    MM2 shows only Time (worked some minutes ago)
    3 Posts 3 Posters 335 Views 3 Watching
    • Z Offline
      ZebAztian
      Hello there,
      i was installing Mm2 today and tried out some modules.
      All was working fine (except Octoprint Stream) and then from one minute to the other all modules were hidden or not shown on the screen except the clock with date
      Here you can see my config.js (also resetted again and after putting in a new module same error as above)
      What am i doing wrong or where is the mistake?
      also if i start “npm install” then a lot of errors appear
      /* Magic Mirror Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
      var config = {
      	address: "localhost", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: "compliments",
      			position: "middle-center"
      			module: "currentweather",
      				locationID: "2835481", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      				appid: "700d5aff6db1410f7ab49da88d0933b8"
      			module: "weatherforecast",
      			header: "Wetter Vorschau",
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
                      module: "MMM-Fuel",
                      position: "top_left",
                      config: {
                          api_key: "d5b40c42-68d4-3767-d7ac-c118ba7a169a",
                          lat: 49.099680,
                          lng: 9.837190,
                          types: ["e5", "diesel"],
                          sortby: "e5",
                          radius: 10,
                          max: 5,
                          rotateInterval: 120000,
                          updateInterval: 900000
                          module: "MMM-Todoist",
                          position: "bottom_right",   // This can be any of the regions. Best results in left or right regions.
                          header: "Todo-Liste", // This is optional
                          config: { // See 'Configuration options' for more information.
                              hideWhenEmpty: true,
                              accessToken: "55fa7b89de14c3d232890748370f2a9c2f296ce5",
                              maximumEntries: 60,
                              updateInterval: 10*60*1000, // Update every 10 minutes
                              fade: false,
                                  // projects and/or labels is mandatory:
                              projects: [ 2239986494 ],
                              labels: [ "noch zu erledigen" ] // Tasks for any projects with these labels will be shown.
      • mumblebajM Online
        mumblebaj Module Developer @ZebAztian
        @ZebAztian Any reason you have the following in you config?
        useHttps: false, // Support HTTPS or not, default "false" will use HTTP httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true
          sdetweil @mumblebaj
          @mumblebaj that was added to the default config in. 2.12
