    I broke something
    10 Posts 3 Posters 2.3k Views 3 Watching
    • K Offline
      killerjoe34
      Hi everyone,
      Was cleaning my module directory, I think I deleted something I shouldn’t have…
      My mirror starts but only shows the clock.
      The RemoteControl is ok except the “hide and show modules” part that asks to check the MM logs for more details.
      That’s what I get :
      PM2            | App [MagicMirror:1] exited with code [1] via signal [SIGINT]
      PM2            | App [MagicMirror:1] starting in -fork mode-
      PM2            | App [MagicMirror:1] online
      1|MagicMirror  | [2020-07-15 08:49:12.135] [ERROR]
      1|MagicMirror  | { Error: ENOENT: no such file or directory, open 'package.json'
      1|MagicMirror  |     at Object.openSync (fs.js:443:3)
      1|MagicMirror  |     at Object.readFileSync (fs.js:343:35)
      1|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:18:32)
      1|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:778:30)
      1|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      1|MagicMirror  |     at Module.load (internal/modules/cjs/loader.js:653:32)
      1|MagicMirror  |     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      1|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      1|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:692:17)
      1|MagicMirror  |     at Module.Hook._require.Module.require (/usr/lib/node_modules/pm2/node_modules/require-in-the-middle/index.js:80:39)
      1|MagicMirror  |   errno: -2,
      1|MagicMirror  |   syscall: 'open',
      1|MagicMirror  |   code: 'ENOENT',
      1|MagicMirror  |   path: 'package.json' }
      I tried to npm install all my modules again but still the same.
      Got an idea ?
      • K Offline
        killerjoe34
        Well, I did a fresh reinstall, it took me about 2 hours but it’s approximately working again :)
        • BKeyportB Offline
          BKeyport Module Developer
          I moved my personal configs to another directory and symlinked them in their proper places.
          This gives me a guide to get up and running after doing something stupid… Takes reinstall time from several hours to about 30 minutes.
          • K Offline
            killerjoe34
            @BKeyport said in I broke something:
            symlink
            I’m not sure to exactly get what a simlink is, what’s the difference with a simple copy ?
              sdetweil @killerjoe34
              @killerjoe34 linux file systems give you the ability to create a file as a LINK to another file somewhere else…
              so you only have one copy, but multiple instances… changing the root file makes it look like all the linked files changed too
              see the ln command
              • K Offline
                killerjoe34
                Ok, I read the man page but still don’t get it, even in french :D :(
                You’re saying that if the root file is modified, it also modifies the linked one(s) or does it make another copy ?
                Cause it would be perfect in that case, keeping track of every modification to be able to step back.
                Thanks for your explanations :)
                  @killerjoe34 no, the link makes it look like all the secondary files ARE the root file. so actually changing ANY changes them all, there is ONLY one actual file. but erasing the linked file does NOT erase the root file.
                  try this
                  mkdir ~/foo
                  mv ~/MagicMirror/config/config.js foo
                  cd ~/MagicMirror/config
                  ln -s ~/foo/config.js config.js
                  now you have your file in ~/foo
                  but it LOOKS like it is also in ~/MagicMirror/config
                  edit one, change the date/time format
                  restart MM
                  voila
                  edit the other one and change it back
                  restart MM
                  • K Offline
                    killerjoe34
                    @sdetweil said in I broke something:
                    try this
                    Wow great :)
                    Thanks a lot, I’ll use that !
                      @killerjoe34 you can also link folders
                      if you do (in the config folder where I just set a link)
                      ls -laF
                      will show u the file is linked, and where to
                      K 1 Reply Last reply Reply Quote 1
                      • K Offline
                        killerjoe34 @sdetweil
                        ls -laF
                        Ok, I’ll have a look at that, thx again !
