Solved pm2 Autostart invert issue
here’s my mm.sh file:
cd./ MagicMirror DISPLAY=:0 npm start DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
@Ethyx right u start mm before u change rotation, swap the last two lines
npm start doesn’t return for the next line until mm shuts down
I did that already but the issue still persists.
cd./ MagicMirror DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted DISPLAY=:0 npm start
@sdetweil yes, it does
@Ethyx with the screen flipped?
@Ethyx I think u can put the screen flip in /boot/config.txt
not the xrandr command tho
how do you do that tho?
@sdetweil so true
