    MMM-GoogleAssistant not running
    55 Posts 5 Posters 22.3k Views 5 Watching
    • W Offline
      wirdman
      j ai essayé de voir un peut mais l’assistant fonctionne très bien mais il est incapable de lancer une video youtube ou de contrôler Spotify
      en revanche on peut caster sans problème
      Merci d’avance pour tout le travail que tu fais
      quand je lance une requete :
       transcription: { transcription: 'joue les beattles sur youtube', done: true },
        continue: false,
        volume: null,
        lastQuery: {
          type: 'MIC',
          key: null,
          lang: 'fr-FR',
          useScreenOutput: true,
          useAudioOutput: true,
          status: 'standby',
          chime: true
      • W Offline
        wirdman @Guest
        @Bugsounet hahahaha incroyable pour le readme😁
        • blake_northrupB Offline
          blake_northrup
          This morning I noticed that my MMM-GoogleAssistant needed an update, so I updated the module, and now get the black electron screen instead of the Magic Mirror screen. If I removed the module from the config, the Mirror comes up correctly, but when I add my config back, it goes black again. I have tried everything, from removing, then reinstalling, npm rebuild, electron rebuild, and nada. Was working fine until then. Any help would be greatly appreciated. See errors below:
          Module helper loaded: MMM-NowPlayingOnSpotify
          [2020-07-17 13:07:48.310] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
          Expected directory: electron-v6.1-linux-arm-glibc
          Found: [node-v72-linux-arm-glibc]
          This problem can often be fixed by running “npm rebuild” on the current system
          Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/node/extension_binary/electron-v6.1-linux-arm-glibc/grpc_node.node’
          Require stack:
          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js
          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js
          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client.js
          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/index.js
          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/components/assistant.js
          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/google-assistant/index.js
          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/components/assistant.js
          • /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_helper.js
          [2020-07-17 13:07:48.311] [LOG] Loading module helpers …
          [2020-07-17 13:07:48.313] [LOG] No helper found for module: alert.
          [2020-07-17 13:07:48.314] [LOG] Initializing new module helper …
          [2020-07-17 13:07:48.314] [LOG] Module helper loaded: updatenotification
          [2020-07-17 13:07:48.315] [LOG] No helper found for module: clock.
          [2020-07-17 13:07:48.316] [LOG] Initializing new module helper …
          [2020-07-17 13:07:48.317] [LOG] Module helper loaded: calendar
          [2020-07-17 13:07:48.318] [LOG] No helper found for module: MMM-Rainbow.
          [2020-07-17 13:07:48.319] [LOG] No helper found for module: compliments.
          [2020-07-17 13:07:48.320] [LOG] Initializing new module helper …
          [2020-07-17 13:07:48.320] [LOG] Module helper loaded: MMM-SystemStats
          [2020-07-17 13:07:48.321] [LOG] Initializing new module helper …
          [2020-07-17 13:07:48.322] [LOG] Module helper loaded: MMM-Remote-Control
          [2020-07-17 13:07:48.323] [LOG] No helper found for module: currentweather.
          [2020-07-17 13:07:48.324] [LOG] No helper found for module: weatherforecast.
          [2020-07-17 13:07:48.325] [LOG] No helper found for module: MMM-EyeCandy.
          [2020-07-17 13:07:48.327] [LOG] Initializing new module helper …
          [2020-07-17 13:07:48.327] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
          [2020-07-17 13:07:48.352] [ERROR] App threw an error during load
          [2020-07-17 13:07:48.354] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
          Require stack:
          • at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/grpc_extension.js:53:17)
            at Module._compile (internal/modules/cjs/loader.js:786:30)
            at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
            at Module.load (internal/modules/cjs/loader.js:645:32)
            at Function.Module._load (internal/modules/cjs/loader.js:560:12)
            at Module.require (internal/modules/cjs/loader.js:685:19)
            at require (internal/modules/cjs/helpers.js:16:16)
            at Object. (/home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/grpc/src/client_interceptors.js:144:12)
            [2020-07-17 13:07:48.356] [ERROR] Whoops! There was an uncaught exception…
            [2020-07-17 13:07:48.357] [ERROR] Error: Failed to load gRPC binary module because it was not installed for the current system
            Require stack:
            at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10) {
            code: ‘MODULE_NOT_FOUND’
            [2020-07-17 13:07:48.371] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [2020-07-17 13:07:48.372] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [2020-07-17 13:07:48.539] [LOG] Launching application.
          • W Offline
            wirdman @blake_northrup
            @blake_northrup said in MMM-GoogleAssistant not running:
            do you have run
            npm run update
            in google assistant folder and Assistant2Display folder ?
            have it too but you can
            at you mmm-GoogleAssistant folder run
            npm install
            or
            npm rebuild
            blake_northrupB 1 Reply Last reply Reply Quote 1
              blake_northrup @wirdman
              @wirdman You are the man sir! Much appreciated wirdman!
              • W Offline
                @blake_northrup did it work ?
                blake_northrupB 1 Reply Last reply Reply Quote 0
                  @wirdman Yep, all good. I just needed to do npm rebuild in the MMM-GoogleAssistant folder. I was doing it in the MagicMirror folder. Thanks again!
                  • W Offline
                    wirdman
                    pleasure
                    • W Offline
                      @blake_northrup is it possible for you now his installed to ask him to go on youtube or control your spotify ?
                      • W Offline
                        wirdman @Guest
                          @wirdman Hey, sorry, been a very busy couple of days. I can use it to change lighting, turning off devices in smart home, but when I ask to play Spotify, it just gives me info about a video, but doesn’t play.
                          • W Offline
                            @blake_northrup no problem.
                            okay but about youtube ?
                              @wirdman It doesn’t play videos either. It just gives a snippet of what I ask for, but no video.
                              • W Offline
                                wirdman
                                @Bugsounet @blake_northrup okay because for me now everything work welle but i cannot ask to my google to play something on spotify
                                blake_northrupB S 2 Replies Last reply Reply Quote 0
                                  @wirdman Yeah, I will dig around a bit to see what I can come up with. At least mine is controlling my smart devices, so that works for now. Please let me know if you figure it out, and I will do the same.
                                    sdetweil @wirdman
                                    @wirdman can u use the windows Spotify connect to play Spotify on your mirror pi? ( I can)
                                    you have to install one of the Spotify system extensions to make play on pi work.
                                    I thought bugsounet said he updated the MMM-Spotify module to do that recently.
                                    • W Offline
                                      wirdman @sdetweil
                                      this part ? cause i have mmm-spotify
                                        sdetweil @wirdman
                                        @wirdman no. the raspotify system extension
                                        https://pimylifeup.com/raspberry-pi-spotify/
                                        it is outside mm
                                        it is required to play Spotify on pi. with or without mm
                                        • W Offline
                                          wirdman @sdetweil
                                          @sdetweil oh no i didn t know i gonna do that
                                            A Former User
                                            if you want to use MMM-Spotify:
                                            npm run spotify step is not needed (only if you want visual)
                                            npm run librespot is needed only if you want to listen music in mirror
                                            spotify A2D config should be :
                                            spotify: {
                                              useSpotify: true, // because you use and love this sub-module
                                              useIntegred: false, // if you use MMM-Spotify
                                              useLibrespot: true, // if you use librespot
                                              connectTo: "A2D", // set your device name to librespot
                                              username: "MyUsername", // Spotify username for librespot
                                              password: "MyPassword, // Spotify password for librespot
                                            better it’s clear with that ;)
                                            • 2 / 3
