MMM-AmbientBrightnessDetection
7 Posts 2 Posters 1.1k Views 2 Watching
  • E Offline
    Eric_H
    Brightness Detection and Auto-Brightness
    Please see a module that samples images from a webcam to calculate the ambient brightness of the light in the room, sends a matching notification with the light level in percentage, while also (optionally) sends a notification to the MMM-RemoteControl to adjust the brightness of the screen accordingly (using that module’s brightness range of 10-200).
    The module samples one image every predefined interval (defaults to 1 minute), and currently supports (and tested over) USB Webcams, while I plan to add support for the PI camera module, which I do not currently have handy, but soon.
    Hope you’d like it. It was born because the mirror was too bright for me at night, or too dim in the daylight, and I wanted to create auto-brightness.
    I’d appreciate your tests and comments!
    https://github.com/eric-h-st/MMM-AmbientBrightnessDetection
    Thank you!
    S E 3 Replies Last reply Jul 25, 2020, 1:45 PM Reply Quote 1
      sdetweil @Eric_H
      @Eric_H cool. some questions
      how do u control the brightness? do all monitors/TV’s respond the same way?
      I have some software already connected to my webcam, are u just taking screen shots? how many images do u need at one time?
      • E Offline
        Eric_H
        Thank you @sdetweil .
        • I control the brightness by sending a notification to the MMM-RemoteControl module (code already written and working, no reason to re-invent), found here.
        • Since the brightness is set programmatic ally via css in that module, I’m not sure how various monitors would react, but I tested on three here, including the one behind the mirror, and they seem to work quite the same.
        • I’m taking a single shot once every configurable interval, with a default of 60 seconds.
        Hope I answered all of your questions.
        Eric
        • E Offline
          Eric_H @Eric_H
          Next to be added:
          • Configurable factor to be added to the brightness level sent to MMM-RemoteControl, to make the brightness range more visible in extreme light/dark cases.
          • CEC support to change the actual brightness of the monitor, if supported.
          • PI camera module support
          E 1 Reply Last reply Jul 25, 2020, 3:01 PM Reply Quote 0
          • E Offline
            Eric_H @Eric_H
            @Eric_H said in MMM-AmbientBrightnessDetection:
            Next to be added:
            ** Now also supported: **
            • E Offline
              Eric_H @Eric_H
              UPDATE:
              Now supporting displaying and animating brightness changes at the top of the screen.
              • E Offline
                Eric_H
                UPDATE: Now supporting the PI camera, as well as configuring which camera to use, if not the default
