    pm2 Autostart invert issue
    Scheduled Pinned Locked Moved Solved Bug Hunt
    32 Posts 4 Posters 14.8k Views 4 Watching
    • EthyxE
      Ethyx
      Yeah I don’t have 2 mm’s starting up at boot.
      • EthyxE
        Ethyx
        here’s my mm.sh file:
        cd./ MagicMirror
        DISPLAY=:0 npm start
        DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
          sdetweil @Ethyx
          @Ethyx right u start mm before u change rotation, swap the last two lines
          npm start doesn’t return for the next line until mm shuts down
          • EthyxE
            Ethyx
            I did that already but the issue still persists.
            cd./ MagicMirror
              sdetweil @Ethyx
              @Ethyx what happens when u execute mm.sh manually. not using pm2?
              does xrandr return immediately
              EthyxE 1 Reply Last reply
              • EthyxE
                Ethyx @sdetweil
                @sdetweil yes, it does
                  sdetweil @Ethyx
                  @Ethyx with the screen flipped?
                    @Ethyx I think u can put the screen flip in /boot/config.txt
                    not the xrandr command tho
                    • EthyxE
                      Ethyx
                      how do you do that tho?
                        sdetweil @Ethyx
                        @Ethyx Google is your friend
                        https://www.raspberrypi-spy.co.uk/2017/11/how-to-rotate-the-raspberry-pi-display-output/
                        EthyxE 2 Replies Last reply
                        • EthyxE
                          Ethyx @sdetweil
                          @sdetweil so true
                          • EthyxE
                            Ethyx @sdetweil
                            @sdetweil the issue still persists
                              sdetweil @Ethyx
                              @Ethyx u set the rotation in /boot/config.txt and rebooted and rotation was changed, yes?
                              the remove xrandr from mm.sh
                              • EthyxE
                                Ethyx @sdetweil
                                @sdetweil ok on it
                                • EthyxE
                                  Ethyx @sdetweil
                                  @sdetweil this time even when I give ^q, the screen is not inverted as opposed to last time.
                                    sdetweil @Ethyx
                                    @Ethyx so the /boot/config.txt didn’t work. read more
                                    • EthyxE
                                      Ethyx @sdetweil
                                      @sdetweil yep
                                      S EthyxE 2 Replies Last reply
                                        sdetweil @Ethyx
                                        @Ethyx you added
                                        display_rotate=2
                                        to config.txt, right, and saved it
                                        • EthyxE
                                          Ethyx @Ethyx
                                          @sdetweil yeah and the issue still somehow persists
                                            sdetweil @Ethyx
                                            @Ethyx you had to use
                                            sudo nano /boot/config.txt
                                            to edit that file, right?
