Calendar module - var location
Hello
is it possible to found a VAR with the location in the default calendar module of magic mirror?
I want to use it with the module of localtransport to generate a dynamical search
@tidus5 the calendar events get broadcasted by the calendar module, you can listen to this module and check for destinations like this module https://github.com/RedNax67/MMM-TrafficCal
EDIT: this feature is currently only in the develop branch of MagicMirror available
@strawberry-3.141 thanks :-) yes was a bit lost in the code to found the broadcast
