    pm2 Autostart invert issue
    Scheduled Pinned Locked Moved Solved Bug Hunt
    32 Posts 4 Posters 14.4k Views 4 Watching
    • EthyxE Offline
      Ethyx @sdetweil
      @sdetweil yep
      S EthyxE 2 Replies Last reply Reply Quote 0
        sdetweil @Ethyx
        @Ethyx you added
        display_rotate=2
        to config.txt, right, and saved it
        • EthyxE Offline
          Ethyx @Ethyx
          @sdetweil yeah and the issue still somehow persists
            sdetweil @Ethyx
            @Ethyx you had to use
            sudo nano /boot/config.txt
            to edit that file, right?
            • EthyxE Offline
              Ethyx
              @sdetweil yes. i followed everything that was on this website.
                sdetweil @Ethyx
                @Ethyx r u running buster?
                try this
                https://pimylifeup.com/raspberry-pi-rotate-screen/
                EthyxE evroomE 2 Replies Last reply Reply Quote 0
                • EthyxE Offline
                  Ethyx @sdetweil
                  @sdetweil that was the aritcle i referred to before i posted it here and yes i am using buster.
                  • evroomE Offline
                    evroom @sdetweil
                    @sdetweil said in pm2 Autostart invert issue:
                    try this
                    @Ethyx
                    Did you try this?
                    display_hdmi_rotate=2
                    Make sure you only have one of the options active; not that you rotate a rotated screen. :-)
                    MagicMirror version: 2.37.0
                      sdetweil @evroom
                      @Ethyx did u try this? in config.txt?
                      • EthyxE Offline
                        Ethyx
                        @evroom @sdetweil Yes. that did not work.
                        • BKeyportB Offline
                          BKeyport Module Developer
                          One thing - are you using a Pi 4? Or the “Fake KMS” drivers? If so, boot.txt won’t work - nor will anything else, really.
                          If the Mirror is running - directly on the pi, or through VNC, Alt-Space, then N. This will give you your desktop. then use your OSKey or the menu icon, go to preferences, and see if “Screen configuration” exists. If it does, set your rotation there, and remove it everywhere else.
                          EthyxE 1 Reply Last reply Reply Quote 1
                          • EthyxE Offline
                            Ethyx @BKeyport
                            @BKeyport I am using a Pi 4 for this matter. I don’t know what a KMS driver is, actually. Screen Configuration does not appear but I use a command that works the same way:
                            DISPLAY=:0 xrandr --output HDMI-1 --rotate inverted
                            • EthyxE Offline
                              Ethyx
                              @BKeyport I’ve tried this on a RPi 3B+ as well and same issue.
                              • BKeyportB Offline
                                BKeyport Module Developer @Ethyx
                                I’ve never adjusted the screen using the Display:0 thing.
                                If you have a spare SD Card, I’d recommend building up a “clean” OS for testing, to see if something was done that unintentionally broke the rotate feature.
                                That’s one of the first things I do when I’m having trouble with something I’m trying to do - I build a new OS, install the basics, and test with it, in this case using https://pimylifeup.com/raspberry-pi-rotate-screen/ as a guide.
                                Just to confirm as you’ve mentioned multiple Pi versions -
                                You’ve not shared SD cards between them, right?
                                You haven’t copied the rotate config files from one to the other, right?
                                Whichever unit is gonna be used in your final product, keep everything on that, and in the future, report to us which hardware and OS you’re using for bug control, as things have changed dramatically over the years. :)
