    Nixie Clock
    1 Posts 1 Posters 439 Views 1 Watching
    • N
      nikobix
      MMM-Nixie-Clock
      This is a module for the MagicMirror².
      https://github.com/nikobix/MMM-Nixie-Clock
      This module will float over other moudules, so you may need to adjust the position in the config file. (Fixed this now)
      Using the module - moment.js
      Images found at:
      © 2007-08 Cestmir Hybl, cestmir.hybl@nustep.net
      http://cestmir.freeside.sk/projects/dhtml-nixie-display
      and
      https://github.com/McOrts/M5StickC_Nixie_tube_Clock
      To use this module, add the following configuration block to the modules array in the config/config.js file:
      var config = {
                  module: 'MMM-Nixie-Clock',
                  position:"top_left",
                  size: 75,            ** CSS automatically sizes the image size - 10%
