    MMM-GoogleAssistant not running
    55 Posts 5 Posters 24.0k Views 5 Watching
      A Former User
      just for information : original is there
      so if you don’t edit it
      Your SD card have a problem
      • W
        wirdman
        okay thanks a lot for you help i going buy a new card a i tell you if it’s working 😃
        • W
          wirdman
          • W
            wirdman
            hey @Bugsounet and @sdetweil
            i delete it re install it and now is since to work but is not on my mirror
            here my npm start :
            > magicmirror@2.12.0 start /home/pi/MagicMirror
            [2020-07-15 01:23:28.851] [LOG]    Starting MagicMirror: v2.12.0
            [2020-07-15 01:23:28.867] [LOG]    Loading config ...
            [2020-07-15 01:23:28.876] [LOG]    Loading module helpers ...
            [2020-07-15 01:23:28.882] [LOG]    No helper found for module: alert.
            [2020-07-15 01:23:28.989] [LOG]    Initializing new module helper ...
            [2020-07-15 01:23:28.991] [LOG]    Module helper loaded: updatenotification
            [2020-07-15 01:23:28.993] [LOG]    No helper found for module: clock.
            [2020-07-15 01:23:29.821] [LOG]    Initializing new module helper ...
            [2020-07-15 01:23:29.823] [LOG]    Module helper loaded: calendar
            [2020-07-15 01:23:29.824] [LOG]    No helper found for module: compliments.
            [2020-07-15 01:23:29.826] [LOG]    No helper found for module: currentweather.
            [2020-07-15 01:23:29.827] [LOG]    No helper found for module: weatherforecast.
            [2020-07-15 01:23:33.352] [LOG]    Initializing new module helper ...
            [2020-07-15 01:23:33.355] [LOG]    Module helper loaded: MMM-GoogleAssistant
            [2020-07-15 01:23:33.358] [LOG]    No helper found for module: MMM-SwissCommute.
            [2020-07-15 01:23:34.709] [LOG]    Initializing new module helper ...
            [2020-07-15 01:23:34.711] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
            [2020-07-15 01:23:34.795] [LOG]    Initializing new module helper ...
            [2020-07-15 01:23:34.798] [LOG]    Module helper loaded: newsfeed
            [2020-07-15 01:23:34.799] [LOG]    All module helpers loaded.
            [2020-07-15 01:23:35.213] [LOG]    Starting server on port 8080 ...
            [2020-07-15 01:23:35.243] [INFO]   You're using a full whitelist configuration to allow for all IPs
            [2020-07-15 01:23:35.267] [LOG]    Server started ...
            [2020-07-15 01:23:35.269] [LOG]    Connecting socket for: updatenotification
            [2020-07-15 01:23:35.273] [LOG]    Connecting socket for: calendar
            [2020-07-15 01:23:35.276] [LOG]    Starting node helper for: calendar
            [2020-07-15 01:23:35.278] [LOG]    Connecting socket for: MMM-GoogleAssistant
            [2020-07-15 01:23:35.281] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
            [2020-07-15 01:23:35.284] [LOG]    Connecting socket for: newsfeed
            [2020-07-15 01:23:35.288] [LOG]    Starting node helper for: newsfeed
            [2020-07-15 01:23:35.290] [LOG]    Sockets connected & modules started ...
            [2020-07-15 01:23:35.621] [LOG]    Launching application.
            [2020-07-15 01:23:41.914] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics - Interval: 300000
            [2020-07-15 01:23:42.376] [LOG]    Create new news fetcher for url: https://www.lemonde.fr/international/rss_full.xml - Interval: 300000
            [2020-07-15 01:23:42.532] [INFO]   Checking git for module: MMM-GoogleAssistant
            [2020-07-15 01:23:42.621] [INFO]   Checking git for module: MMM-SwissCommute
            [2020-07-15 01:23:42.706] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
            [2020-07-15 01:23:42.800] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.2.1
            [2020-07-15 01:23:42.831] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
            [2020-07-15 01:23:42.835] [ERROR]  (node:25329) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
            [2020-07-15 01:23:44.440] [LOG]    Refreshed access token because it has expired. Expired at: 01:23:42 now is: 01:23:44
            [2020-07-15 01:23:44.509] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:44
            [2020-07-15 01:23:45.202] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
            [2020-07-15 01:23:45.224] [LOG]    Refreshed access token because it has expired. Expired at: 02:23:44 now is: 01:23:45
            [2020-07-15 01:23:47.028] [LOG]    [SNOWBOY] Model selected: jarvis
            [2020-07-15 01:23:47.042] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
            [2020-07-15 01:23:47.067] [LOG]    [ASSISTANT] RECIPE_LOADED: with-MMM-TelegramBot.js
            [2020-07-15 01:23:47.073] [LOG]    [ASSISTANT] Use native program (mpg321) for audio response
            [2020-07-15 01:23:47.078] [LOG]    [SOUND] mpg321 Initialized
            [2020-07-15 01:23:47.083] [LOG]    [ASSISTANT] Google Assistant is initialized.
            [2020-07-15 01:23:48.183] [INFO]   Calendar-Fetcher: Broadcasting 4 events.
            here my confi.js
            /* Magic Mirror Config Sample
              * MIT Licensed.
            var config = {
                    port: 8080,
                    ipWhitelist: [], // Set [] to allow all IP addresses.
                    language: "fr",
                    timeFormat: 24,
                    units: "metric",
                                    module: "alert",
                                    module: "updatenotification",
                                    position: "top_bar"
                                    module: "clock",
                                    position: "top_left"
                                    header: "Calendrier",
                                                            symbol: "calendar-check-o ",
                                                            url: "https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics"
                                    module: "compliments",
                                    position: "lower_third"
                                    module: "currentweather",
                                            locationID: "2660646",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            appid: "a159eb40caad1348cda97718adc69d6d"
                                    module: "weatherforecast",
                                    header: "Météo",
                                    header: "Météo",
                                            locationID: "",  //ID from http://www.openweathermap.org/help/city_list.txt
                                            appid: ""
              module: "MMM-GoogleAssistant",
                debug: false,
                assistantConfig: {
                  lang: "en-US",
                  projectId: "", // Required to use gaction.
                  modelId: "", // (OPTIONAL for gaction)
                  instanceId: "", // (OPTIONAL for gaction)
                  latitude: 51.508530,
                  longitude: -0.076132,
                responseConfig: {
                  useScreenOutput: true,
                  screenOutputCSS: "screen_output.css",
                  screenOutputTimer: 5000,
                  activateDelay: 250,
                  useAudioOutput: true,
                  useChime: true,
                  newChime: false,
                  useNative: true,
                  playProgram: "mpg321"
                micConfig: { // put there configuration generated by auto-installer
                  recorder: "arecord",
                  device: "plughw:2",
                customActionConfig: {
                  autoMakeAction: false,
                  autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                  actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                snowboy: {
                  audioGain: 2.0,
                  Frontend: true,
                  Model: "jarvis",
                  Sensitivity: null
                A2DServer: {
                  useA2D: false,
                  stopCommand: "stop"
                recipes: [ "with-MMM-TelegramBot.js" ]
            		module: 'MMM-SwissCommute',
            		position: 'top_left',
            		header: 'En Louche',
            			to: 'Lancy-Bachet', // Destination station
            			maximumEntries: 4, // Max departures displayed
            			minWalkingTime: 10 // Minimum time to get to the station
            				  module: "MMM-NowPlayingOnSpotify",
            					clientID: "622ad97f8ed24ad9aa3b81531aae033f",
            					clientSecret: "418079ac53a848679c37ac9613485136",
            					accessToken: "BQCWLLN5elD8_f9zR7q9947jqCacUYNQ-6RzF8W_R1vx89DVTwkZBjpa1AR89PNw-yLdFziPjg_-hth6WVTPgQvekE5YPnz5ywbBzY0V_TBEa2N1hyucipaXSrmtBx5e2VaFf_SGrjzIkIeeKQ",
            					refreshToken: "AQA-F5RgN04XC8NP5oOymHEWY_HqW4EwzUCx28GBHfjtLiCf3ordxs55HDxSjy1NwDWJlxthmAVKCRwNUrN3sqDX51JDRVjHP6y6wDnwZ1gs2RJ2tLPwIxJM3SuAgXOAlOk"
                                    module: "newsfeed",
                                    position: "lower_third",
                                            feeds: [
                                                            title: "Le Monde, Paris",
                                                            url: "https://www.lemonde.fr/international/rss_full.xml"
                                            showSourceTitle: true,
                                            showPublishDate: true
              A Former User
              @wirdman said in MMM-GoogleAssistant not running:
              module: “MMM-GoogleAssistant”,
              position: “top_right”,
              • why top_right and not fullscreen_above position ?
              • why recipes: [ "with-MMM-TelegramBot.js" ] if you don’t use TelegramBot module ?
              W 1 Reply Last reply
              • W
                wirdman @Guest
                @Bugsounet
                hello mon google assistant ne veux plus aller sur youtube depuis la mise à jour
                et aussi je ne sais pas pourquoi pour MMM-Spotify j’ai une erreur a la commande
                il ne veux pas me donner le token
                cd ~/MagicMirror/modules/MMM-Spotify
                node first_auth.js
                erreur
                pi@raspberrypi:~/MagicMirror/modules/MMM-Spotify $ node first_auth.js
                internal/modules/cjs/loader.js:638
                    throw err;
                Error: Cannot find module './Spotify.js'
                    at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                    at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                    at Module.require (internal/modules/cjs/loader.js:692:17)
                    at require (internal/modules/cjs/helpers.js:25:18)
                    at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:3:17)
                merci d avance
                  A Former User
                  ah oui lol … désolé j’ai oublier de modifier le script avec la nouvelle librairie (bravo !)
                  Je vais corriger ça de suite !
                  pour A2D et GA, la commande de mise a jour est npm run update
                  a executer dans chaque repertoire (GA et A2D)
                  • W
                    wirdman @Guest
                    @Bugsounet
                    aah je croyais avoir tout cassé 😁😁😁😁
                      A Former User
                      non personne est parfait !
                      Laisse moi 10 min et c’est good ;)
                        A Former User
                        voila !
                        git pull et go !
                        (et peut etre: npm install… a voir)
                          A Former User
                          Tu va etre connu !!! ton nickname est sur le Readme ! ;)
                            A Former User
                            @wirdman : c’est good ?
                            • W
                              wirdman
                              j ai essayé de voir un peut mais l’assistant fonctionne très bien mais il est incapable de lancer une video youtube ou de contrôler Spotify
                              en revanche on peut caster sans problème
                              Merci d’avance pour tout le travail que tu fais
                              quand je lance une requete :
                               transcription: { transcription: 'joue les beattles sur youtube', done: true },
                                continue: false,
                                volume: null,
                                lastQuery: {
                                  type: 'MIC',
                                  key: null,
                                  lang: 'fr-FR',
                                  status: 'standby',
                                  chime: true
                              • W
                                wirdman @Guest
                                @Bugsounet hahahaha incroyable pour le readme😁
                                • blake_northrupB
                                  blake_northrup
                                  This morning I noticed that my MMM-GoogleAssistant needed an update, so I updated the module, and now get the black electron screen instead of the Magic Mirror screen. If I removed the module from the config, the Mirror comes up correctly, but when I add my config back, it goes black again. I have tried everything, from removing, then reinstalling, npm rebuild, electron rebuild, and nada. Was working fine until then. Any help would be greatly appreciated. See errors below:
                                  [2020-07-17 13:07:48.310] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
                                  Expected directory: electron-v6.1-linux-arm-glibc
                                  Found: [node-v72-linux-arm-glibc]
                                  This problem can often be fixed by running “npm rebuild” on the current system
                                  Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node’
                                  Require stack:
                                  • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js
                                  • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js
                                  • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client.js
                                  • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/index.js
                                  • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/components/assistant.js
                                  • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/index.js
                                  • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/components/assistant.js
                                  • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
                                  [2020-07-17 13:07:48.311] [LOG] Loading module helpers …
                                  [2020-07-17 13:07:48.313] [LOG] No helper found for module: alert.
                                  [2020-07-17 13:07:48.314] [LOG] Initializing new module helper …
                                  [2020-07-17 13:07:48.314] [LOG] Module helper loaded: updatenotification
                                  [2020-07-17 13:07:48.315] [LOG] No helper found for module: clock.
                                  [2020-07-17 13:07:48.316] [LOG] Initializing new module helper …
                                  [2020-07-17 13:07:48.317] [LOG] Module helper loaded: calendar
                                  [2020-07-17 13:07:48.318] [LOG] No helper found for module: MMM-Rainbow.
                                  [2020-07-17 13:07:48.319] [LOG] No helper found for module: compliments.
                                  [2020-07-17 13:07:48.320] [LOG] Initializing new module helper …
                                  [2020-07-17 13:07:48.320] [LOG] Module helper loaded: MMM-SystemStats
                                  [2020-07-17 13:07:48.321] [LOG] Initializing new module helper …
                                  [2020-07-17 13:07:48.322] [LOG] Module helper loaded: MMM-Remote-Control
                                  [2020-07-17 13:07:48.323] [LOG] No helper found for module: currentweather.
                                  [2020-07-17 13:07:48.324] [LOG] No helper found for module: weatherforecast.
                                  [2020-07-17 13:07:48.325] [LOG] No helper found for module: MMM-EyeCandy.
                                  [2020-07-17 13:07:48.327] [LOG] Initializing new module helper …
                                  [2020-07-17 13:07:48.327] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
                                  [2020-07-17 13:07:48.352] [ERROR] App threw an error during load
                                  [2020-07-17 13:07:48.354] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
                                  Require stack:
                                  • at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js:53:17)
                                    at Module._compile (internal/modules/cjs/loader.js:786:30)
                                    at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                                    at Module.load (internal/modules/cjs/loader.js:645:32)
                                    at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                                    at Module.require (internal/modules/cjs/loader.js:685:19)
                                    at require (internal/modules/cjs/helpers.js:16:16)
                                    at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js:144:12)
                                    [2020-07-17 13:07:48.356] [ERROR] Whoops! There was an uncaught exception…
                                    [2020-07-17 13:07:48.357] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
                                    Require stack:
                                    at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10) {
                                    code: ‘MODULE_NOT_FOUND’
                                    [2020-07-17 13:07:48.371] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2020-07-17 13:07:48.372] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [2020-07-17 13:07:48.539] [LOG] Launching application.
                                  • W
                                    wirdman @blake_northrup
                                    @blake_northrup said in MMM-GoogleAssistant not running:
                                    do you have run
                                    npm run update
                                    in google assistant folder and Assistant2Display folder ?
                                    have it too but you can
                                    at you mmm-GoogleAssistant folder run
                                    npm install
                                    or
                                    npm rebuild
                                    blake_northrupB 1 Reply Last reply
                                    • blake_northrupB
                                      blake_northrup @wirdman
                                      @wirdman You are the man sir! Much appreciated wirdman!
                                      • W
                                        @blake_northrup did it work ?
                                        • blake_northrupB
                                          @wirdman Yep, all good. I just needed to do npm rebuild in the MMM-GoogleAssistant folder. I was doing it in the MagicMirror folder. Thanks again!
                                          • W
                                            wirdman
                                            pleasure
