    MMM-GoogleAssistant not running
    55 Posts 5 Posters 18.9k Views 5 Watching
      A Former User
      and why you edit snowboy sources ?
      • W Offline
        wirdman
        i dont do
          sdetweil @wirdman
          @wirdman said in MMM-GoogleAssistant not running:
          [2020-07-14 16:59:18.380] [ERROR] /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:12
          DetectionResult[DetectionResu.ts",
          looks like sd card trouble ahead, make backup NOW… get new card
          • W Offline
            wirdman
            really beceause without google assitant my magic mirror running
              sdetweil @wirdman
              @wirdman
              if you didn’t edit that file yourself, this looks like random file system corruption
              once it starts, it never gets better
              SD cards are write once, and then next write that old spaces cannot be reused, so it is marked used and dropped.
              eventually the card fills up… I have lost 8-10 cards so far over 3 years…
              • W Offline
                wirdman
                i have that in my shelle when i try to run it
                [2020-07-14 17:13:37.219] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:12
                SyntaxError: Invalid or unexpected token
                    at Module._compile (internal/modules/cjs/loader.js:722:23)
                    at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                    at Module.load (internal/modules/cjs/loader.js:645:32)
                    at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                    at Module.require (internal/modules/cjs/loader.js:685:19)
                    at require (internal/modules/cjs/helpers.js:16:16)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js:6:18)
                    at Module._compile (internal/modules/cjs/loader.js:786:30)
                okay i going right now buy a new sd card and i try it again
                  A Former User
                  just for information : original is there
                  so if you don’t edit it
                  Your SD card have a problem
                  • W Offline
                    wirdman
                    okay thanks a lot for you help i going buy a new card a i tell you if it’s working 😃
                    • W Offline
                      wirdman
                      • W Offline
                        wirdman
                        hey @Bugsounet and @sdetweil
                        i delete it re install it and now is since to work but is not on my mirror
                        here my npm start :
                        > magicmirror@2.12.0 start /home/pi/MagicMirror
                        [2020-07-15 01:23:28.851] [LOG]    Starting MagicMirror: v2.12.0
                        [2020-07-15 01:23:28.867] [LOG]    Loading config ...
                        [2020-07-15 01:23:28.876] [LOG]    Loading module helpers ...
                        [2020-07-15 01:23:28.882] [LOG]    No helper found for module: alert.
                        [2020-07-15 01:23:28.989] [LOG]    Initializing new module helper ...
                        [2020-07-15 01:23:28.991] [LOG]    Module helper loaded: updatenotification
                        [2020-07-15 01:23:28.993] [LOG]    No helper found for module: clock.
                        [2020-07-15 01:23:29.821] [LOG]    Initializing new module helper ...
                        [2020-07-15 01:23:29.823] [LOG]    Module helper loaded: calendar
                        [2020-07-15 01:23:29.824] [LOG]    No helper found for module: compliments.
                        [2020-07-15 01:23:29.826] [LOG]    No helper found for module: currentweather.
                        [2020-07-15 01:23:29.827] [LOG]    No helper found for module: weatherforecast.
                        [2020-07-15 01:23:33.352] [LOG]    Initializing new module helper ...
                        [2020-07-15 01:23:33.355] [LOG]    Module helper loaded: MMM-GoogleAssistant
                        [2020-07-15 01:23:33.358] [LOG]    No helper found for module: MMM-SwissCommute.
                        [2020-07-15 01:23:34.709] [LOG]    Initializing new module helper ...
                        [2020-07-15 01:23:34.711] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                        [2020-07-15 01:23:34.795] [LOG]    Initializing new module helper ...
                        [2020-07-15 01:23:34.798] [LOG]    Module helper loaded: newsfeed
                        [2020-07-15 01:23:34.799] [LOG]    All module helpers loaded.
                        [2020-07-15 01:23:35.213] [LOG]    Starting server on port 8080 ...
                        [2020-07-15 01:23:35.243] [INFO]   You're using a full whitelist configuration to allow for all IPs
                        [2020-07-15 01:23:35.267] [LOG]    Server started ...
                        [2020-07-15 01:23:35.269] [LOG]    Connecting socket for: updatenotification
                        [2020-07-15 01:23:35.273] [LOG]    Connecting socket for: calendar
                        [2020-07-15 01:23:35.276] [LOG]    Starting node helper for: calendar
                        [2020-07-15 01:23:35.278] [LOG]    Connecting socket for: MMM-GoogleAssistant
                        [2020-07-15 01:23:35.281] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                        [2020-07-15 01:23:35.284] [LOG]    Connecting socket for: newsfeed
                        [2020-07-15 01:23:35.288] [LOG]    Starting node helper for: newsfeed
                        [2020-07-15 01:23:35.290] [LOG]    Sockets connected & modules started ...
                        [2020-07-15 01:23:35.621] [LOG]    Launching application.
                        [2020-07-15 01:23:41.914] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics - Interval: 300000
                        [2020-07-15 01:23:42.376] [LOG]    Create new news fetcher for url: https://www.lemonde.fr/international/rss_full.xml - Interval: 300000
                        [2020-07-15 01:23:42.532] [INFO]   Checking git for module: MMM-GoogleAssistant
                        [2020-07-15 01:23:42.621] [INFO]   Checking git for module: MMM-SwissCommute
                        [2020-07-15 01:23:42.706] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
                        [2020-07-15 01:23:42.800] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.2.1
                        [2020-07-15 01:23:42.831] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                        [2020-07-15 01:23:42.835] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                        [2020-07-15 01:23:44.440] [LOG]    Refreshed access token because it has expired. Expired at: 01:23:42 now is: 01:23:44
                        [2020-07-15 01:23:44.509] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:44
                        [2020-07-15 01:23:45.202] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
                        [2020-07-15 01:23:45.224] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:45
                        [2020-07-15 01:23:47.028] [LOG]    [SNOWBOY] Model selected: jarvis
                        [2020-07-15 01:23:47.042] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
                        [2020-07-15 01:23:47.067] [LOG]    [ASSISTANT] RECIPE_LOADED: with-MMM-TelegramBot.js
                        [2020-07-15 01:23:47.073] [LOG]    [ASSISTANT] Use native program (mpg321) for audio response
                        [2020-07-15 01:23:47.078] [LOG]    [SOUND] mpg321 Initialized
                        [2020-07-15 01:23:47.083] [LOG]    [ASSISTANT] Google Assistant is initialized.
                        [2020-07-15 01:23:48.183] [INFO]   Calendar-Fetcher: Broadcasting 4 events.
                        here my confi.js
                        /* Magic Mirror Config Sample
                          * MIT Licensed.
                        var config = {
                                port: 8080,
                                ipWhitelist: [], // Set [] to allow all IP addresses.
                                language: "fr",
                                timeFormat: 24,
                                units: "metric",
                                                module: "alert",
                                                module: "updatenotification",
                                                position: "top_bar"
                                                module: "clock",
                                                position: "top_left"
                                                header: "Calendrier",
        symbol: "calendar-check-o ",
        url: "https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics"
                                                module: "compliments",
                                                position: "lower_third"
                                                module: "currentweather",
                                                        locationID: "2660646",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                        appid: "a159eb40caad1348cda97718adc69d6d"
                                                module: "weatherforecast",
                                                header: "Météo",
                                                header: "Météo",
                                                        locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                        appid: ""
                          module: "MMM-GoogleAssistant",
                            debug: false,
                            assistantConfig: {
                              lang: "en-US",
                              projectId: "", // Required to use gaction.
                              modelId: "", // (OPTIONAL for gaction)
                              instanceId: "", // (OPTIONAL for gaction)
                              latitude: 51.508530,
                              longitude: -0.076132,
                            responseConfig: {
                              useScreenOutput: true,
                              screenOutputCSS: "screen_output.css",
                              screenOutputTimer: 5000,
                              activateDelay: 250,
                              useAudioOutput: true,
                              useChime: true,
                              newChime: false,
                              useNative: true,
                              playProgram: "mpg321"
                            micConfig: { // put there configuration generated by auto-installer
                              recorder: "arecord",
                              device: "plughw:2",
                            customActionConfig: {
                              autoMakeAction: false,
                              autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                              actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                            snowboy: {
                              audioGain: 2.0,
                              Frontend: true,
                              Model: "jarvis",
                              Sensitivity: null
                            A2DServer: {
                              useA2D: false,
                              stopCommand: "stop"
                            recipes: [ "with-MMM-TelegramBot.js" ]
                        		module: 'MMM-SwissCommute',
                        		position: 'top_left',
                        		header: 'En Louche',
                        			to: 'Lancy-Bachet', // Destination station
                        			maximumEntries: 4, // Max departures displayed
                        			minWalkingTime: 10 // Minimum time to get to the station
                        				  module: "MMM-NowPlayingOnSpotify",
                        					clientID: "622ad97f8ed24ad9aa3b81531aae033f",
                        					clientSecret: "418079ac53a848679c37ac9613485136",
                        					accessToken: "BQCWLLN5elD8_f9zR7q9947jqCacUYNQ-6RzF8W_R1vx89DVTwkZBjpa1AR89PNw-yLdFziPjg_-hth6WVTPgQvekE5YPnz5ywbBzY0V_TBEa2N1hyucipaXSrmtBx5e2VaFf_SGrjzIkIeeKQ",
                        					refreshToken: "AQA-F5RgN04XC8NP5oOymHEWY_HqW4EwzUCx28GBHfjtLiCf3ordxs55HDxSjy1NwDWJlxthmAVKCRwNUrN3sqDX51JDRVjHP6y6wDnwZ1gs2RJ2tLPwIxJM3SuAgXOAlOk"
                                                module: "newsfeed",
                                                position: "lower_third",
                                                        feeds: [
        title: "Le Monde, Paris",
        url: "https://www.lemonde.fr/international/rss_full.xml"
                                                        showSourceTitle: true,
                                                        showPublishDate: true
                        • 1 / 6
