    pm2 Autostart invert issue
    Scheduled Pinned Locked Moved Solved Bug Hunt
    32 Posts 4 Posters 11.9k Views 4 Watching
    • EthyxE Offline
      Ethyx
      here’s my mm.sh file:
      cd./ MagicMirror
      DISPLAY=:0 npm start
      DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
        sdetweil @Ethyx
        @Ethyx right u start mm before u change rotation, swap the last two lines
        npm start doesn’t return for the next line until mm shuts down
        • EthyxE Offline
          Ethyx
          I did that already but the issue still persists.
          cd./ MagicMirror
            sdetweil @Ethyx
            @Ethyx what happens when u execute mm.sh manually. not using pm2?
            does xrandr return immediately
            EthyxE 1 Reply Last reply Reply Quote 0
            • EthyxE Offline
              Ethyx @sdetweil
              @sdetweil yes, it does
                sdetweil @Ethyx
                @Ethyx with the screen flipped?
                  @Ethyx I think u can put the screen flip in /boot/config.txt
                  not the xrandr command tho
                  • EthyxE Offline
                    Ethyx
                    how do you do that tho?
                      sdetweil @Ethyx
                      @Ethyx Google is your friend
                      https://www.raspberrypi-spy.co.uk/2017/11/how-to-rotate-the-raspberry-pi-display-output/
                      EthyxE 2 Replies Last reply Reply Quote 0
                      • EthyxE Offline
                        Ethyx @sdetweil
                        @sdetweil so true
                        • 1 / 4
