    pm2 Autostart invert issue
    Scheduled Pinned Locked Moved Solved Bug Hunt
    32 Posts 4 Posters 11.6k Views 4 Watching
    • EthyxE Offline
      Ethyx
      This is my first mm project. I used pm2 to autostart my magicmirror and everything is going fine. but the mirror i made can only be put up when the screen is inverted. so i added that to my mm.sh file. Once it boots up, the screen becomes regualr and i have to vnc to it and do ^Q in order to exit the mm. it opens up a short while after and thats when its inverted.
        sdetweil @Ethyx
        @Ethyx are u sure u don’t have two MM’s starting at boot?
        see
        pm2 status
        • EthyxE Offline
          Ethyx
          Yeah I don’t have 2 mm’s starting up at boot.
          • EthyxE Offline
            Ethyx
            here’s my mm.sh file:
            cd./ MagicMirror
            DISPLAY=:0 npm start
            DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
              sdetweil @Ethyx
              @Ethyx right u start mm before u change rotation, swap the last two lines
              npm start doesn’t return for the next line until mm shuts down
              • EthyxE Offline
                Ethyx
                I did that already but the issue still persists.
                cd./ MagicMirror
                  sdetweil @Ethyx
                  @Ethyx what happens when u execute mm.sh manually. not using pm2?
                  does xrandr return immediately
                  EthyxE 1 Reply Last reply Reply Quote 0
                  • EthyxE Offline
                    Ethyx @sdetweil
                    @sdetweil yes, it does
                      sdetweil @Ethyx
                      @Ethyx with the screen flipped?
                        @Ethyx I think u can put the screen flip in /boot/config.txt
                        not the xrandr command tho
                        • 1 / 4
