    MMM-GoogleAssistant not running
    55 Posts 5 Posters 24.0k Views 5 Watching
    • W
      wirdman
      this is my config.js
      		  module: "MMM-GoogleAssistant",
      		  position: "fullscreen_above",
      		    debug: false,
      		    assistantConfig: {
      		      lang: "en-US",
      		      projectId: "", // Required to use gaction.
      		      modelId: "", // (OPTIONAL for gaction)
      		      instanceId: "", // (OPTIONAL for gaction)
      		      latitude: 51.508530,
      		      longitude: -0.076132,
      		    responseConfig: {
      		      useScreenOutput: true,
      		      screenOutputCSS: "screen_output.css",
      		      screenOutputTimer: 5000,
      		      activateDelay: 250,
      		      useAudioOutput: true,
      		      useChime: true,
      		      newChime: false,
      		      useNative: true,
      		      playProgram: "mpg321"
      		    micConfig: { // put there configuration generated by auto-installer
      		      recorder: "arecord",
      		      device: "plughw:2",
      		    customActionConfig: {
      		      autoMakeAction: false,
      		      autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
      		      actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
      		    snowboy: {
      		      audioGain: 2.0,
      		      Frontend: true,
      		      Model: "jarvis",
      		      Sensitivity: null
      		    A2DServer: {
      		      useA2D: false,
      		      stopCommand: "stop"
      		    recipes: [ "with-MMM-TelegramBot.js" ]
      				  module:
        A Former User
        and why you edit snowboy sources ?
        • W
          wirdman
          i dont do
            sdetweil @wirdman
            @wirdman said in MMM-GoogleAssistant not running:
            [2020-07-14 16:59:18.380] [ERROR] /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:12
            DetectionResult[DetectionResu.ts",
            looks like sd card trouble ahead, make backup NOW… get new card
            • W
              wirdman
              really beceause without google assitant my magic mirror running
                sdetweil @wirdman
                @wirdman
                if you didn’t edit that file yourself, this looks like random file system corruption
                once it starts, it never gets better
                SD cards are write once, and then next write that old spaces cannot be reused, so it is marked used and dropped.
                eventually the card fills up… I have lost 8-10 cards so far over 3 years…
                • W
                  wirdman
                  i have that in my shelle when i try to run it
                  [2020-07-14 17:13:37.219] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:12
                  SyntaxError: Invalid or unexpected token
                      at Module._compile (internal/modules/cjs/loader.js:722:23)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                      at Module.load (internal/modules/cjs/loader.js:645:32)
                      at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                      at Module.require (internal/modules/cjs/loader.js:685:19)
                      at require (internal/modules/cjs/helpers.js:16:16)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js:6:18)
                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                  okay i going right now buy a new sd card and i try it again
                    A Former User
                    just for information : original is there
                    so if you don’t edit it
                    Your SD card have a problem
                    • W
                      wirdman
                      okay thanks a lot for you help i going buy a new card a i tell you if it’s working 😃
                      • W
                        wirdman
                        • W
                          wirdman
                          hey @Bugsounet and @sdetweil
                          i delete it re install it and now is since to work but is not on my mirror
                          here my npm start :
                          > magicmirror@2.12.0 start /home/pi/MagicMirror
                          [2020-07-15 01:23:28.851] [LOG]    Starting MagicMirror: v2.12.0
                          [2020-07-15 01:23:28.867] [LOG]    Loading config ...
                          [2020-07-15 01:23:28.876] [LOG]    Loading module helpers ...
                          [2020-07-15 01:23:28.882] [LOG]    No helper found for module: alert.
                          [2020-07-15 01:23:28.989] [LOG]    Initializing new module helper ...
                          [2020-07-15 01:23:28.991] [LOG]    Module helper loaded: updatenotification
                          [2020-07-15 01:23:28.993] [LOG]    No helper found for module: clock.
                          [2020-07-15 01:23:29.821] [LOG]    Initializing new module helper ...
                          [2020-07-15 01:23:29.823] [LOG]    Module helper loaded: calendar
                          [2020-07-15 01:23:29.824] [LOG]    No helper found for module: compliments.
                          [2020-07-15 01:23:29.826] [LOG]    No helper found for module: currentweather.
                          [2020-07-15 01:23:29.827] [LOG]    No helper found for module: weatherforecast.
                          [2020-07-15 01:23:33.352] [LOG]    Initializing new module helper ...
                          [2020-07-15 01:23:33.355] [LOG]    Module helper loaded: MMM-GoogleAssistant
                          [2020-07-15 01:23:33.358] [LOG]    No helper found for module: MMM-SwissCommute.
                          [2020-07-15 01:23:34.709] [LOG]    Initializing new module helper ...
                          [2020-07-15 01:23:34.711] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                          [2020-07-15 01:23:34.795] [LOG]    Initializing new module helper ...
                          [2020-07-15 01:23:34.798] [LOG]    Module helper loaded: newsfeed
                          [2020-07-15 01:23:34.799] [LOG]    All module helpers loaded.
                          [2020-07-15 01:23:35.213] [LOG]    Starting server on port 8080 ...
                          [2020-07-15 01:23:35.243] [INFO]   You're using a full whitelist configuration to allow for all IPs
                          [2020-07-15 01:23:35.267] [LOG]    Server started ...
                          [2020-07-15 01:23:35.269] [LOG]    Connecting socket for: updatenotification
                          [2020-07-15 01:23:35.273] [LOG]    Connecting socket for: calendar
                          [2020-07-15 01:23:35.276] [LOG]    Starting node helper for: calendar
                          [2020-07-15 01:23:35.278] [LOG]    Connecting socket for: MMM-GoogleAssistant
                          [2020-07-15 01:23:35.281] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                          [2020-07-15 01:23:35.284] [LOG]    Connecting socket for: newsfeed
                          [2020-07-15 01:23:35.288] [LOG]    Starting node helper for: newsfeed
                          [2020-07-15 01:23:35.290] [LOG]    Sockets connected & modules started ...
                          [2020-07-15 01:23:35.621] [LOG]    Launching application.
                          [2020-07-15 01:23:41.914] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics - Interval: 300000
                          [2020-07-15 01:23:42.376] [LOG]    Create new news fetcher for url: https://www.lemonde.fr/international/rss_full.xml - Interval: 300000
                          [2020-07-15 01:23:42.532] [INFO]   Checking git for module: MMM-GoogleAssistant
                          [2020-07-15 01:23:42.621] [INFO]   Checking git for module: MMM-SwissCommute
                          [2020-07-15 01:23:42.706] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
                          [2020-07-15 01:23:42.800] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.2.1
                          [2020-07-15 01:23:42.831] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                          [2020-07-15 01:23:42.835] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                          [2020-07-15 01:23:44.440] [LOG]    Refreshed access token because it has expired. Expired at: 01:23:42 now is: 01:23:44
                          [2020-07-15 01:23:44.509] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:44
                          [2020-07-15 01:23:45.202] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
                          [2020-07-15 01:23:45.224] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:45
                          [2020-07-15 01:23:47.028] [LOG]    [SNOWBOY] Model selected: jarvis
                          [2020-07-15 01:23:47.042] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
                          [2020-07-15 01:23:47.067] [LOG]    [ASSISTANT] RECIPE_LOADED: with-MMM-TelegramBot.js
                          [2020-07-15 01:23:47.073] [LOG]    [ASSISTANT] Use native program (mpg321) for audio response
                          [2020-07-15 01:23:47.078] [LOG]    [SOUND] mpg321 Initialized
                          [2020-07-15 01:23:47.083] [LOG]    [ASSISTANT] Google Assistant is initialized.
                          [2020-07-15 01:23:48.183] [INFO]   Calendar-Fetcher: Broadcasting 4 events.
                          here my confi.js
                          /* Magic Mirror Config Sample
                            * MIT Licensed.
                          var config = {
                                  port: 8080,
                                  ipWhitelist: [], // Set [] to allow all IP addresses.
                                  language: "fr",
                                  timeFormat: 24,
                                  units: "metric",
                                                  module: "alert",
                                                  module: "updatenotification",
                                                  position: "top_bar"
                                                  module: "clock",
                                                  position: "top_left"
                                                  header: "Calendrier",
        symbol: "calendar-check-o ",
        url: "https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics"
                                                  module: "compliments",
                                                  position: "lower_third"
                                                  module: "currentweather",
                                                          locationID: "2660646",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                          appid: "a159eb40caad1348cda97718adc69d6d"
                                                  module: "weatherforecast",
                                                  header: "Météo",
                                                  header: "Météo",
                                                          locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                          appid: ""
                              debug: false,
                              assistantConfig: {
                                lang: "en-US",
                              responseConfig: {
                                activateDelay: 250,
                                useChime: true,
                                newChime: false,
                                useNative: true,
                                device: "plughw:2",
                              snowboy: {
                                audioGain: 2.0,
                                Frontend: true,
                                Model: "jarvis",
                                Sensitivity: null
                              A2DServer: {
                                useA2D: false,
                                stopCommand: "stop"
                          		module: 'MMM-SwissCommute',
                          		position: 'top_left',
                          		header: 'En Louche',
                          			to: 'Lancy-Bachet', // Destination station
                          			maximumEntries: 4, // Max departures displayed
                          			minWalkingTime: 10 // Minimum time to get to the station
                          				  module: "MMM-NowPlayingOnSpotify",
                          					clientID: "622ad97f8ed24ad9aa3b81531aae033f",
                          					clientSecret: "418079ac53a848679c37ac9613485136",
                          					accessToken: "BQCWLLN5elD8_f9zR7q9947jqCacUYNQ-6RzF8W_R1vx89DVTwkZBjpa1AR89PNw-yLdFziPjg_-hth6WVTPgQvekE5YPnz5ywbBzY0V_TBEa2N1hyucipaXSrmtBx5e2VaFf_SGrjzIkIeeKQ",
                          					refreshToken: "AQA-F5RgN04XC8NP5oOymHEWY_HqW4EwzUCx28GBHfjtLiCf3ordxs55HDxSjy1NwDWJlxthmAVKCRwNUrN3sqDX51JDRVjHP6y6wDnwZ1gs2RJ2tLPwIxJM3SuAgXOAlOk"
                                                  module: "newsfeed",
                                                  position: "lower_third",
                                                          feeds: [
        title: "Le Monde, Paris",
        url: "https://www.lemonde.fr/international/rss_full.xml"
                                                          showSourceTitle: true,
                                                          showPublishDate: true
                            A Former User
                            module: “MMM-GoogleAssistant”,
                            position: “top_right”,
                            • why top_right and not fullscreen_above position ?
                            • why recipes: [ "with-MMM-TelegramBot.js" ] if you don’t use TelegramBot module ?
                            W 1 Reply Last reply
                            • W
                              wirdman @Guest
                              @Bugsounet
                              hello mon google assistant ne veux plus aller sur youtube depuis la mise à jour
                              et aussi je ne sais pas pourquoi pour MMM-Spotify j’ai une erreur a la commande
                              il ne veux pas me donner le token
                              cd ~/MagicMirror/modules/MMM-Spotify
                              node first_auth.js
                              erreur
                              pi@raspberrypi:~/MagicMirror/modules/MMM-Spotify $ node first_auth.js
                              internal/modules/cjs/loader.js:638
                                  throw err;
                              Error: Cannot find module './Spotify.js'
                                  at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                                  at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                                  at Module.require (internal/modules/cjs/loader.js:692:17)
                                  at require (internal/modules/cjs/helpers.js:25:18)
                                  at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:3:17)
                              merci d avance
                                A Former User
                                ah oui lol … désolé j’ai oublier de modifier le script avec la nouvelle librairie (bravo !)
                                Je vais corriger ça de suite !
                                pour A2D et GA, la commande de mise a jour est npm run update
                                a executer dans chaque repertoire (GA et A2D)
                                • W
                                  wirdman @Guest
                                  @Bugsounet
                                  aah je croyais avoir tout cassé 😁😁😁😁
                                    A Former User
                                    non personne est parfait !
                                    Laisse moi 10 min et c’est good ;)
                                      A Former User
                                      voila !
                                      git pull et go !
                                      (et peut etre: npm install… a voir)
                                        A Former User
                                        Tu va etre connu !!! ton nickname est sur le Readme ! ;)
                                          A Former User
                                          @wirdman : c’est good ?
                                          • W
                                            wirdman
                                            j ai essayé de voir un peut mais l’assistant fonctionne très bien mais il est incapable de lancer une video youtube ou de contrôler Spotify
                                            en revanche on peut caster sans problème
                                            Merci d’avance pour tout le travail que tu fais
                                            quand je lance une requete :
                                             transcription: { transcription: 'joue les beattles sur youtube', done: true },
                                              continue: false,
                                              volume: null,
                                              lastQuery: {
                                                type: 'MIC',
                                                key: null,
                                                lang: 'fr-FR',
                                                status: 'standby',
                                                chime: true
