    MMM-GoogleAssistant not running
    55 Posts 5 Posters 22.3k Views 5 Watching
    • blake_northrupB Offline
      blake_northrup @wirdman
      @wirdman Yep, all good. I just needed to do npm rebuild in the MMM-GoogleAssistant folder. I was doing it in the MagicMirror folder. Thanks again!
      • W Offline
        wirdman
        pleasure
        • W Offline
          wirdman @blake_northrup
          @blake_northrup is it possible for you now his installed to ask him to go on youtube or control your spotify ?
          blake_northrupB 1 Reply Last reply Reply Quote 0
          • W Offline
            wirdman @Guest
              @wirdman Hey, sorry, been a very busy couple of days. I can use it to change lighting, turning off devices in smart home, but when I ask to play Spotify, it just gives me info about a video, but doesn’t play.
              • W Offline
                @blake_northrup no problem.
                okay but about youtube ?
                  @wirdman It doesn’t play videos either. It just gives a snippet of what I ask for, but no video.
                  • W Offline
                    wirdman
                    @Bugsounet @blake_northrup okay because for me now everything work welle but i cannot ask to my google to play something on spotify
                    blake_northrupB S 2 Replies Last reply Reply Quote 0
                      @wirdman Yeah, I will dig around a bit to see what I can come up with. At least mine is controlling my smart devices, so that works for now. Please let me know if you figure it out, and I will do the same.
                        sdetweil @wirdman
                        @wirdman can u use the windows Spotify connect to play Spotify on your mirror pi? ( I can)
                        you have to install one of the Spotify system extensions to make play on pi work.
                        I thought bugsounet said he updated the MMM-Spotify module to do that recently.
                        • W Offline
                          wirdman @sdetweil
                          this part ? cause i have mmm-spotify
                            sdetweil @wirdman
                            @wirdman no. the raspotify system extension
                            https://pimylifeup.com/raspberry-pi-spotify/
                            it is outside mm
                            it is required to play Spotify on pi. with or without mm
                            • W Offline
                              wirdman @sdetweil
                              @sdetweil oh no i didn t know i gonna do that
                                A Former User
                                if you want to use MMM-Spotify:
                                npm run spotify step is not needed (only if you want visual)
                                npm run librespot is needed only if you want to listen music in mirror
                                spotify A2D config should be :
                                spotify: {
                                  useSpotify: true, // because you use and love this sub-module
                                  useIntegred: false, // if you use MMM-Spotify
                                  useLibrespot: true, // if you use librespot
                                  connectTo: "A2D", // set your device name to librespot
                                  username: "MyUsername", // Spotify username for librespot
                                  password: "MyPassword, // Spotify password for librespot
                                better it’s clear with that ;)
                                  Mauro-1998
                                  I also have a problem, I installed everything according to the documentation and it was done correctly, but when I run the application an error appears and the screen goes black. I need help please, thanks.
                                  Captura de pantalla de 2020-08-01 00-14-11.png Captura de pantalla de 2020-08-01 00-13-56.png
                                    A Former User
                                    It’s meens that snowboy module is not builded correctly
                                    I think when you did npm install you should have some errors, right ?
                                    or maybe you did have no error but you try to do an npm fix command
                                    what OS do you use ?
                                      sdetweil @Guest
                                      @Bugsounet this post
                                      https://forum.magicmirror.builders/topic/13383/mmm-googleassistant-doesn-t-run
                                      says running Ubuntu, and note that mm is in a subfolder from the users home folder
                                      /home/mauro/Escritorio/MagicMirror
                                      one error posted shows
                                      cannot find module ./lib/node/index.js error
                                        A Former User
                                        I have some know issue with ubuntu
                                        Snowboy don’t want to build
                                        I have not ubuntu installed to debug it but maybe some package is missing ?
                                        If someone have a working version in ubuntu, simply contact me for updating script/dependencies
                                        in all case, It’s ouside the requirement of GA (for this moment)
                                          A Former User
                                          @sdetweil said in MMM-GoogleAssistant not running:
                                          it’s meens node_modules/@bugsounet/snowboy/lib/node/index.js don’t exist so ?
                                            you can use free VMware player to create a single virtual machine of some other os.
                                            download the os iso boot disk image, and use VMware player to launch it
                                            • 2 / 3
