    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 443.5k Views 65 Watching
      Beh @elliot1996
      @elliot1996 I would need more information to help you debug this. Are you sure you used the right directory for the file? And you used the --user option when executing systemctl?
      Everything you need to know about systemd unit files is here: https://www.freedesktop.org/software/systemd/man/systemd.unit.html
      The file must be in one of the directories mentioned at the top of the page.
      E 1 Reply Last reply
      • E
        elliot1996 @Beh
        @Beh I’m sure I have installed it in the right directory, I followed :curl https://raw.githubusercontent.com/pimutils/vdirsyncer/master/contrib/vdirsyncer.timer | sudo tee /etc/systemd/user/vdirsyncer.timer firstly under the MagicMirror Directory. Then activating using systemctl --user enable vdirsyncer.timer.
        When looking at the status I get : Warning: The unit file, source configuration file or drop-ins of vdirsyncer.timer changed on disk. Run ‘systemctl --user daemon-reload’ to rel
        ● vdirsyncer.timer - Synchronize vdirs
        Loaded: loaded (/etc/systemd/user/vdirsyncer.timer; enabled; vendor preset: enabled)
        Drop-In: /home/smartm/.config/systemd/user/vdirsyncer.timer.d
        └─override.conf
        Active: inactive (dead)
        Trigger: n/a
        Apr 13 18:38:50 smartm-Latitude-E6230 systemd[915]: /home/smartm/.config/systemd/user/vdirsyncer.timer.d/override.conf:1: Assignment outside o
        Apr 13 18:38:50 smartm-Latitude-E6230 systemd[915]: /home/smartm/.config/systemd/user/vdirsyncer.timer.d/override.conf:2: Assignment outside o
        Apr 13 18:46:21 smartm-Latitude-E6230 systemd[915]: /home/smartm/.config/systemd/user/vdirsyncer.timer.d/override.conf:1: Assignment outside o
        Apr 13 18:46:21 smartm-Latitude-E6230 systemd[915]: /home/smartm/.config/systemd/user/vdirsyncer.timer.d/override.conf:2: Assignment outside o
        lines 1-12/12 (END)
        Anything you could do to help would be amazing! Been trying to get it going all day, my mirrors close to perfect!
        D 1 Reply Last reply
          ShoeBox @Beh
          @Beh this is a great tutorial. Thanks!
            Jaunney
            @Beh
            Hi!
            Thank you for your great solution. All went well till I tried to sync more than one iCloud Calendars.
            Something is getting confused I think.
            Could you please make an example for the right syntax in the following section:
            collections = [“UUID1”, “UUID2”, “UUID3”]
            Something like this?
            I also have now problems to sync two non-iCloud Calenders after the great confusion…
            My module (I use MMM-CalendarExt2) only shows one iCloud-calendar.
            Thanks for your help.
            BEst regards
            Jaunney
            B 1 Reply Last reply
              duxnobis
              Hi. Try to participate as well :-). I am totally new to the Raspberry world and so to MM. I have set up using the step-by-step guide. Thanks for this a lot. Now that I have set this up as expected, the result is not as expected. The other modules work well. Also 3rd party ones. But the calendar says “No upcoming event”. I have managed to obtain the according icloud calendar ID for my PRIVATE calendar. Any idea what I could potentially have wrongly set up or installed?
              Trigger: n/a
              pi@raspberrypi:~/.vdirsyncer $ vdirsyncer discover
              Discovering collections for pair iCloud_to_MagicMirror
              Mirror:
              • “14Exxxxx-xxxx-xxxx-xxxx-xxxxxxxxxEF2”
                iCloud:
              • “14Exxxxx-xxxx-xxxx-xxxx-xxxxxxxxxEF2” (“Patrick”)
              • “73Fxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxB3F” (“Kalender”)
              • “tasks” (“Erinnerungen”)
              • “fc79xxxdf28cxxxxxxxxx42c0dxxxx7d6e3cf0xxxxxxcac0b2e4xxxxxxxxx” (“Peter”)
                Saved for iCloud_to_MagicMirror: collections = [“14Exxxxx-xxxx-xxxx-xxxx-xxxxxxxxxEF2”]
              config file:
              CALDAV Sync
              [pair iCloud_to_MagicMirror]
              a = “Mirror”
              b = “iCloud”
              Calendars also have a color property
              metadata = [“displayname”, “color”]
              [storage Mirror]
              We need a single .ics file for use with the mirror (Attention! This is really slow on big amounts of events.)
              type = “singlefile”
              We’ll put the calendar file to a readable location for the calendar module
              path = “/home/pi/MagicMirror/modules/calendars/%s.ics”
              [storage iCloud]
              type = “caldav”
              url = “https://caldav.icloud.com/”
              Authentication credentials
              username = “xxxxxxxxxxx@mailprovider.com”
              password = “xxxx-xxxx-xxxx-xxxx”
              We only want to sync in the direction TO the mirror, so we make iCloud readonly
              read_only = true
              We only want to sync events
              item_types = [“VEVENT”]
              Can anyone of you help? Maybe you see what I did wrong or you know how I could check some points to see if I did something wrong.
              Thanks for your inputs. Keep in mind, I am new in this ;-)
              Patrick
                duxnobis @elliot1996
                @elliot1996 said in Sync private iCloud calendar with MagicMirror:
                └─override.conf
                Trigger: n/a
                Hi mate. I have the exact same issue. I have everything now up and running. I managed to have two private ical calendars showing up in the mirror. If I sync manually and reload it works fine. Unfortunately I dont manage the damn thing to do it automatically, ideally triggered on an event or at least all few minutes. My settings in the timer are 1min, 2min, 3min. Just because Beh said to avoid all 1min settings. Any Idea?
                Feedy88F 1 Reply Last reply
                • T
                  tobias789
                  • Feedy88F
                    Feedy88 @duxnobis
                    @duxnobis @elliot1996 @Beh
                    Hey guys,
                    just checking in on this topic, as I also have issues with getting the timer to run while manual sync works fine.
                    • Files are in /etc/systemd/user/ (vdirsyncer.service & vdirsyncer.timer)
                    • Ran systemctl --user enable vdirsyncer.timer? (no error or any other feedback in Terminal)
                    • Checked jorunalctl --user -u vdirsyncer with the result:
                      No journal files were found. -- No Entries --
                    I even went forward and tried to sync using a cronjob but this is unfortuately also not working:
                    error: Unknown error occured for iCloud_to_MagicMirror/9*******-****-****-****-************D: HTTPSConnectionPool(host='p65-caldav.icloud.com', port=443): Max retries exceeded with url: /1355377534/calendars/9*******-****-****-****-************D/ (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')])")))
                    error: Use `-vdebug` to see the full traceback.
                    error: 1 out of 2 tasks failed.
                    Syncing iCloud_to_MagicMirror/9*******-****-****-****-************D
                    Anyone has an Idea?
                    • Feedy88F
                      Feedy88
                      @elliot1996 @duxnobis not sure if anyone is still following, but I was able to get the automated sync with a work around through cronjob. Step-by-step guide below:
                      1. Create Shell script
                      First we need to create the script which is actually executed by the cronjob. To do this we open a terminal and type
                      nano ~/MagicMirror/modules/calendars/vdirsyncer.sh
                      Within the editor we just write a one-liner:
                      vdirsyncer -vinfo sync
                      Close by CTRL+X and save by confirming with Y
                      1. Make script executable.
                      Within terminal type
                      chmod +x ~/MagicMirror/modules/calendars/vdirsyncer.sh
                      1. Test the script
                      Run a test if your script works. Within terminal type
                      bash ~/MagicMirror/modules/calendars/vdirsyncer.sh
                      If working as intended you should receive the feedback
                      Syncing iCloud_to_MagicMirror/YOUR-CALENDAR-UUID
                      1. Checking/Changing the Version of vdirsyncer
                      This was actually my biggest issue. I could sync successfully when running the script manually but the actual cronjob failed. Looking into Debug-Logs I found that the manual run used Version 0.16.8 of vdirsyncer while the cronjob used 0.16.7. After manually chaning the versioning if worked as inteded. To ensue you are not running into that issue, let’s check the versioning from the get-go. Within Terminal type
                      sudo nano /usr/bin/vdirsyncer
                      An editor will show you the following code:
                      #!/usr/bin/python3
                      # EASY-INSTALL-ENTRY-SCRIPT: 'vdirsyncer==0.16.7','console_scripts','vdirsyncer'
                      __requires__ = 'vdirsyncer==0.16.7'
                      import re
                      import sys
                      from pkg_resources import load_entry_point
                      if __name__ == '__main__':
                          sys.argv[0] = re.sub(r'(-script\.pyw?|\.exe)?$', '', sys.argv[0])
                          sys.exit(
                              load_entry_point('vdirsyncer= q=0.16.7', 'console_scripts', 'vdirsyncer')()
                      Change all three instances of 0.16.7to 0.16.8, close via CTRL+X and save with Y.
                      1. Create the Cronjob
                      Cronjobs are a great thing. It is pre-installed with UNIX based systems, therefore also with our Raspberry Pi. More information about Cronjobs can be found here. To set up a new cronjob, within Terminal type
                      crontab -e
                      The result will be the following code:
                      # Edit this file to introduce tasks to be run by cron.
                      # Each task to run has to be defined through a single line
                      # indicating with different fields when the task will be run
                      # and what command to run for the task
                      # To define the time you can provide concrete values for
                      # minute (m), hour (h), day of month (dom), month (mon),
                      # and day of week (dow) or use '*' in these fields (for 'any').
                      # Notice that tasks will be started based on the cron's system
                      # daemon's notion of time and timezones.
                      # Output of the crontab jobs (including errors) is sent through
                      # email to the user the crontab file belongs to (unless redirected).
                      # For example, you can run a backup of all your user accounts
                      # at 5 a.m every week with:
                      # 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
                      # For more information see the manual pages of crontab(5) and cron(8)
                      # m h  dom mon dow   command
                      Type a new line at the bottom with the cron syntax. Here is an overview for the timings:
                      # ┌───────────── minute (0 - 59)
                      # │ ┌───────────── hour (0 - 23)
                      # │ │ ┌───────────── day of the month (1 - 31)
                      # │ │ │ ┌───────────── month (1 - 12)
                      # │ │ │ │ ┌───────────── day of the week (0 - 6) (Sunday to Saturday;
                      # │ │ │ │ │                                   7 is also Sunday on some systems)
                      # * * * * * <command to execute>
                      As for us it makes senst to run vdirsyncer every X minutes (I am going with 5 minutes in my case) the syntax looks as follows:
                      */5 * * * *
                      followed by the script to execute:
                      bash ~/MagicMirror/modules/calendars/vdirsyncer.sh >> ~/vdirsyncer.log 2>&1
                      The first part should be familiar to you. What follows after the >> is a log we are creating. This will be helpful in case anything does not work as inteded. The full cronjob should look as follows:
                      */5 * * * * bash ~/MagicMirror/modules/calendars/vdirsyncer.sh >> ~/vdirsyncer.log 2>&1
                      Close again by CTRL+X. You are now ready and have everything set up. The cronjob will start automatically on every startup and run the sync in the interval you have set it up.
                        sdetweil @Feedy88
                        @Feedy88 and if u edit your script and make the 1st line
                        #!/bin/bash
                        when the script is invoked it will launch the script using bash so all the bash symbols, redirection etc can be moved into the script, and you just use the script and to.launch it
                        /home/pi/MagicMirror/modules/calendars/vdirsyncer.sh
                        also, cron typically executes commands as root, so ~/filename will try to write to /root/filename, but not where u intended. so use the full path
                        • Feedy88F
                          Feedy88 @sdetweil
                          @sdetweil Thanks for the notes, but can you explain a bit more into detail. You mean, if I add
                          #!/bin/bash as first line to the script, I can also add the logging part and remove it from the cron?
                          To be honest, I’m quite a noob to Linux based systems and scripts. Nonetheless, hope my answer will help some people to get the sync going who have issues with the timer service from vdirsyncer.
                            sdetweil @Feedy88
                            @Feedy88 yes, if you use the exec command in the script you can capture stdout & stderr and pipe them to a file
                            LOG_FILE=filename
                            Open standard out at $LOG_FILE for write.
                            This has the effect
                            exec 1>$LOG_FILE
                            Redirect standard error to standard out such that
                            standard error ends up going to wherever standard
                            out goes (the file).
                            exec 2>&1
                            normal rest of your script
                              jlnxaer
                              Hello Guys,
                              I’m fairly new to the whole Raspberry Pi Thing.
                              I got the whole Calendar up and running. My only problem is, that it is not syncing automatically…
                              Do you guys know any fix for this problem?
                              The fix from @Feedy88 didn’t work for me unfortunately.
                              Cheers!
                              S T 2 Replies Last reply
                                sdetweil @jlnxaer
                                @jlnxaer did u create a cron job entry?
                                • T
                                  Tribun @jlnxaer
                                  @jlnxaer what does the pm2 log show? Are error messages displayed at the log?
                                  I also had this phenomenon recently, as the calendar did not syncronize automatically. I had an error message in the log. I no longer know the exact wording of the report.
                                  For me it helped to delete and recreate the files under /home/pi/.vdirsyncer/status and the created * .ics files. after creating the data again with “vdirsyncer sync”, everything now runs automatically as described in the instructions.
                                    jlnxaer
                                    @sdetweil You refer to this, right?
                                    */5 * * * *
                                    @Tribun The command for the pm2 log is just “pm2 logs” isn’t it? If yes there seems to be everything fine except for a “EADDRINUSE” Error…
                                    EDIT: I just figured out, that I was missing a command after the Timings… I added that and now it seems to work just fine! Thank you very much guys :D
                                    T 1 Reply Last reply
                                    • T
                                      Tribun @jlnxaer
                                      @jlnxaer
                                      (/home/pi/.vdirsyncer/status) is a hidden folder in /home/pi
                                      you can also find the pm2 log in /home/pi/.pm2/logs this is also hidden.
                                        Beh
                                        I have another hint related to the systemd timer that was originally described in my tutorial.
                                        It is advised to download the vdirsyncer.service and vdirsyncer.timer directly from the web.
                                        You need to adjust the path to the executable in the vdirsyncer.service file!
                                        It defaults to ExecStart=/usr/bin/vdirsyncer sync, which can be wrong.
                                        But probably it is in ~/.local/bin. (Can be different depending on your installation. Just check location with which vdirsyncer.
                                        This should make the initially described automatic sync work again.
                                          Beh @Jaunney
                                          @Jaunney I don’t see that this has ben answered yet.
                                          collections = [“UUID1”, “UUID2”, “UUID3”] is what I use in my config and it works.
                                          Of course, you need to add a new calender to your calender module to make them visible on the mirror. You need one for every UUID. If you look into your target sync folder on the Pi, there should be 3 .ics files for each UUID. Those are, in fact, 3 separate calendars
                                          • N
                                            Nd_27
                                            Hey,
                                            im new to this but trying my best.
                                            The Sync with calendar works fine, but the sync to the reminders won’t work.
                                            I added the “VTODO” but there are do VTODO in the *.ics File.
                                            Does i have to do anything else and how the calendar shown the Reminders?
                                            Sorry again, im very new and this is my very first project.
                                            best regards
                                            Niklas
                                            • 6 / 9
