    I broke something
    10 Posts 3 Posters 2.0k Views 3 Watching
    • BKeyportB Offline
      BKeyport Module Developer
      I moved my personal configs to another directory and symlinked them in their proper places.
      This gives me a guide to get up and running after doing something stupid… Takes reinstall time from several hours to about 30 minutes.
      • K Offline
        killerjoe34
        @BKeyport said in I broke something:
        symlink
        I’m not sure to exactly get what a simlink is, what’s the difference with a simple copy ?
          sdetweil @killerjoe34
          @killerjoe34 linux file systems give you the ability to create a file as a LINK to another file somewhere else…
          so you only have one copy, but multiple instances… changing the root file makes it look like all the linked files changed too
          see the ln command
          • K Offline
            killerjoe34
            Ok, I read the man page but still don’t get it, even in french :D :(
            You’re saying that if the root file is modified, it also modifies the linked one(s) or does it make another copy ?
            Cause it would be perfect in that case, keeping track of every modification to be able to step back.
            Thanks for your explanations :)
              @killerjoe34 no, the link makes it look like all the secondary files ARE the root file. so actually changing ANY changes them all, there is ONLY one actual file. but erasing the linked file does NOT erase the root file.
              try this
              mkdir ~/foo
              mv ~/MagicMirror/config/config.js foo
              cd ~/MagicMirror/config
              ln -s ~/foo/config.js config.js
              now you have your file in ~/foo
              but it LOOKS like it is also in ~/MagicMirror/config
              edit one, change the date/time format
              restart MM
              voila
              edit the other one and change it back
              restart MM
              • K Offline
                killerjoe34
                @sdetweil said in I broke something:
                try this
                Wow great :)
                Thanks a lot, I’ll use that !
                  @killerjoe34 you can also link folders
                  if you do (in the config folder where I just set a link)
                  ls -laF
                  will show u the file is linked, and where to
                  K 1 Reply Last reply Reply Quote 1
                  • K Offline
                    killerjoe34 @sdetweil
                    ls -laF
                    Ok, I’ll have a look at that, thx again !
