Solved pm2 Autostart invert issue
@sdetweil yeah and the issue still somehow persists
@Ethyx you had to use
sudo nano /boot/config.txt
to edit that file, right? -
@sdetweil yes. i followed everything that was on this website.
@Ethyx r u running buster?
@sdetweil that was the aritcle i referred to before i posted it here and yes i am using buster.
@sdetweil said in pm2 Autostart invert issue:
Did you try this?
display_hdmi_rotate=2
Make sure you only have one of the options active; not that you rotate a rotated screen. :-)
@Ethyx did u try this? in config.txt?
One thing - are you using a Pi 4? Or the “Fake KMS” drivers? If so, boot.txt won’t work - nor will anything else, really.
If the Mirror is running - directly on the pi, or through VNC, Alt-Space, then N. This will give you your desktop. then use your OSKey or the menu icon, go to preferences, and see if “Screen configuration” exists. If it does, set your rotation there, and remove it everywhere else.
@BKeyport I am using a Pi 4 for this matter. I don’t know what a KMS driver is, actually. Screen Configuration does not appear but I use a command that works the same way:
DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
