    MMM-ModuleScheduler for Monitor control
    16 Posts 2 Posters 5.6k Views 2 Watching
      sdetweil @tootiemac3
      @tootiemac3 what is the error displayed
      • T
        tootiemac3
        @sdetweil it tell me it could not validate the config file.
        then this is below that "SyntaxError: Invalid destructuring assignment target
          @tootiemac3 what line number is shown? I don’t see an error like that. show rest of module section in config. use code block pleasr
          T 1 Reply Last reply
          • T
            tootiemac3 @sdetweil
            @sdetweil im not 100% sure what you mean
            • T
              tootiemac3 @tootiemac3
              @sdetweil its showing line 201 has the error.
                @tootiemac3 ok, I can’t see line 201. show the config. paste the text, select it, and use the code block marker ‘</>’ button to mark the selected text
                • T
                  tootiemac3
                  Line 201 according to the config file is the line
                  module: “MMM-ModuleScheduler”,
                    @tootiemac3
                    ok, that means the real error occurred BEFORE line 201, and was detected there. so. show us before
                    • T
                      tootiemac3
                      above that is the working news feed module.
                        @tootiemac3 can u show the config please. change 1 or 2 char in any API key to something to make it garbage
                        • T
                          			module: "newsfeed",
                          			position: "bottom_bar",
                          				feeds: [
                          						title: "BBC UK",
                          						url: "https://feeds.bbci.co.uk/news/rss.xml?edition=uk"
                          				showSourceTitle: true,
                          				 showPublishDate: true,
                          				broadcastNewsFeeds: true,
                          				broadcastNewsUpdates: true
                          	]  // < --- this?
                          },  // < --- this?
                                  module: "MMM-ModuleScheduler",
                                      notification_schedule: [
                                          // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
                                          {notification: 'REMOTE_ACTION', schedule: '20 15 * * *', payload: {action: "MONITORON"}},
                                          // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY  DAY
                                          {notification: 'REMOTE_ACTION', schedule: '25 15 * * *', payload: {action: "MONITOROFF"}},
                                          // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                                          {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
                              };   //< --- ';' this
                            @tootiemac3 said in MMM-ModuleScheduler for Monitor control:
                            ] //< — what is this?
                            }, // < - what is this?
                            ]; // < – what is ‘;’ this?
                              @tootiemac3
                              i would guess that you pasted the ModuleScheduler module block in the wrong place, after the end for the modules ;[] array closure
                              • T
                                @sdetweil thank you so much for this. i think this is what i did then messed up the rest of the coding when i tried to move it around.
                                the advice you gave above about looking at the ] and } was great! i actually managed to get the mirror to boot with scheduler coded and i am now just testing if it will actually work.
                                Fingers crossed!
                                  temporary fix for npm config:check
                                  edit ~/MagicMirror/js/check_config.js
                                  change line 57 to look like this
                                  		const messages = linter.verify(data);
                                  change line 66 to look like this
                                  	//		throw new Error("Wrong syntax in config file!");
