    MMM-ModuleScheduler for Monitor control
    16 Posts 2 Posters 5.4k Views 2 Watching
    • T
      tootiemac3
      @sdetweil it tell me it could not validate the config file.
      then this is below that "SyntaxError: Invalid destructuring assignment target
        sdetweil @tootiemac3
        @tootiemac3 what line number is shown? I don’t see an error like that. show rest of module section in config. use code block pleasr
        • T
          tootiemac3 @sdetweil
          @sdetweil im not 100% sure what you mean
          • T
            tootiemac3 @tootiemac3
            @sdetweil its showing line 201 has the error.
              @tootiemac3 ok, I can’t see line 201. show the config. paste the text, select it, and use the code block marker ‘</>’ button to mark the selected text
              • T
                tootiemac3
                Line 201 according to the config file is the line
                module: “MMM-ModuleScheduler”,
                  @tootiemac3
                  ok, that means the real error occurred BEFORE line 201, and was detected there. so. show us before
                  • T
                    tootiemac3
                    above that is the working news feed module.
                      @tootiemac3 can u show the config please. change 1 or 2 char in any API key to something to make it garbage
                      • T
                        			module: "newsfeed",
                        			position: "bottom_bar",
                        				feeds: [
                        						title: "BBC UK",
                        						url: "https://feeds.bbci.co.uk/news/rss.xml?edition=uk"
                        				showSourceTitle: true,
                        				 showPublishDate: true,
                        				broadcastNewsFeeds: true,
                        				broadcastNewsUpdates: true
                        	]  // < --- this?
                        },  // < --- this?
                                module: "MMM-ModuleScheduler",
                                    notification_schedule: [
                                        // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
                                        {notification: 'REMOTE_ACTION', schedule: '20 15 * * *', payload: {action: "MONITORON"}},
                                        // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY  DAY
                                        {notification: 'REMOTE_ACTION', schedule: '25 15 * * *', payload: {action: "MONITOROFF"}},
                                        // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                                        {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
                            };   //< --- ';' this
                          @tootiemac3 said in MMM-ModuleScheduler for Monitor control:
                          ] //< — what is this?
                          }, // < - what is this?
                          ]; // < – what is ‘;’ this?
                            @tootiemac3
                            i would guess that you pasted the ModuleScheduler module block in the wrong place, after the end for the modules ;[] array closure
                            • T
                              @sdetweil thank you so much for this. i think this is what i did then messed up the rest of the coding when i tried to move it around.
                              the advice you gave above about looking at the ] and } was great! i actually managed to get the mirror to boot with scheduler coded and i am now just testing if it will actually work.
                              Fingers crossed!
                                temporary fix for npm config:check
                                edit ~/MagicMirror/js/check_config.js
                                change line 57 to look like this
                                		const messages = linter.verify(data);
                                change line 66 to look like this
                                	//		throw new Error("Wrong syntax in config file!");
