    *NEW LIST 29.06.2021* Two way community order for mirror glass for all european countries - Open until at least 10 people have entered
    321 Posts 62 Posters 785.8k Views 56 Watching
    • F Offline
      fribse @Goldjunge_Chriz
      @Goldjunge_Chriz weehee :-D
      • I Offline
        Ivanov_d
        Has anyone received their mirror? Mine arrived today but it is broken :(
        F 1 Reply Last reply Reply Quote 1
        • F Offline
          fribse @Ivanov_d
          @Ivanov_d Mine arrived in one piece, though I never got a notification from the danish postal system, so I had to find it through customer service, that couldn’t give me a danish tracking number, but fortunately the guy at the post office was a bright kid, that could find it from the description with ‘fragile’ and ‘glass’ written all over it.
          • I Offline
            Ivanov_d @fribse
            @fribse said in Two way community order for mirror glass for all european countries - Open until at least 10 people have entered the list:
            Lucky you. It seems like somebody stepped on the package and broke it.
            • uros76U Offline
              uros76
              I got mine luckily in one piece. But it did have a small chip on one of the edges. Possible damage through process of sanding off edges…
              By the way, how to be 100% which side is correct? One looks slightly more reflective than other but I am not sure :/
              • F Offline
                fribse @uros76
                @uros76 Chris told me that the side with the protective film on is the ‘outside’ of the mirror.
                uros76U 1 Reply Last reply Reply Quote 0
                • G Offline
                  Goldjunge_Chriz
                  @Ivanov_d and I are already in contact by private message. I am sorry that the mirror arrived damaged. I am already in contact with the shipping company. Unfortunately, @Ivanov_d did not complain about the external damage to the wooden box when he accepted it or refused to accept it. Now it will be very difficult to prove anything to the shipping company, the company will now claim that @Ivanov_d broke it after they brought it to him. As it looks, due to this omission, the burden of proof now lies with us and that is going to be damn difficult…
                  • I Offline
                    Ivanov_d
                    • uros76U Offline
                      uros76 @fribse
                      Protective film? Mine did not have any protective film.
                      @Goldjunge_Chriz can you indicate how do I recognize which side is which?
                      • G Offline
                        Goldjunge_Chriz @uros76
                        @uros76 said in Two way community order for mirror glass for all european countries - Open until at least 10 people have entered the list:
                        that’s true. There was no film attached to one of the mirrors at the factory. then that was probably yours :) the film also has no function, but is simply intended to show the correct side.
                        If you compare both sides with each other and hold them in the light, you should notice a side that is a little lighter and reflects better. this is the coated side, i.e. the side you look into. The other side has a little less mirror effect.
                        • uros76U Offline
                          uros76 @Goldjunge_Chriz
                          @Goldjunge_Chriz said in Two way community order for mirror glass for all european countries - Open until at least 10 people have entered the list:
                          Yaaay lucky lottery winner :D I did it this way and hoped it’s correct. Thanks for confirming it.
                          I am now waiting for a frame to be built. Then assembly and mounting on wall…
                          • hoztH Offline
                            hozt
                            I luckily got mine in one piece too, since the box seemed a bit roughed out.
                            I have a small chip on one of the edges, but probably doesn’t interfere with anything.
                            I haven’t tested anything out yet, just want to make sure it was safe :D
                            • G Offline
                              Goldjunge_Chriz
                              it has always been like this 😅 you can often see that the boxes had to go through a lot, but that’s why the mirrors are so well packed that nothing happens anyway ;) so far the mirrors have always arrived safely.
                              ivanov_d had the bad luck that someone walked around on his package and stepped on it several times (there are many shoe prints on it) and that the box was probably misused as a ramp or something. It would have needed an armored wardrobe as shipping packaging to avoid damage here …
                              • G Offline
                                Goldjunge_Chriz
                                The matter has now been finally clarified and Ivanov_d has his damage replaced :) Since otherwise all mirrors have reached the users to their satisfaction and now the unfortunate case of Ivanov_d can also be concluded positively, it is time for a new list :)
                                You can now register again. The conditions from the first thread remain the same ;) I’m not opening a new thread because I think we can continue the orders in this one. So go on guys, let’s see when we get the 10 users full this time :)
                                # username width (m) height (m) real area (m²) area to pay for (min. 0,4 m²) location of delivery additional comments (like polished edges)
                                1 - - - - - - -
                                  malevolent
                                  AT LAST! \o/
                                  Count with me! And let’s hope it won’t last a year to fill the list… :fingers_crossed:
                                  Need to see what benefits have polished edges if the mirror will be inside a wooden frame. Don’t know if there is a tempered glass options and what its cost would be.
                                  So for the moment:
                                  1 malevolent 0.8 0.5 0.4 0.4 Spain -
                                    Azra @malevolent
                                    Very cool - count me in please. I’ll take two of these
                                    2 azra 0.38 0.58 0.22 0.4 Germany -
                                    3 azra 0.38 0.58 0.22 0.4 Germany polished edges
                                    • G Offline
                                      Goldjunge_Chriz @Azra
                                      4 Mascheljefferson 0.85 0.6 0.51 0.51 Germany polished edges
                                        malevolent
                                        One question: Are the glasses tempered?
                                        • G Offline
                                          Goldjunge_Chriz @malevolent
                                          @malevolent said in *NEW LIST 23.08.2020* Two way community order for mirror glass for all european countries - Open until at least 10 people have entered:
                                          no, with a mirror for our application (hanging on a wall in front of a monitor) that is not necessary at all. Tempered glass is only used where it is exposed to particularly high mechanical influences. and that is not the case with a magic mirror.
                                            cluelesscarter
                                            Hey,
                                            I am interested in joining the order, do the mirrors come with pre-made mounting holes?
                                            • 16
                                            • 17
                                            • 6 / 17
