    pm2 Autostart invert issue
    Scheduled Pinned Locked Moved Solved Bug Hunt
    32 Posts 4 Posters 14.1k Views 4 Watching
      sdetweil @Ethyx
      @Ethyx what happens when u execute mm.sh manually. not using pm2?
      does xrandr return immediately
      EthyxE 1 Reply Last reply Reply Quote 0
      • EthyxE Offline
        Ethyx @sdetweil
        @sdetweil yes, it does
          sdetweil @Ethyx
          @Ethyx with the screen flipped?
            @Ethyx I think u can put the screen flip in /boot/config.txt
            not the xrandr command tho
            • EthyxE Offline
              Ethyx
              how do you do that tho?
                sdetweil @Ethyx
                @Ethyx Google is your friend
                https://www.raspberrypi-spy.co.uk/2017/11/how-to-rotate-the-raspberry-pi-display-output/
                EthyxE 2 Replies Last reply Reply Quote 0
                • EthyxE Offline
                  Ethyx @sdetweil
                  @sdetweil so true
                  • EthyxE Offline
                    Ethyx @sdetweil
                    @sdetweil the issue still persists
                      sdetweil @Ethyx
                      @Ethyx u set the rotation in /boot/config.txt and rebooted and rotation was changed, yes?
                      the remove xrandr from mm.sh
                      • EthyxE Offline
                        Ethyx @sdetweil
                        @sdetweil ok on it
                        • EthyxE Offline
                          Ethyx @sdetweil
                          @sdetweil this time even when I give ^q, the screen is not inverted as opposed to last time.
                            sdetweil @Ethyx
                            @Ethyx so the /boot/config.txt didn’t work. read more
                            • EthyxE Offline
                              Ethyx @sdetweil
                              @sdetweil yep
                              S EthyxE 2 Replies Last reply Reply Quote 0
                                sdetweil @Ethyx
                                @Ethyx you added
                                display_rotate=2
                                to config.txt, right, and saved it
                                • EthyxE Offline
                                  Ethyx @Ethyx
                                  @sdetweil yeah and the issue still somehow persists
                                    sdetweil @Ethyx
                                    @Ethyx you had to use
                                    sudo nano /boot/config.txt
                                    to edit that file, right?
                                    • EthyxE Offline
                                      Ethyx
                                      @sdetweil yes. i followed everything that was on this website.
                                        sdetweil @Ethyx
                                        @Ethyx r u running buster?
                                        try this
                                        https://pimylifeup.com/raspberry-pi-rotate-screen/
                                        EthyxE evroomE 2 Replies Last reply Reply Quote 0
                                        • EthyxE Offline
                                          Ethyx @sdetweil
                                          @sdetweil that was the aritcle i referred to before i posted it here and yes i am using buster.
                                          • evroomE Offline
                                            evroom @sdetweil
                                            @sdetweil said in pm2 Autostart invert issue:
                                            try this
                                            @Ethyx
                                            Did you try this?
                                            display_hdmi_rotate=2
                                            Make sure you only have one of the options active; not that you rotate a rotated screen. :-)
                                            MagicMirror version: 2.37.0
