    MMM-GoogleAssistant not running
    55 Posts 5 Posters 21.6k Views 5 Watching
      sdetweil @wirdman
      @wirdman said in MMM-GoogleAssistant not running:
      [2020-07-14 16:59:18.380] [ERROR] /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:12
      DetectionResult[DetectionResu.ts",
      looks like sd card trouble ahead, make backup NOW… get new card
      • W Offline
        wirdman
        really beceause without google assitant my magic mirror running
          sdetweil @wirdman
          @wirdman
          if you didn’t edit that file yourself, this looks like random file system corruption
          once it starts, it never gets better
          SD cards are write once, and then next write that old spaces cannot be reused, so it is marked used and dropped.
          eventually the card fills up… I have lost 8-10 cards so far over 3 years…
          • W Offline
            wirdman
            i have that in my shelle when i try to run it
            [2020-07-14 17:13:37.219] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/lib/node/index.js:12
            SyntaxError: Invalid or unexpected token
                at Module._compile (internal/modules/cjs/loader.js:722:23)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                at Module.load (internal/modules/cjs/loader.js:645:32)
                at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                at Module.require (internal/modules/cjs/loader.js:685:19)
                at require (internal/modules/cjs/helpers.js:16:16)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/index.js:6:18)
                at Module._compile (internal/modules/cjs/loader.js:786:30)
            okay i going right now buy a new sd card and i try it again
              [[global:former-user]]
              just for information : original is there
              so if you don’t edit it
              Your SD card have a problem
              • W Offline
                wirdman
                okay thanks a lot for you help i going buy a new card a i tell you if it’s working 😃
                • W Offline
                  wirdman
                  • W Offline
                    wirdman
                    hey @Bugsounet and @sdetweil
                    i delete it re install it and now is since to work but is not on my mirror
                    here my npm start :
                    > magicmirror@2.12.0 start /home/pi/MagicMirror
                    [2020-07-15 01:23:28.851] [LOG]    Starting MagicMirror: v2.12.0
                    [2020-07-15 01:23:28.867] [LOG]    Loading config ...
                    [2020-07-15 01:23:28.876] [LOG]    Loading module helpers ...
                    [2020-07-15 01:23:28.882] [LOG]    No helper found for module: alert.
                    [2020-07-15 01:23:28.989] [LOG]    Initializing new module helper ...
                    [2020-07-15 01:23:28.991] [LOG]    Module helper loaded: updatenotification
                    [2020-07-15 01:23:28.993] [LOG]    No helper found for module: clock.
                    [2020-07-15 01:23:29.821] [LOG]    Initializing new module helper ...
                    [2020-07-15 01:23:29.823] [LOG]    Module helper loaded: calendar
                    [2020-07-15 01:23:29.824] [LOG]    No helper found for module: compliments.
                    [2020-07-15 01:23:29.826] [LOG]    No helper found for module: currentweather.
                    [2020-07-15 01:23:29.827] [LOG]    No helper found for module: weatherforecast.
                    [2020-07-15 01:23:33.352] [LOG]    Initializing new module helper ...
                    [2020-07-15 01:23:33.355] [LOG]    Module helper loaded: MMM-GoogleAssistant
                    [2020-07-15 01:23:33.358] [LOG]    No helper found for module: MMM-SwissCommute.
                    [2020-07-15 01:23:34.709] [LOG]    Initializing new module helper ...
                    [2020-07-15 01:23:34.711] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
                    [2020-07-15 01:23:34.795] [LOG]    Initializing new module helper ...
                    [2020-07-15 01:23:34.798] [LOG]    Module helper loaded: newsfeed
                    [2020-07-15 01:23:34.799] [LOG]    All module helpers loaded.
                    [2020-07-15 01:23:35.213] [LOG]    Starting server on port 8080 ...
                    [2020-07-15 01:23:35.243] [INFO]   You're using a full whitelist configuration to allow for all IPs
                    [2020-07-15 01:23:35.267] [LOG]    Server started ...
                    [2020-07-15 01:23:35.269] [LOG]    Connecting socket for: updatenotification
                    [2020-07-15 01:23:35.273] [LOG]    Connecting socket for: calendar
                    [2020-07-15 01:23:35.276] [LOG]    Starting node helper for: calendar
                    [2020-07-15 01:23:35.278] [LOG]    Connecting socket for: MMM-GoogleAssistant
                    [2020-07-15 01:23:35.281] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
                    [2020-07-15 01:23:35.284] [LOG]    Connecting socket for: newsfeed
                    [2020-07-15 01:23:35.288] [LOG]    Starting node helper for: newsfeed
                    [2020-07-15 01:23:35.290] [LOG]    Sockets connected & modules started ...
                    [2020-07-15 01:23:35.621] [LOG]    Launching application.
                    [2020-07-15 01:23:41.914] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics - Interval: 300000
                    [2020-07-15 01:23:42.376] [LOG]    Create new news fetcher for url: https://www.lemonde.fr/international/rss_full.xml - Interval: 300000
                    [2020-07-15 01:23:42.532] [INFO]   Checking git for module: MMM-GoogleAssistant
                    [2020-07-15 01:23:42.621] [INFO]   Checking git for module: MMM-SwissCommute
                    [2020-07-15 01:23:42.706] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
                    [2020-07-15 01:23:42.800] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.2.1
                    [2020-07-15 01:23:42.831] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                    [2020-07-15 01:23:42.835] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                    [2020-07-15 01:23:44.440] [LOG]    Refreshed access token because it has expired. Expired at: 01:23:42 now is: 01:23:44
                    [2020-07-15 01:23:44.509] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:44
                    [2020-07-15 01:23:45.202] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
                    [2020-07-15 01:23:45.224] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:45
                    [2020-07-15 01:23:47.028] [LOG]    [SNOWBOY] Model selected: jarvis
                    [2020-07-15 01:23:47.042] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
                    [2020-07-15 01:23:47.067] [LOG]    [ASSISTANT] RECIPE_LOADED: with-MMM-TelegramBot.js
                    [2020-07-15 01:23:47.073] [LOG]    [ASSISTANT] Use native program (mpg321) for audio response
                    [2020-07-15 01:23:47.078] [LOG]    [SOUND] mpg321 Initialized
                    [2020-07-15 01:23:47.083] [LOG]    [ASSISTANT] Google Assistant is initialized.
                    [2020-07-15 01:23:48.183] [INFO]   Calendar-Fetcher: Broadcasting 4 events.
                    here my confi.js
                    /* Magic Mirror Config Sample
                      * MIT Licensed.
                    var config = {
                            port: 8080,
                            ipWhitelist: [], // Set [] to allow all IP addresses.
                            language: "fr",
                            timeFormat: 24,
                            units: "metric",
                                            module: "alert",
                                            module: "updatenotification",
                                            position: "top_bar"
                                            module: "clock",
                                            position: "top_left"
                                            header: "Calendrier",
        symbol: "calendar-check-o ",
        url: "https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics"
                                            module: "compliments",
                                            position: "lower_third"
                                            module: "currentweather",
                                                    locationID: "2660646",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                    appid: "a159eb40caad1348cda97718adc69d6d"
                                            module: "weatherforecast",
                                            header: "Météo",
                                            header: "Météo",
                                                    locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                                    appid: ""
                      module: "MMM-GoogleAssistant",
                        debug: false,
                        assistantConfig: {
                          lang: "en-US",
                          projectId: "", // Required to use gaction.
                          modelId: "", // (OPTIONAL for gaction)
                          instanceId: "", // (OPTIONAL for gaction)
                          latitude: 51.508530,
                          longitude: -0.076132,
                        responseConfig: {
                          useScreenOutput: true,
                          screenOutputCSS: "screen_output.css",
                          screenOutputTimer: 5000,
                          activateDelay: 250,
                          useAudioOutput: true,
                          useChime: true,
                          newChime: false,
                          useNative: true,
                          playProgram: "mpg321"
                        micConfig: { // put there configuration generated by auto-installer
                          recorder: "arecord",
                          device: "plughw:2",
                        customActionConfig: {
                          autoMakeAction: false,
                          autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                          actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                        snowboy: {
                          audioGain: 2.0,
                          Frontend: true,
                          Model: "jarvis",
                          Sensitivity: null
                        A2DServer: {
                          useA2D: false,
                          stopCommand: "stop"
                        recipes: [ "with-MMM-TelegramBot.js" ]
                    		module: 'MMM-SwissCommute',
                    		position: 'top_left',
                    		header: 'En Louche',
                    			to: 'Lancy-Bachet', // Destination station
                    			maximumEntries: 4, // Max departures displayed
                    			minWalkingTime: 10 // Minimum time to get to the station
                    				  module: "MMM-NowPlayingOnSpotify",
                    					clientID: "622ad97f8ed24ad9aa3b81531aae033f",
                    					clientSecret: "418079ac53a848679c37ac9613485136",
                    					accessToken: "BQCWLLN5elD8_f9zR7q9947jqCacUYNQ-6RzF8W_R1vx89DVTwkZBjpa1AR89PNw-yLdFziPjg_-hth6WVTPgQvekE5YPnz5ywbBzY0V_TBEa2N1hyucipaXSrmtBx5e2VaFf_SGrjzIkIeeKQ",
                    					refreshToken: "AQA-F5RgN04XC8NP5oOymHEWY_HqW4EwzUCx28GBHfjtLiCf3ordxs55HDxSjy1NwDWJlxthmAVKCRwNUrN3sqDX51JDRVjHP6y6wDnwZ1gs2RJ2tLPwIxJM3SuAgXOAlOk"
                                            module: "newsfeed",
                                            position: "lower_third",
                                                    feeds: [
        title: "Le Monde, Paris",
        url: "https://www.lemonde.fr/international/rss_full.xml"
                                                    showSourceTitle: true,
                                                    showPublishDate: true
                      module: “MMM-GoogleAssistant”,
                      position: “top_right”,
                      • why top_right and not fullscreen_above position ?
                      • why recipes: [ "with-MMM-TelegramBot.js" ] if you don’t use TelegramBot module ?
                      • W Offline
                        wirdman @Guest
                        @Bugsounet
                        hello mon google assistant ne veux plus aller sur youtube depuis la mise à jour
                        et aussi je ne sais pas pourquoi pour MMM-Spotify j’ai une erreur a la commande
                        il ne veux pas me donner le token
                        cd ~/MagicMirror/modules/MMM-Spotify
                        node first_auth.js
                        erreur
                        pi@raspberrypi:~/MagicMirror/modules/MMM-Spotify $ node first_auth.js
                        internal/modules/cjs/loader.js:638
                            throw err;
                        Error: Cannot find module './Spotify.js'
                            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                            at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                            at Module.require (internal/modules/cjs/loader.js:692:17)
                            at require (internal/modules/cjs/helpers.js:25:18)
                            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:3:17)
                        merci d avance
                          ah oui lol … désolé j’ai oublier de modifier le script avec la nouvelle librairie (bravo !)
                          Je vais corriger ça de suite !
                          pour A2D et GA, la commande de mise a jour est npm run update
                          a executer dans chaque repertoire (GA et A2D)
                          • W Offline
                            wirdman @Guest
                            @Bugsounet
                            aah je croyais avoir tout cassé 😁😁😁😁
                              non personne est parfait !
                              Laisse moi 10 min et c’est good ;)
                                voila !
                                git pull et go !
                                (et peut etre: npm install… a voir)
                                  Tu va etre connu !!! ton nickname est sur le Readme ! ;)
                                    @wirdman : c’est good ?
                                    • W Offline
                                      wirdman
                                      j ai essayé de voir un peut mais l’assistant fonctionne très bien mais il est incapable de lancer une video youtube ou de contrôler Spotify
                                      en revanche on peut caster sans problème
                                      Merci d’avance pour tout le travail que tu fais
                                      quand je lance une requete :
                                       transcription: { transcription: 'joue les beattles sur youtube', done: true },
                                        continue: false,
                                        volume: null,
                                        lastQuery: {
                                          type: 'MIC',
                                          key: null,
                                          lang: 'fr-FR',
                                          status: 'standby',
                                          chime: true
                                      • W Offline
                                        wirdman @Guest
                                        @Bugsounet hahahaha incroyable pour le readme😁
                                        • blake_northrupB Offline
                                          blake_northrup
                                          This morning I noticed that my MMM-GoogleAssistant needed an update, so I updated the module, and now get the black electron screen instead of the Magic Mirror screen. If I removed the module from the config, the Mirror comes up correctly, but when I add my config back, it goes black again. I have tried everything, from removing, then reinstalling, npm rebuild, electron rebuild, and nada. Was working fine until then. Any help would be greatly appreciated. See errors below:
                                          [2020-07-17 13:07:48.310] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                                          Expected directory: electron-v6.1-linux-arm-glibc
                                          Found: [node-v72-linux-arm-glibc]
                                          This problem can often be fixed by running “npm rebuild” on the current system
                                          Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node’
                                          Require stack:
                                          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js
                                          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js
                                          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client.js
                                          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/index.js
                                          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/components/assistant.js
                                          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/index.js
                                          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/components/assistant.js
                                          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
                                          [2020-07-17 13:07:48.311] [LOG] Loading module helpers …
                                          [2020-07-17 13:07:48.313] [LOG] No helper found for module: alert.
                                          [2020-07-17 13:07:48.314] [LOG] Initializing new module helper …
                                          [2020-07-17 13:07:48.314] [LOG] Module helper loaded: updatenotification
                                          [2020-07-17 13:07:48.315] [LOG] No helper found for module: clock.
                                          [2020-07-17 13:07:48.316] [LOG] Initializing new module helper …
                                          [2020-07-17 13:07:48.317] [LOG] Module helper loaded: calendar
                                          [2020-07-17 13:07:48.318] [LOG] No helper found for module: MMM-Rainbow.
                                          [2020-07-17 13:07:48.319] [LOG] No helper found for module: compliments.
                                          [2020-07-17 13:07:48.320] [LOG] Initializing new module helper …
                                          [2020-07-17 13:07:48.320] [LOG] Module helper loaded: MMM-SystemStats
                                          [2020-07-17 13:07:48.321] [LOG] Initializing new module helper …
                                          [2020-07-17 13:07:48.322] [LOG] Module helper loaded: MMM-Remote-Control
                                          [2020-07-17 13:07:48.323] [LOG] No helper found for module: currentweather.
                                          [2020-07-17 13:07:48.324] [LOG] No helper found for module: weatherforecast.
                                          [2020-07-17 13:07:48.325] [LOG] No helper found for module: MMM-EyeCandy.
                                          [2020-07-17 13:07:48.327] [LOG] Initializing new module helper …
                                          [2020-07-17 13:07:48.327] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
                                          [2020-07-17 13:07:48.352] [ERROR] App threw an error during load
                                          [2020-07-17 13:07:48.354] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
                                          Require stack:
                                          • at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js:53:17)
                                            at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                                            at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js:144:12)
                                            [2020-07-17 13:07:48.356] [ERROR] Whoops! There was an uncaught exception…
                                            [2020-07-17 13:07:48.357] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
                                            Require stack:
                                            at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10) {
                                            code: ‘MODULE_NOT_FOUND’
                                            [2020-07-17 13:07:48.371] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            [2020-07-17 13:07:48.372] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            [2020-07-17 13:07:48.539] [LOG] Launching application.
                                          • W Offline
                                            wirdman @blake_northrup
                                            @blake_northrup said in MMM-GoogleAssistant not running:
                                            do you have run
                                            npm run update
                                            in google assistant folder and Assistant2Display folder ?
                                            have it too but you can
                                            at you mmm-GoogleAssistant folder run
                                            npm install
                                            or
                                            npm rebuild
                                            blake_northrupB 1 Reply Last reply Reply Quote 1
