    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 445.4k Views 65 Watching
      duxnobis @elliot1996
      @elliot1996 said in Sync private iCloud calendar with MagicMirror:
      @Beh I’m sure I have installed it in the right directory, I followed :curl https://raw.githubusercontent.com/pimutils/vdirsyncer/master/contrib/vdirsyncer.timer | sudo tee /etc/systemd/user/vdirsyncer.timer firstly under the MagicMirror Directory. Then activating using systemctl --user enable vdirsyncer.timer.
      When looking at the status I get : Warning: The unit file, source configuration file or drop-ins of vdirsyncer.timer changed on disk. Run ‘systemctl --user daemon-reload’ to rel
      ● vdirsyncer.timer - Synchronize vdirs
      Loaded: loaded (/etc/systemd/user/vdirsyncer.timer; enabled; vendor preset: enabled)
      Drop-In: /home/smartm/.config/systemd/user/vdirsyncer.timer.d
      └─override.conf
      Active: inactive (dead)
      Trigger: n/a
      Hi mate. I have the exact same issue. I have everything now up and running. I managed to have two private ical calendars showing up in the mirror. If I sync manually and reload it works fine. Unfortunately I dont manage the damn thing to do it automatically, ideally triggered on an event or at least all few minutes. My settings in the timer are 1min, 2min, 3min. Just because Beh said to avoid all 1min settings. Any Idea?
      Feedy88F 1 Reply Last reply
      • T
        tobias789
        • Feedy88F
          Feedy88 @duxnobis
          @duxnobis @elliot1996 @Beh
          Hey guys,
          just checking in on this topic, as I also have issues with getting the timer to run while manual sync works fine.
          • Files are in /etc/systemd/user/ (vdirsyncer.service & vdirsyncer.timer)
          • Ran systemctl --user enable vdirsyncer.timer? (no error or any other feedback in Terminal)
          • Checked jorunalctl --user -u vdirsyncer with the result:
            No journal files were found. -- No Entries --
          I even went forward and tried to sync using a cronjob but this is unfortuately also not working:
          error: Unknown error occured for iCloud_to_MagicMirror/9*******-****-****-****-************D: HTTPSConnectionPool(host='p65-caldav.icloud.com', port=443): Max retries exceeded with url: /1355377534/calendars/9*******-****-****-****-************D/ (Caused by SSLError(SSLError("bad handshake: Error([('SSL routines', 'tls_process_server_certificate', 'certificate verify failed')])")))
          error: Use `-vdebug` to see the full traceback.
          error: 1 out of 2 tasks failed.
          Syncing iCloud_to_MagicMirror/9*******-****-****-****-************D
          Anyone has an Idea?
          • Feedy88F
            Feedy88
            @elliot1996 @duxnobis not sure if anyone is still following, but I was able to get the automated sync with a work around through cronjob. Step-by-step guide below:
            1. Create Shell script
            First we need to create the script which is actually executed by the cronjob. To do this we open a terminal and type
            nano ~/MagicMirror/modules/calendars/vdirsyncer.sh
            Within the editor we just write a one-liner:
            vdirsyncer -vinfo sync
            Close by CTRL+X and save by confirming with Y
            1. Make script executable.
            Within terminal type
            chmod +x ~/MagicMirror/modules/calendars/vdirsyncer.sh
            1. Test the script
            Run a test if your script works. Within terminal type
            bash ~/MagicMirror/modules/calendars/vdirsyncer.sh
            If working as intended you should receive the feedback
            Syncing iCloud_to_MagicMirror/YOUR-CALENDAR-UUID
            1. Checking/Changing the Version of vdirsyncer
            This was actually my biggest issue. I could sync successfully when running the script manually but the actual cronjob failed. Looking into Debug-Logs I found that the manual run used Version 0.16.8 of vdirsyncer while the cronjob used 0.16.7. After manually chaning the versioning if worked as inteded. To ensue you are not running into that issue, let’s check the versioning from the get-go. Within Terminal type
            sudo nano /usr/bin/vdirsyncer
            An editor will show you the following code:
            #!/usr/bin/python3
            # EASY-INSTALL-ENTRY-SCRIPT: 'vdirsyncer==0.16.7','console_scripts','vdirsyncer'
            __requires__ = 'vdirsyncer==0.16.7'
            import re
            import sys
            from pkg_resources import load_entry_point
            if __name__ == '__main__':
                sys.argv[0] = re.sub(r'(-script\.pyw?|\.exe)?$', '', sys.argv[0])
                sys.exit(
                    load_entry_point('vdirsyncer= q=0.16.7', 'console_scripts', 'vdirsyncer')()
            Change all three instances of 0.16.7to 0.16.8, close via CTRL+X and save with Y.
            1. Create the Cronjob
            Cronjobs are a great thing. It is pre-installed with UNIX based systems, therefore also with our Raspberry Pi. More information about Cronjobs can be found here. To set up a new cronjob, within Terminal type
            crontab -e
            The result will be the following code:
            # Edit this file to introduce tasks to be run by cron.
            # Each task to run has to be defined through a single line
            # indicating with different fields when the task will be run
            # and what command to run for the task
            # To define the time you can provide concrete values for
            # minute (m), hour (h), day of month (dom), month (mon),
            # and day of week (dow) or use '*' in these fields (for 'any').
            # Notice that tasks will be started based on the cron's system
            # daemon's notion of time and timezones.
            # Output of the crontab jobs (including errors) is sent through
            # email to the user the crontab file belongs to (unless redirected).
            # For example, you can run a backup of all your user accounts
            # at 5 a.m every week with:
            # 0 5 * * 1 tar -zcf /var/backups/home.tgz /home/
            # For more information see the manual pages of crontab(5) and cron(8)
            # m h  dom mon dow   command
            Type a new line at the bottom with the cron syntax. Here is an overview for the timings:
            # ┌───────────── minute (0 - 59)
            # │ ┌───────────── hour (0 - 23)
            # │ │ ┌───────────── day of the month (1 - 31)
            # │ │ │ ┌───────────── month (1 - 12)
            # │ │ │ │ ┌───────────── day of the week (0 - 6) (Sunday to Saturday;
            # │ │ │ │ │                                   7 is also Sunday on some systems)
            # * * * * * <command to execute>
            As for us it makes senst to run vdirsyncer every X minutes (I am going with 5 minutes in my case) the syntax looks as follows:
            */5 * * * *
            followed by the script to execute:
            bash ~/MagicMirror/modules/calendars/vdirsyncer.sh >> ~/vdirsyncer.log 2>&1
            The first part should be familiar to you. What follows after the >> is a log we are creating. This will be helpful in case anything does not work as inteded. The full cronjob should look as follows:
            */5 * * * * bash ~/MagicMirror/modules/calendars/vdirsyncer.sh >> ~/vdirsyncer.log 2>&1
            Close again by CTRL+X. You are now ready and have everything set up. The cronjob will start automatically on every startup and run the sync in the interval you have set it up.
              sdetweil @Feedy88
              @Feedy88 and if u edit your script and make the 1st line
              #!/bin/bash
              when the script is invoked it will launch the script using bash so all the bash symbols, redirection etc can be moved into the script, and you just use the script and to.launch it
              /home/pi/MagicMirror/modules/calendars/vdirsyncer.sh
              also, cron typically executes commands as root, so ~/filename will try to write to /root/filename, but not where u intended. so use the full path
              • Feedy88F
                Feedy88 @sdetweil
                @sdetweil Thanks for the notes, but can you explain a bit more into detail. You mean, if I add
                #!/bin/bash as first line to the script, I can also add the logging part and remove it from the cron?
                To be honest, I’m quite a noob to Linux based systems and scripts. Nonetheless, hope my answer will help some people to get the sync going who have issues with the timer service from vdirsyncer.
                  sdetweil @Feedy88
                  @Feedy88 yes, if you use the exec command in the script you can capture stdout & stderr and pipe them to a file
                  LOG_FILE=filename
                  Open standard out at $LOG_FILE for write.
                  This has the effect
                  exec 1>$LOG_FILE
                  Redirect standard error to standard out such that
                  standard error ends up going to wherever standard
                  out goes (the file).
                  exec 2>&1
                  normal rest of your script
                    jlnxaer
                    Hello Guys,
                    I’m fairly new to the whole Raspberry Pi Thing.
                    I got the whole Calendar up and running. My only problem is, that it is not syncing automatically…
                    Do you guys know any fix for this problem?
                    The fix from @Feedy88 didn’t work for me unfortunately.
                    Cheers!
                    S T 2 Replies Last reply
                      sdetweil @jlnxaer
                      @jlnxaer did u create a cron job entry?
                      • T
                        Tribun @jlnxaer
                        @jlnxaer what does the pm2 log show? Are error messages displayed at the log?
                        I also had this phenomenon recently, as the calendar did not syncronize automatically. I had an error message in the log. I no longer know the exact wording of the report.
                        For me it helped to delete and recreate the files under /home/pi/.vdirsyncer/status and the created * .ics files. after creating the data again with “vdirsyncer sync”, everything now runs automatically as described in the instructions.
                          jlnxaer
                          @sdetweil You refer to this, right?
                          */5 * * * *
                          @Tribun The command for the pm2 log is just “pm2 logs” isn’t it? If yes there seems to be everything fine except for a “EADDRINUSE” Error…
                          EDIT: I just figured out, that I was missing a command after the Timings… I added that and now it seems to work just fine! Thank you very much guys :D
                          T 1 Reply Last reply
                          • T
                            Tribun @jlnxaer
                            @jlnxaer
                            (/home/pi/.vdirsyncer/status) is a hidden folder in /home/pi
                            you can also find the pm2 log in /home/pi/.pm2/logs this is also hidden.
                            • BehB
                              Beh
                              I have another hint related to the systemd timer that was originally described in my tutorial.
                              It is advised to download the vdirsyncer.service and vdirsyncer.timer directly from the web.
                              You need to adjust the path to the executable in the vdirsyncer.service file!
                              It defaults to ExecStart=/usr/bin/vdirsyncer sync, which can be wrong.
                              But probably it is in ~/.local/bin. (Can be different depending on your installation. Just check location with which vdirsyncer.
                              This should make the initially described automatic sync work again.
                              • BehB
                                Beh @Jaunney
                                @Jaunney I don’t see that this has ben answered yet.
                                collections = [“UUID1”, “UUID2”, “UUID3”] is what I use in my config and it works.
                                Of course, you need to add a new calender to your calender module to make them visible on the mirror. You need one for every UUID. If you look into your target sync folder on the Pi, there should be 3 .ics files for each UUID. Those are, in fact, 3 separate calendars
                                • N
                                  Nd_27
                                  Hey,
                                  im new to this but trying my best.
                                  The Sync with calendar works fine, but the sync to the reminders won’t work.
                                  I added the “VTODO” but there are do VTODO in the *.ics File.
                                  Does i have to do anything else and how the calendar shown the Reminders?
                                  Sorry again, im very new and this is my very first project.
                                  best regards
                                  Niklas
                                    mwallis
                                    Ok … Trying to sync my iCal calendars and I get this every time:
                                    error: Unknown error occurred: name 'r130' is not defined
                                    error: 1 out of 1 tasks failed.
                                    Any ideas?
                                    • AssassinsA
                                      Assassins
                                      @Beh thanks for this. everything is working fine for me just a small error I wanted to ask about in my /home/pi/.pm2/logs/MagicMirror-error.log, it complains the following:
                                      ERROR! Could not find main module js file for calendars
                                      Its not a show stopper but because the calendars folder is created in the modules folder this is why it is asking for a js file.
                                        sdetweil @Assassins
                                        @assassins calendar is actually in the modules/default folder
                                        AssassinsA 1 Reply Last reply
                                        • AssassinsA
                                          Assassins @sdetweil
                                          @sdetweil Yes i now, but i have do all the step, and this error come up
                                            sdetweil @Assassins
                                            @assassins but u said the calendar folder was created. and its looking for the js file… so i think you didnt use the right folder
                                            • 6 / 9
