    pm2 Autostart invert issue
    Scheduled Pinned Locked Moved Solved Bug Hunt
    32 Posts 4 Posters 14.8k Views 4 Watching
      sdetweil @Ethyx
      @Ethyx right u start mm before u change rotation, swap the last two lines
      npm start doesn’t return for the next line until mm shuts down
      • EthyxE
        Ethyx
        I did that already but the issue still persists.
        cd./ MagicMirror
        DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
        DISPLAY=:0 npm start
          sdetweil @Ethyx
          @Ethyx what happens when u execute mm.sh manually. not using pm2?
          does xrandr return immediately
          EthyxE 1 Reply Last reply
          • EthyxE
            Ethyx @sdetweil
            @sdetweil yes, it does
              sdetweil @Ethyx
              @Ethyx with the screen flipped?
                @Ethyx I think u can put the screen flip in /boot/config.txt
                not the xrandr command tho
                • EthyxE
                  Ethyx
                  how do you do that tho?
                    sdetweil @Ethyx
                    @Ethyx Google is your friend
                    https://www.raspberrypi-spy.co.uk/2017/11/how-to-rotate-the-raspberry-pi-display-output/
                    EthyxE 2 Replies Last reply
                    • EthyxE
                      Ethyx @sdetweil
                      @sdetweil so true
                      • EthyxE
                        Ethyx @sdetweil
                        @sdetweil the issue still persists
                          sdetweil @Ethyx
                          @Ethyx u set the rotation in /boot/config.txt and rebooted and rotation was changed, yes?
                          the remove xrandr from mm.sh
                          • EthyxE
                            Ethyx @sdetweil
                            @sdetweil ok on it
                            • EthyxE
                              Ethyx @sdetweil
                              @sdetweil this time even when I give ^q, the screen is not inverted as opposed to last time.
                                sdetweil @Ethyx
                                @Ethyx so the /boot/config.txt didn’t work. read more
                                • EthyxE
                                  Ethyx @sdetweil
                                  @sdetweil yep
                                  S EthyxE 2 Replies Last reply
                                    sdetweil @Ethyx
                                    @Ethyx you added
                                    display_rotate=2
                                    to config.txt, right, and saved it
                                    • EthyxE
                                      Ethyx @Ethyx
                                      @sdetweil yeah and the issue still somehow persists
                                        sdetweil @Ethyx
                                        @Ethyx you had to use
                                        sudo nano /boot/config.txt
                                        to edit that file, right?
                                        • EthyxE
                                          Ethyx
                                          @sdetweil yes. i followed everything that was on this website.
                                            sdetweil @Ethyx
                                            @Ethyx r u running buster?
                                            try this
                                            https://pimylifeup.com/raspberry-pi-rotate-screen/
                                            EthyxE evroomE 2 Replies Last reply
