog
                    [2020-07-11 14:38:34.809] [LOG]    Connecting socket for: MMM-NOAA3
                    [2020-07-11 14:38:34.816] [LOG]    Sockets connected & modules started ...
                    [2020-07-11 14:38:35.278] [LOG]    Launching application.
                    [2020-07-11 14:38:55.482] [LOG]    [14:38:55] - DEBUG - MMM-OpeningHours : Notification - SETUP
                    [2020-07-11 14:38:55.485] [LOG]    [14:38:55] - DEBUG - MMM-OpeningHours : Started - false
                    [2020-07-11 14:38:55.487] [LOG]    [14:38:55] - DEBUG - MMM-OpeningHours : Config -  {
                      googleApiKey: 'MY-API-KEY',
                      places: [
                        'ChIJl8h2VlIJlR4Rn5311bQlcXQ',
                        'ChIJB0lb_mgPlR4Rje4UAMJnOvY',
                        'ChIJZwMQpQGglR4RLpdkGUhNZTE',
                        'ChIJ-cM-E1kJlR4R_roOyHfbmaI',
                        'ChIJe-_APDkJlR4Rux6UduHCpvg'
                      scheduleTime: 14400000,
                      timeFormat: 24,
                      language: 'en',
                      styling: { showTimeUntil: true, textAlign: 'center', size: 'xsmall' },
                      debug: 'false',
                      mockData: false
                    [2020-07-11 14:38:55.715] [LOG]    [14:38:55] - MMM-OpeningHours : Fetching opening hours
                    [2020-07-11 14:38:55.721] [LOG]    [14:38:55] - MMM-OpeningHours : Using Google Places API.
                    [2020-07-11 14:38:55.751] [LOG]    [14:38:55] - DEBUG - MMM-OpeningHours : googlePromise -  Promise { <pending> }
                    [2020-07-11 14:38:55.756] [LOG]    [14:38:55] - MMM-OpeningHours : Using Google Places API.
                    [2020-07-11 14:38:55.764] [LOG]    [14:38:55] - DEBUG - MMM-OpeningHours : googlePromise -  Promise { <pending> }
                    [2020-07-11 14:38:55.766] [LOG]    [14:38:55] - MMM-OpeningHours : Using Google Places API.
                    [2020-07-11 14:38:55.770] [LOG]    [14:38:55] - DEBUG - MMM-OpeningHours : googlePromise -  Promise { <pending> }
                    [2020-07-11 14:38:55.774] [LOG]    [14:38:55] - MMM-OpeningHours : Using Google Places API.
                    [2020-07-11 14:38:55.777] [LOG]    [14:38:55] - DEBUG - MMM-OpeningHours : googlePromise -  Promise { <pending> }
                    [2020-07-11 14:38:55.778] [LOG]    [14:38:55] - MMM-OpeningHours : Using Google Places API.
                    [2020-07-11 14:38:55.780] [LOG]    [14:38:55] - DEBUG - MMM-OpeningHours : googlePromise -  Promise { <pending> }
                    [2020-07-11 14:38:55.782] [LOG]    MMM-NetworkScanner received CONFIG
                    [2020-07-11 14:38:55.947] [LOG]    Create new calendar fetcher for url: https://www.officeholidays.com/ics/ics_country_iso.php?tbl_country=ZA - Interval: 14400000
                    [2020-07-11 14:38:55.966] [LOG]    Create new news fetcher for url: http://feeds.news24.com/articles/news24/SouthAfrica/rss - Interval: 300000
                    [2020-07-11 14:38:56.122] [LOG]    MMM-RandomQuranAyah node helper received a socket notification: START_QURAN - Payload: [object Object]
                    [2020-07-11 14:38:56.632] [LOG]    WatchDog started. Maximum timeout: 10s.
                    [2020-07-11 14:38:56.651] [LOG]    wb
                    [2020-07-11 14:38:56.733] [LOG]    1594471136
                    [2020-07-11 14:38:56.783] [INFO]   Checking git for module: MMM-Admin-Interface
                    [2020-07-11 14:38:56.874] [INFO]   Checking git for module: MMM-COVID19
                    [2020-07-11 14:38:56.958] [INFO]   Checking git for module: MMM-OpeningHours
                    [2020-07-11 14:38:57.072] [INFO]   Checking git for module: MMM-QRCode
                    [2020-07-11 14:38:57.144] [INFO]   Checking git for module: MMM-pages
                    [2020-07-11 14:38:57.205] [INFO]   Checking git for module: MMM-page-indicator
                    [2020-07-11 14:38:57.267] [INFO]   Checking git for module: MMM-NetworkScanner
                    [2020-07-11 14:38:57.358] [INFO]   Checking git for module: MMM-Hue
                    [2020-07-11 14:38:57.443] [INFO]   Checking git for module: MMM-RandomQuranAyah
                    [2020-07-11 14:38:57.531] [INFO]   Checking git for module: MMM-Remote-Control
                    [2020-07-11 14:38:57.607] [INFO]   Checking git for module: MMM-SystemStats
                    [2020-07-11 14:38:57.680] [INFO]   Checking git for module: MMM-WatchDog
                    [2020-07-11 14:38:57.751] [INFO]   Checking git for module: MMM-NOAA3
                    [2020-07-11 14:39:02.458] [LOG]    [14:39:02] - DEBUG - MMM-OpeningHours : Response -  {"status":200,"headers":{"content-type":"application/json; charset=UTF-8","date":"Sat, 11 Jul 2020 12:35:26 GMT","expires":"Sat, 11 Jul 2020 12:40:26 GMT","server":"scaffolding on HTTPServer2","x-xss-protection":"0","x-frame-options":"SAMEORIGIN","server-timing":"gfet4t7; dur=287","cache-control":"public, max-age=300","age":"215","alt-svc":"h3-29=\":443\"; ma=2592000,h3-27=\":443\"; ma=2592000,h3-25=\":443\"; ma=2592000,h3-T050=\":443\"; ma=2592000,h3-Q050=\":443\"; ma=2592000,h3-Q046=\":443\"; ma=2592000,h3-Q043=\":443\"; ma=2592000,quic=\":443\"; ma=2592000; v=\"46,43\"","accept-ranges":"none","vary":"Accept-Encoding","connection":"close","transfer-encoding":"chunked"},"json":{"html_attributions":[],"result":{"name":"Makro Store Crown Mines","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"1400"},"open":{"day":0,"time":"0900"}},{"close":{"day":1,"time":"1730"},"open":{"day":1,"time":"0830"}},{"close":{"day":2,"time":"1730"},"open":{"day":2,"time":"0830"}},{"close":{"day":3,"time":"1730"},"open":{"day":3,"time":"0830"}},{"close":{"day":4,"time":"1730"},"open":{"day":4,"time":"0830"}},{"close":{"day":5,"time":"1730"},"open":{"day":5,"time":"0830"}},{"close":{"day":6,"time":"1600"},"open":{"day":6,"time":"0800"}}],"weekday_text":["Monday: 8:30 AM – 5:30 PM","Tuesday: 8:30 AM – 5:30 PM","Wednesday: 8:30 AM – 5:30 PM","Thursday: 8:30 AM – 5:30 PM","Friday: 8:30 AM – 5:30 PM","Saturday: 8:00 AM – 4:00 PM","Sunday: 9:00 AM – 2:00 PM"]},"place_id":"ChIJl8h2VlIJlR4Rn5311bQlcXQ"},"status":"OK"},"requestUrl":"https://maps.googleapis.com/maps/api/place/details/json?fields=name%2Copening_hours%2Cplace_id&language=en&placeid=ChIJl8h2VlIJlR4Rn5311bQlcXQ&key=MY-API-KEY","query":{"fields":"name,opening_hours,place_id","language":"en","placeid":"ChIJl8h2VlIJlR4Rn5311bQlcXQ","key":"MY-API-KEY"}}
                    [2020-07-11 14:39:02.513] [LOG]    [14:39:02] - DEBUG - MMM-OpeningHours : Response -  {"status":200,"headers":{"content-type":"application/json; charset=UTF-8","date":"Sat, 11 Jul 2020 12:35:20 GMT","expires":"Sat, 11 Jul 2020 12:40:20 GMT","server":"scaffolding on HTTPServer2","x-xss-protection":"0","x-frame-options":"SAMEORIGIN","server-timing":"gfet4t7; dur=190","cache-control":"public, max-age=300","age":"221","alt-svc":"h3-29=\":443\"; ma=2592000,h3-27=\":443\"; ma=2592000,h3-25=\":443\"; ma=2592000,h3-T050=\":443\"; ma=2592000,h3-Q050=\":443\"; ma=2592000,h3-Q046=\":443\"; ma=2592000,h3-Q043=\":443\"; ma=2592000,quic=\":443\"; ma=2592000; v=\"46,43\"","accept-ranges":"none","vary":"Accept-Encoding","connection":"close","transfer-encoding":"chunked"},"json":{"html_attributions":[],"result":{"name":"Builders Warehouse Glen Eagles","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"1600"},"open":{"day":0,"time":"0800"}},{"close":{"day":1,"time":"1700"},"open":{"day":1,"time":"0700"}},{"close":{"day":2,"time":"1700"},"open":{"day":2,"time":"0700"}},{"close":{"day":3,"time":"1700"},"open":{"day":3,"time":"0700"}},{"close":{"day":4,"time":"1700"},"open":{"day":4,"time":"0700"}},{"close":{"day":5,"time":"1700"},"open":{"day":5,"time":"0700"}},{"close":{"day":6,"time":"1700"},"open":{"day":6,"time":"0700"}}],"weekday_text":["Monday: 7:00 AM – 5:00 PM","Tuesday: 7:00 AM – 5:00 PM","Wednesday: 7:00 AM – 5:00 PM","Thursday: 7:00 AM – 5:00 PM","Friday: 7:00 AM – 5:00 PM","Saturday: 7:00 AM – 5:00 PM","Sunday: 8:00 AM – 4:00 PM"]},"place_id":"ChIJB0lb_mgPlR4Rje4UAMJnOvY"},"status":"OK"},"requestUrl":"https://maps.googleapis.com/maps/api/place/details/json?fields=name%2Copening_hours%2Cplace_id&language=en&placeid=ChIJB0lb_mgPlR4Rje4UAMJnOvY&key=MY-API-KEY","query":{"fields":"name,opening_hours,place_id","language":"en","placeid":"ChIJB0lb_mgPlR4Rje4UAMJnOvY","key":"MY-API-KEY"}}
                    [2020-07-11 14:39:02.555] [LOG]    [14:39:02] - DEBUG - MMM-OpeningHours : Response -  {"status":200,"headers":{"content-type":"application/json; charset=UTF-8","date":"Sat, 11 Jul 2020 12:35:21 GMT","expires":"Sat, 11 Jul 2020 12:40:21 GMT","server":"scaffolding on HTTPServer2","x-xss-protection":"0","x-frame-options":"SAMEORIGIN","server-timing":"gfet4t7; dur=224","cache-control":"public, max-age=300","age":"221","alt-svc":"h3-29=\":443\"; ma=2592000,h3-27=\":443\"; ma=2592000,h3-25=\":443\"; ma=2592000,h3-T050=\":443\"; ma=2592000,h3-Q050=\":443\"; ma=2592000,h3-Q046=\":443\"; ma=2592000,h3-Q043=\":443\"; ma=2592000,quic=\":443\"; ma=2592000; v=\"46,43\"","accept-ranges":"none","vary":"Accept-Encoding","connection":"close","transfer-encoding":"chunked"},"json":{"html_attributions":[],"result":{"name":"Food Lover's Market Hillfox","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"1700"},"open":{"day":0,"time":"0800"}},{"close":{"day":1,"time":"1800"},"open":{"day":1,"time":"0900"}},{"close":{"day":2,"time":"1800"},"open":{"day":2,"time":"0800"}},{"close":{"day":3,"time":"1800"},"open":{"day":3,"time":"0800"}},{"close":{"day":4,"time":"1800"},"open":{"day":4,"time":"0800"}},{"close":{"day":5,"time":"1800"},"open":{"day":5,"time":"0800"}},{"close":{"day":6,"time":"1800"},"open":{"day":6,"time":"0800"}}],"weekday_text":["Monday: 9:00 AM – 6:00 PM","Tuesday: 8:00 AM – 6:00 PM","Wednesday: 8:00 AM – 6:00 PM","Thursday: 8:00 AM – 6:00 PM","Friday: 8:00 AM – 6:00 PM","Saturday: 8:00 AM – 6:00 PM","Sunday: 8:00 AM – 5:00 PM"]},"place_id":"ChIJZwMQpQGglR4RLpdkGUhNZTE"},"status":"OK"},"requestUrl":"https://maps.googleapis.com/maps/api/place/details/json?fields=name%2Copening_hours%2Cplace_id&language=en&placeid=ChIJZwMQpQGglR4RLpdkGUhNZTE&key=MY-API-KEY","query":{"fields":"name,opening_hours,place_id","language":"en","placeid":"ChIJZwMQpQGglR4RLpdkGUhNZTE","key":"MY-API-KEY"}}
                    [2020-07-11 14:39:02.609] [LOG]    [14:39:02] - DEBUG - MMM-OpeningHours : Response -  {"status":200,"headers":{"content-type":"application/json; charset=UTF-8","date":"Sat, 11 Jul 2020 12:35:20 GMT","expires":"Sat, 11 Jul 2020 12:40:20 GMT","server":"scaffolding on HTTPServer2","x-xss-protection":"0","x-frame-options":"SAMEORIGIN","server-timing":"gfet4t7; dur=159","cache-control":"public, max-age=300","age":"222","alt-svc":"h3-29=\":443\"; ma=2592000,h3-27=\":443\"; ma=2592000,h3-25=\":443\"; ma=2592000,h3-T050=\":443\"; ma=2592000,h3-Q050=\":443\"; ma=2592000,h3-Q046=\":443\"; ma=2592000,h3-Q043=\":443\"; ma=2592000,quic=\":443\"; ma=2592000; v=\"46,43\"","accept-ranges":"none","vary":"Accept-Encoding","connection":"close","transfer-encoding":"chunked"},"json":{"html_attributions":[],"result":{"name":"SUPERSPAR Xavier","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"2000"},"open":{"day":0,"time":"0800"}},{"close":{"day":1,"time":"2000"},"open":{"day":1,"time":"0700"}},{"close":{"day":2,"time":"2000"},"open":{"day":2,"time":"0700"}},{"close":{"day":3,"time":"2000"},"open":{"day":3,"time":"0700"}},{"close":{"day":4,"time":"2000"},"open":{"day":4,"time":"0700"}},{"close":{"day":5,"time":"2000"},"open":{"day":5,"time":"0700"}},{"close":{"day":6,"time":"2000"},"open":{"day":6,"time":"0800"}}],"weekday_text":["Monday: 7:00 AM – 8:00 PM","Tuesday: 7:00 AM – 8:00 PM","Wednesday: 7:00 AM – 8:00 PM","Thursday: 7:00 AM – 8:00 PM","Friday: 7:00 AM – 8:00 PM","Saturday: 8:00 AM – 8:00 PM","Sunday: 8:00 AM – 8:00 PM"]},"place_id":"ChIJ-cM-E1kJlR4R_roOyHfbmaI"},"status":"OK"},"requestUrl":"https://maps.googleapis.com/maps/api/place/details/json?fields=name%2Copening_hours%2Cplace_id&language=en&placeid=ChIJ-cM-E1kJlR4R_roOyHfbmaI&key=MY-API-KEY","query":{"fields":"name,opening_hours,place_id","language":"en","placeid":"ChIJ-cM-E1kJlR4R_roOyHfbmaI","key":"MY-API-KEY"}}
                    [2020-07-11 14:39:04.032] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
                    [2020-07-11 14:39:04.436] [LOG]    /nodehelper/get arabic with statuscode-200
                    [2020-07-11 14:39:04.457] [LOG]    /nodehelper/get translation with statuscode-200
                    [2020-07-11 14:39:04.470] [LOG]    /nodehelper/result-Al-Qalam:31
                    [2020-07-11 14:39:05.420] [LOG]    [14:39:05] - DEBUG - MMM-OpeningHours : Response -  {"status":200,"headers":{"content-type":"application/json; charset=UTF-8","date":"Sat, 11 Jul 2020 12:35:25 GMT","expires":"Sat, 11 Jul 2020 12:40:25 GMT","server":"scaffolding on HTTPServer2","x-xss-protection":"0","x-frame-options":"SAMEORIGIN","server-timing":"gfet4t7; dur=125","cache-control":"public, max-age=300","age":"219","alt-svc":"h3-29=\":443\"; ma=2592000,h3-27=\":443\"; ma=2592000,h3-25=\":443\"; ma=2592000,h3-T050=\":443\"; ma=2592000,h3-Q050=\":443\"; ma=2592000,h3-Q046=\":443\"; ma=2592000,h3-Q043=\":443\"; ma=2592000,quic=\":443\"; ma=2592000; v=\"46,43\"","accept-ranges":"none","vary":"Accept-Encoding","connection":"close","transfer-encoding":"chunked"},"json":{"html_attributions":[],"result":{"name":"Mochachos Ormonde","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"2100"},"open":{"day":0,"time":"1000"}},{"close":{"day":1,"time":"2100"},"open":{"day":1,"time":"1000"}},{"close":{"day":2,"time":"2100"},"open":{"day":2,"time":"1000"}},{"close":{"day":3,"time":"2100"},"open":{"day":3,"time":"1000"}},{"close":{"day":4,"time":"2100"},"open":{"day":4,"time":"1000"}},{"close":{"day":5,"time":"2200"},"open":{"day":5,"time":"1000"}},{"close":{"day":6,"time":"2200"},"open":{"day":6,"time":"1000"}}],"weekday_text":["Monday: 10:00 AM – 9:00 PM","Tuesday: 10:00 AM – 9:00 PM","Wednesday: 10:00 AM – 9:00 PM","Thursday: 10:00 AM – 9:00 PM","Friday: 10:00 AM – 10:00 PM","Saturday: 10:00 AM – 10:00 PM","Sunday: 10:00 AM – 9:00 PM"]},"place_id":"ChIJe-_APDkJlR4Rux6UduHCpvg"},"status":"OK"},"requestUrl":"https://maps.googleapis.com/maps/api/place/details/json?fields=name%2Copening_hours%2Cplace_id&language=en&placeid=ChIJe-_APDkJlR4Rux6UduHCpvg&key=MY-API-KEY","query":{"fields":"name,opening_hours,place_id","language":"en","placeid":"ChIJe-_APDkJlR4Rux6UduHCpvg","key":"MY-API-KEY"}}
                    [2020-07-11 14:39:05.432] [LOG]    [14:39:05] - DEBUG - MMM-OpeningHours : Sending to frontend -  [{"name":"Makro Store Crown Mines","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"1400"},"open":{"day":0,"time":"0900"}},{"close":{"day":1,"time":"1730"},"open":{"day":1,"time":"0830"}},{"close":{"day":2,"time":"1730"},"open":{"day":2,"time":"0830"}},{"close":{"day":3,"time":"1730"},"open":{"day":3,"time":"0830"}},{"close":{"day":4,"time":"1730"},"open":{"day":4,"time":"0830"}},{"close":{"day":5,"time":"1730"},"open":{"day":5,"time":"0830"}},{"close":{"day":6,"time":"1600"},"open":{"day":6,"time":"0800"}}],"weekday_text":["Monday: 8:30 AM – 5:30 PM","Tuesday: 8:30 AM – 5:30 PM","Wednesday: 8:30 AM – 5:30 PM","Thursday: 8:30 AM – 5:30 PM","Friday: 8:30 AM – 5:30 PM","Saturday: 8:00 AM – 4:00 PM","Sunday: 9:00 AM – 2:00 PM"]},"place_id":"ChIJl8h2VlIJlR4Rn5311bQlcXQ"},{"name":"Builders Warehouse Glen Eagles","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"1600"},"open":{"day":0,"time":"0800"}},{"close":{"day":1,"time":"1700"},"open":{"day":1,"time":"0700"}},{"close":{"day":2,"time":"1700"},"open":{"day":2,"time":"0700"}},{"close":{"day":3,"time":"1700"},"open":{"day":3,"time":"0700"}},{"close":{"day":4,"time":"1700"},"open":{"day":4,"time":"0700"}},{"close":{"day":5,"time":"1700"},"open":{"day":5,"time":"0700"}},{"close":{"day":6,"time":"1700"},"open":{"day":6,"time":"0700"}}],"weekday_text":["Monday: 7:00 AM – 5:00 PM","Tuesday: 7:00 AM – 5:00 PM","Wednesday: 7:00 AM – 5:00 PM","Thursday: 7:00 AM – 5:00 PM","Friday: 7:00 AM – 5:00 PM","Saturday: 7:00 AM – 5:00 PM","Sunday: 8:00 AM – 4:00 PM"]},"place_id":"ChIJB0lb_mgPlR4Rje4UAMJnOvY"},{"name":"Food Lover's Market Hillfox","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"1700"},"open":{"day":0,"time":"0800"}},{"close":{"day":1,"time":"1800"},"open":{"day":1,"time":"0900"}},{"close":{"day":2,"time":"1800"},"open":{"day":2,"time":"0800"}},{"close":{"day":3,"time":"1800"},"open":{"day":3,"time":"0800"}},{"close":{"day":4,"time":"1800"},"open":{"day":4,"time":"0800"}},{"close":{"day":5,"time":"1800"},"open":{"day":5,"time":"0800"}},{"close":{"day":6,"time":"1800"},"open":{"day":6,"time":"0800"}}],"weekday_text":["Monday: 9:00 AM – 6:00 PM","Tuesday: 8:00 AM – 6:00 PM","Wednesday: 8:00 AM – 6:00 PM","Thursday: 8:00 AM – 6:00 PM","Friday: 8:00 AM – 6:00 PM","Saturday: 8:00 AM – 6:00 PM","Sunday: 8:00 AM – 5:00 PM"]},"place_id":"ChIJZwMQpQGglR4RLpdkGUhNZTE"},{"name":"SUPERSPAR Xavier","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"2000"},"open":{"day":0,"time":"0800"}},{"close":{"day":1,"time":"2000"},"open":{"day":1,"time":"0700"}},{"close":{"day":2,"time":"2000"},"open":{"day":2,"time":"0700"}},{"close":{"day":3,"time":"2000"},"open":{"day":3,"time":"0700"}},{"close":{"day":4,"time":"2000"},"open":{"day":4,"time":"0700"}},{"close":{"day":5,"time":"2000"},"open":{"day":5,"time":"0700"}},{"close":{"day":6,"time":"2000"},"open":{"day":6,"time":"0800"}}],"weekday_text":["Monday: 7:00 AM – 8:00 PM","Tuesday: 7:00 AM – 8:00 PM","Wednesday: 7:00 AM – 8:00 PM","Thursday: 7:00 AM – 8:00 PM","Friday: 7:00 AM – 8:00 PM","Saturday: 8:00 AM – 8:00 PM","Sunday: 8:00 AM – 8:00 PM"]},"place_id":"ChIJ-cM-E1kJlR4R_roOyHfbmaI"},{"name":"Mochachos Ormonde","opening_hours":{"open_now":true,"periods":[{"close":{"day":0,"time":"2100"},"open":{"day":0,"time":"1000"}},{"close":{"day":1,"time":"2100"},"open":{"day":1,"time":"1000"}},{"close":{"day":2,"time":"2100"},"open":{"day":2,"time":"1000"}},{"close":{"day":3,"time":"2100"},"open":{"day":3,"time":"1000"}},{"close":{"day":4,"time":"2100"},"open":{"day":4,"time":"1000"}},{"close":{"day":5,"time":"2200"},"open":{"day":5,"time":"1000"}},{"close":{"day":6,"time":"2200"},"open":{"day":6,"time":"1000"}}],"weekday_text":["Monday: 10:00 AM – 9:00 PM","Tuesday: 10:00 AM – 9:00 PM","Wednesday: 10:00 AM – 9:00 PM","Thursday: 10:00 AM – 9:00 PM","Friday: 10:00 AM – 10:00 PM","Saturday: 10:00 AM – 10:00 PM","Sunday: 10:00 AM – 9:00 PM"]},"place_id":"ChIJe-_APDkJlR4Rux6UduHCpvg"}]
                    [2020-07-11 14:39:07.365] [INFO]   Calendar-Fetcher: Broadcasting 14 events.
                    [2020-07-11 14:39:08.019] [ERROR]  Sat Jul 11 2020 14:39:08 GMT+0200 (South Africa Standard Time) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
                    npm ERR! errno 1
                    npm ERR!
                    npm ERR!     /home/pi/.npm/_logs/2020-07-11T12_39_08_390Z-debug.log
                      A Former User
                      @mumblebaj said in Mirror Crashing:
                      and it will stop MagicMirror app
                      I think it should be configured ;)
                        @Bugsounet Watchdog? How do I configure it?
                          A Former User
                          You have installed MMM-WatchDog, so read the manual of it to configure.
                          I can’t help for this, I don’t use it
