    MMM-GoogleAssistant not running
    55 Posts 5 Posters 22.0k Views 5 Watching
    • W Offline
      wirdman
      really beceause without google assitant my magic mirror running
        sdetweil @wirdman
        @wirdman
        /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js
        DetectionResult[DetectionResu.ts",
        if you didn’t edit that file yourself, this looks like random file system corruption
        once it starts, it never gets better
        SD cards are write once, and then next write that old spaces cannot be reused, so it is marked used and dropped.
        eventually the card fills up… I have lost 8-10 cards so far over 3 years…
        • W Offline
          wirdman
          i have that in my shelle when i try to run it
          [2020-07-14 17:13:37.219] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:12
          SyntaxError: Invalid or unexpected token
              at Module._compile (internal/modules/cjs/loader.js:722:23)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
              at Module.load (internal/modules/cjs/loader.js:645:32)
              at Function.Module._load (internal/modules/cjs/loader.js:560:12)
              at Module.require (internal/modules/cjs/loader.js:685:19)
              at require (internal/modules/cjs/helpers.js:16:16)
              at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js:6:18)
              at Module._compile (internal/modules/cjs/loader.js:786:30)
          okay i going right now buy a new sd card and i try it again
            [[global:former-user]]
            just for information : original is there
            so if you don’t edit it
            Your SD card have a problem
            • W Offline
              wirdman
              okay thanks a lot for you help i going buy a new card a i tell you if it’s working 😃
              • W Offline
                wirdman
                • W Offline
                  wirdman
                  hey @Bugsounet and @sdetweil
                  i delete it re install it and now is since to work but is not on my mirror
                  here my npm start :
                  > magicmirror@2.12.0 start /home/pi/MagicMirror
                  [2020-07-15 01:23:28.851] [LOG]    Starting MagicMirror: v2.12.0
                  [2020-07-15 01:23:28.867] [LOG]    Loading config ...
                  [2020-07-15 01:23:28.876] [LOG]    Loading module helpers ...
                  [2020-07-15 01:23:28.882] [LOG]    No helper found for module: alert.
                  [2020-07-15 01:23:28.989] [LOG]    Initializing new module helper ...
                  [2020-07-15 01:23:28.991] [LOG]    Module helper loaded: updatenotification
                  [2020-07-15 01:23:28.993] [LOG]    No helper found for module: clock.
                  [2020-07-15 01:23:29.821] [LOG]    Initializing new module helper ...
                  [2020-07-15 01:23:29.823] [LOG]    Module helper loaded: calendar
                  [2020-07-15 01:23:29.824] [LOG]    No helper found for module: compliments.
                  [2020-07-15 01:23:29.826] [LOG]    No helper found for module: currentweather.
                  [2020-07-15 01:23:29.827] [LOG]    No helper found for module: weatherforecast.
                  [2020-07-15 01:23:33.352] [LOG]    Initializing new module helper ...
                  [2020-07-15 01:23:33.355] [LOG]    Module helper loaded: MMM-GoogleAssistant
                  [2020-07-15 01:23:33.358] [LOG]    No helper found for module: MMM-SwissCommute.
                  [2020-07-15 01:23:34.709] [LOG]    Initializing new module helper ...
                  [2020-07-15 01:23:34.711] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                  [2020-07-15 01:23:34.795] [LOG]    Initializing new module helper ...
                  [2020-07-15 01:23:34.798] [LOG]    Module helper loaded: newsfeed
                  [2020-07-15 01:23:34.799] [LOG]    All module helpers loaded.
                  [2020-07-15 01:23:35.213] [LOG]    Starting server on port 8080 ...
                  [2020-07-15 01:23:35.243] [INFO]   You're using a full whitelist configuration to allow for all IPs
                  [2020-07-15 01:23:35.267] [LOG]    Server started ...
                  [2020-07-15 01:23:35.269] [LOG]    Connecting socket for: updatenotification
                  [2020-07-15 01:23:35.273] [LOG]    Connecting socket for: calendar
                  [2020-07-15 01:23:35.276] [LOG]    Starting node helper for: calendar
                  [2020-07-15 01:23:35.278] [LOG]    Connecting socket for: MMM-GoogleAssistant
                  [2020-07-15 01:23:35.281] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                  [2020-07-15 01:23:35.284] [LOG]    Connecting socket for: newsfeed
                  [2020-07-15 01:23:35.288] [LOG]    Starting node helper for: newsfeed
                  [2020-07-15 01:23:35.290] [LOG]    Sockets connected & modules started ...
                  [2020-07-15 01:23:35.621] [LOG]    Launching application.
                  [2020-07-15 01:23:41.914] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics - Interval: 300000
                  [2020-07-15 01:23:42.376] [LOG]    Create new news fetcher for url: https://www.lemonde.fr/international/rss_full.xml - Interval: 300000
                  [2020-07-15 01:23:42.532] [INFO]   Checking git for module: MMM-GoogleAssistant
                  [2020-07-15 01:23:42.621] [INFO]   Checking git for module: MMM-SwissCommute
                  [2020-07-15 01:23:42.706] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
                  [2020-07-15 01:23:42.800] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.2.1
                  [2020-07-15 01:23:42.831] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  [2020-07-15 01:23:42.835] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                  [2020-07-15 01:23:44.440] [LOG]    Refreshed access token because it has expired. Expired at: 01:23:42 now is: 01:23:44
                  [2020-07-15 01:23:44.509] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:44
                  [2020-07-15 01:23:45.202] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
                  [2020-07-15 01:23:45.224] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:45
                  [2020-07-15 01:23:47.028] [LOG]    [SNOWBOY] Model selected: jarvis
                  [2020-07-15 01:23:47.042] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
                  [2020-07-15 01:23:47.067] [LOG]    [ASSISTANT] RECIPE_LOADED: with-MMM-TelegramBot.js
                  [2020-07-15 01:23:47.073] [LOG]    [ASSISTANT] Use native program (mpg321) for audio response
                  [2020-07-15 01:23:47.078] [LOG]    [SOUND] mpg321 Initialized
                  [2020-07-15 01:23:47.083] [LOG]    [ASSISTANT] Google Assistant is initialized.
                  [2020-07-15 01:23:48.183] [INFO]   Calendar-Fetcher: Broadcasting 4 events.
                  here my confi.js
                  /* Magic Mirror Config Sample
                    * MIT Licensed.
                  var config = {
                          port: 8080,
                          ipWhitelist: [], // Set [] to allow all IP addresses.
                          language: "fr",
                          timeFormat: 24,
                          units: "metric",
                                          module: "alert",
                                          module: "updatenotification",
                                          position: "top_bar"
                                          module: "clock",
                                          position: "top_left"
                                          header: "Calendrier",
        symbol: "calendar-check-o ",
        url: "https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics"
                                          module: "compliments",
                                          position: "lower_third"
                                          module: "currentweather",
                                                  locationID: "2660646",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                  appid: "a159eb40caad1348cda97718adc69d6d"
                                          module: "weatherforecast",
                                          header: "Météo",
                                          header: "Météo",
                                                  locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                  appid: ""
                    module: "MMM-GoogleAssistant",
                      debug: false,
                      assistantConfig: {
                        lang: "en-US",
                        projectId: "", // Required to use gaction.
                        modelId: "", // (OPTIONAL for gaction)
                        instanceId: "", // (OPTIONAL for gaction)
                        latitude: 51.508530,
                        longitude: -0.076132,
                      responseConfig: {
                        useScreenOutput: true,
                        screenOutputCSS: "screen_output.css",
                        screenOutputTimer: 5000,
                        activateDelay: 250,
                        useAudioOutput: true,
                        useChime: true,
                        newChime: false,
                        useNative: true,
                        playProgram: "mpg321"
                      micConfig: { // put there configuration generated by auto-installer
                        recorder: "arecord",
                        device: "plughw:2",
                      customActionConfig: {
                        autoMakeAction: false,
                        autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                        actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                      snowboy: {
                        audioGain: 2.0,
                        Frontend: true,
                        Model: "jarvis",
                        Sensitivity: null
                      A2DServer: {
                        useA2D: false,
                        stopCommand: "stop"
                      recipes: [ "with-MMM-TelegramBot.js" ]
                  		module: 'MMM-SwissCommute',
                  		position: 'top_left',
                  		header: 'En Louche',
                  			to: 'Lancy-Bachet', // Destination station
                  			maximumEntries: 4, // Max departures displayed
                  			minWalkingTime: 10 // Minimum time to get to the station
                  				  module: "MMM-NowPlayingOnSpotify",
                  					clientID: "622ad97f8ed24ad9aa3b81531aae033f",
                  					clientSecret: "418079ac53a848679c37ac9613485136",
                  					accessToken: "BQCWLLN5elD8_f9zR7q9947jqCacUYNQ-6RzF8W_R1vx89DVTwkZBjpa1AR89PNw-yLdFziPjg_-hth6WVTPgQvekE5YPnz5ywbBzY0V_TBEa2N1hyucipaXSrmtBx5e2VaFf_SGrjzIkIeeKQ",
                  					refreshToken: "AQA-F5RgN04XC8NP5oOymHEWY_HqW4EwzUCx28GBHfjtLiCf3ordxs55HDxSjy1NwDWJlxthmAVKCRwNUrN3sqDX51JDRVjHP6y6wDnwZ1gs2RJ2tLPwIxJM3SuAgXOAlOk"
                                          module: "newsfeed",
                                          position: "lower_third",
                                                  feeds: [
        title: "Le Monde, Paris",
        url: "https://www.lemonde.fr/international/rss_full.xml"
                                                  showSourceTitle: true,
                                                  showPublishDate: true
                    @wirdman said in MMM-GoogleAssistant not running:
                    module: “MMM-GoogleAssistant”,
                    position: “top_right”,
                    • why top_right and not fullscreen_above position ?
                    • why recipes: [ "with-MMM-TelegramBot.js" ] if you don’t use TelegramBot module ?
                    • W Offline
                      wirdman @Guest
                      @Bugsounet
                      hello mon google assistant ne veux plus aller sur youtube depuis la mise à jour
                      et aussi je ne sais pas pourquoi pour MMM-Spotify j’ai une erreur a la commande
                      il ne veux pas me donner le token
                      cd ~/MagicMirror/modules/MMM-Spotify
                      node first_auth.js
                      erreur
                      pi@raspberrypi:~/MagicMirror/modules/MMM-Spotify $ node first_auth.js
                      internal/modules/cjs/loader.js:638
                          throw err;
                      Error: Cannot find module './Spotify.js'
                          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                          at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                          at Module.require (internal/modules/cjs/loader.js:692:17)
                          at require (internal/modules/cjs/helpers.js:25:18)
                          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:3:17)
                      merci d avance
                        ah oui lol … désolé j’ai oublier de modifier le script avec la nouvelle librairie (bravo !)
                        Je vais corriger ça de suite !
                        pour A2D et GA, la commande de mise a jour est npm run update
                        a executer dans chaque repertoire (GA et A2D)
                        • W Offline
                          wirdman @Guest
                          @Bugsounet
                          aah je croyais avoir tout cassé 😁😁😁😁
                            non personne est parfait !
                            Laisse moi 10 min et c’est good ;)
                              voila !
                              git pull et go !
                              (et peut etre: npm install… a voir)
                                Tu va etre connu !!! ton nickname est sur le Readme ! ;)
                                  @wirdman : c’est good ?
                                  • W Offline
                                    wirdman
                                    j ai essayé de voir un peut mais l’assistant fonctionne très bien mais il est incapable de lancer une video youtube ou de contrôler Spotify
                                    en revanche on peut caster sans problème
                                    Merci d’avance pour tout le travail que tu fais
                                    quand je lance une requete :
                                     transcription: { transcription: 'joue les beattles sur youtube', done: true },
                                      continue: false,
                                      volume: null,
                                      lastQuery: {
                                        type: 'MIC',
                                        key: null,
                                        lang: 'fr-FR',
                                        status: 'standby',
                                        chime: true
                                    • W Offline
                                      wirdman @Guest
                                      @Bugsounet hahahaha incroyable pour le readme😁
                                      • blake_northrupB Offline
                                        blake_northrup
                                        This morning I noticed that my MMM-GoogleAssistant needed an update, so I updated the module, and now get the black electron screen instead of the Magic Mirror screen. If I removed the module from the config, the Mirror comes up correctly, but when I add my config back, it goes black again. I have tried everything, from removing, then reinstalling, npm rebuild, electron rebuild, and nada. Was working fine until then. Any help would be greatly appreciated. See errors below:
                                        [2020-07-17 13:07:48.310] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                                        Expected directory: electron-v6.1-linux-arm-glibc
                                        Found: [node-v72-linux-arm-glibc]
                                        This problem can often be fixed by running “npm rebuild” on the current system
                                        Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node’
                                        Require stack:
                                        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js
                                        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js
                                        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client.js
                                        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/index.js
                                        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/components/assistant.js
                                        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/index.js
                                        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/components/assistant.js
                                        • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
                                        [2020-07-17 13:07:48.311] [LOG] Loading module helpers …
                                        [2020-07-17 13:07:48.313] [LOG] No helper found for module: alert.
                                        [2020-07-17 13:07:48.314] [LOG] Initializing new module helper …
                                        [2020-07-17 13:07:48.314] [LOG] Module helper loaded: updatenotification
                                        [2020-07-17 13:07:48.315] [LOG] No helper found for module: clock.
                                        [2020-07-17 13:07:48.316] [LOG] Initializing new module helper …
                                        [2020-07-17 13:07:48.317] [LOG] Module helper loaded: calendar
                                        [2020-07-17 13:07:48.318] [LOG] No helper found for module: MMM-Rainbow.
                                        [2020-07-17 13:07:48.319] [LOG] No helper found for module: compliments.
                                        [2020-07-17 13:07:48.320] [LOG] Initializing new module helper …
                                        [2020-07-17 13:07:48.320] [LOG] Module helper loaded: MMM-SystemStats
                                        [2020-07-17 13:07:48.321] [LOG] Initializing new module helper …
                                        [2020-07-17 13:07:48.322] [LOG] Module helper loaded: MMM-Remote-Control
                                        [2020-07-17 13:07:48.323] [LOG] No helper found for module: currentweather.
                                        [2020-07-17 13:07:48.324] [LOG] No helper found for module: weatherforecast.
                                        [2020-07-17 13:07:48.325] [LOG] No helper found for module: MMM-EyeCandy.
                                        [2020-07-17 13:07:48.327] [LOG] Initializing new module helper …
                                        [2020-07-17 13:07:48.327] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
                                        [2020-07-17 13:07:48.352] [ERROR] App threw an error during load
                                        [2020-07-17 13:07:48.354] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
                                        Require stack:
                                        • at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js:53:17)
                                          at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                                          at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js:144:12)
                                          [2020-07-17 13:07:48.356] [ERROR] Whoops! There was an uncaught exception…
                                          [2020-07-17 13:07:48.357] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
                                          Require stack:
                                          at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10) {
                                          code: ‘MODULE_NOT_FOUND’
                                          [2020-07-17 13:07:48.371] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          [2020-07-17 13:07:48.372] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          [2020-07-17 13:07:48.539] [LOG] Launching application.
                                        • W Offline
                                          wirdman @blake_northrup
                                          @blake_northrup said in MMM-GoogleAssistant not running:
                                          do you have run
                                          npm run update
                                          in google assistant folder and Assistant2Display folder ?
                                          have it too but you can
                                          at you mmm-GoogleAssistant folder run
                                          npm install
                                          or
                                          npm rebuild
                                          blake_northrupB 1 Reply Last reply Reply Quote 1
                                            blake_northrup @wirdman
                                            @wirdman You are the man sir! Much appreciated wirdman!
