    MMM-AmbientBrightnessDetection
    7 Posts 2 Posters 1.9k Views 2 Watching
    • Eric_HE Offline
      Eric_H
      Brightness Detection and Auto-Brightness
      Please see a module that samples images from a webcam to calculate the ambient brightness of the light in the room, sends a matching notification with the light level in percentage, while also (optionally) sends a notification to the MMM-RemoteControl to adjust the brightness of the screen accordingly (using that module’s brightness range of 10-200).
      The module samples one image every predefined interval (defaults to 1 minute), and currently supports (and tested over) USB Webcams, while I plan to add support for the PI camera module, which I do not currently have handy, but soon.
      Hope you’d like it. It was born because the mirror was too bright for me at night, or too dim in the daylight, and I wanted to create auto-brightness.
      I’d appreciate your tests and comments!
      https://github.com/eric-h-st/MMM-AmbientBrightnessDetection
      Thank you!
      S Eric_HE 3 Replies Last reply Reply Quote 1
        sdetweil @Eric_H
        @Eric_H cool. some questions
        how do u control the brightness? do all monitors/TV’s respond the same way?
        I have some software already connected to my webcam, are u just taking screen shots? how many images do u need at one time?
        • Eric_HE Offline
          Eric_H
          Thank you @sdetweil .
          • I control the brightness by sending a notification to the MMM-RemoteControl module (code already written and working, no reason to re-invent), found here.
          • Since the brightness is set programmatic ally via css in that module, I’m not sure how various monitors would react, but I tested on three here, including the one behind the mirror, and they seem to work quite the same.
          • I’m taking a single shot once every configurable interval, with a default of 60 seconds.
          Hope I answered all of your questions.
          Eric
          • Eric_HE Offline
            Eric_H @Eric_H
            Next to be added:
            • Configurable factor to be added to the brightness level sent to MMM-RemoteControl, to make the brightness range more visible in extreme light/dark cases.
            • CEC support to change the actual brightness of the monitor, if supported.
            • PI camera module support
            Eric_HE 1 Reply Last reply Reply Quote 0
            • Eric_HE Offline
              Eric_H @Eric_H
              @Eric_H said in MMM-AmbientBrightnessDetection:
              Next to be added:
              ** Now also supported: **
              • Eric_HE Offline
                Eric_H @Eric_H
                UPDATE:
                Now supporting displaying and animating brightness changes at the top of the screen.
                • Eric_HE Offline
                  Eric_H
                  UPDATE: Now supporting the PI camera, as well as configuring which camera to use, if not the default
