    Raspberry Pi 3B+ and 4 "No wireless interfaces found"
    12 Posts 3 Posters 26.5k Views 3 Watching
      Blauenfeldt
      I can try and take a picture in Noobs Recovery and upload it.
        sdetweil @Blauenfeldt
        @Blauenfeldt I never use noobs
          majik655
          @Blauenfeldt
          install it without noobs. Noobs has given me problems in one way or another when I have used it. The issues range from a lot of things depending on what you are doing …
          Go get the raspbian desktop image and just use that … it is just as easy to install as noobs and more than likely you will have working wifi when finished.
          If you have another sd card (and dont want to erase your noobs one) just try it out on a second card… you will get it going.
            Blauenfeldt
            I guess I have to do that.
            I have used a lot of time compiling and makeing things forward/backwards compatible python wise. Is there a way to save and transfer that?
              Blauenfeldt
              Now that i look this post through, I saw that rfkill says “wlan”. Is it possible, that my Pi looks for wlan0 and not wlan, and therefore not being able to find it?
                @Blauenfeldt rfkill?
                sudo ifconfig
                will list the network interfaces
                  Blauenfeldt
                  I did some digging around the net, and kinda got wifi working again. Wifi itself works fine. I can do sudo iwlist wlan0 scan, and see surrounding wifi. However the drop-down list on the panel does not work.
                  What i did to get my wifi working to this point was changing the /etc/network/interfaces file to
                  auto lo
                  iface lo inet loopback
                  auto eth0
                  iface eth0 inet dhcp
                  auto wlan0
                  allow-hotplug wlan0
                  iface wlan0 inet dhcp
                          wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
                  I found out I had some spelling errors like .config instead of .conf and found a default Buster Wpa_supplicant.conf file
                  here is my new Sudo ifconfig
                  eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                          inet 192.168.87.198  netmask 255.255.255.0  broadcast 192.168.87.255
                          inet6 fe80::dea6:32ff:fe20:55bf  prefixlen 64  scopeid 0x20<link>
                          ether dc:a6:32:20:55:bf  txqueuelen 1000  (Ethernet)
                          RX packets 1775  bytes 510729 (498.7 KiB)
                          RX errors 0  dropped 0  overruns 0  frame 0
                          TX packets 1633  bytes 972722 (949.9 KiB)
                          TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
                  lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
                          inet 127.0.0.1  netmask 255.0.0.0
                          inet6 ::1  prefixlen 128  scopeid 0x10<host>
                          loop  txqueuelen 1000  (Local Loopback)
                          RX packets 275  bytes 80411 (78.5 KiB)
                          TX packets 275  bytes 80411 (78.5 KiB)
                  wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
                          inet 192.168.87.199  netmask 255.255.255.0  broadcast 192.168.87.255
                          inet6 fe80::dea6:32ff:fe20:55c0  prefixlen 64  scopeid 0x20<link>
                          ether dc:a6:32:20:55:c0  txqueuelen 1000  (Ethernet)
                          RX packets 20  bytes 2957 (2.8 KiB)
                          TX packets 32  bytes 5653 (5.5 KiB)
                  Everything works, even ethernet, except for the wifi drop-down menu (shown below)
                  If I hover the mouse over it it says “connection to dhcpcd lost”
                  If I click on it, it says “No wireless interfaces found”
                  Can not really find anymore answers to this problem.
                  Have i disabled something somewhere?
                    Blauenfeldt @Blauenfeldt
                      @Blauenfeldt no idea. as I said, I don’t use noobs because of all this extra setup I don’t want to learn
