    MMM-ModuleScheduler for Monitor control
    16 Posts 2 Posters 5.6k Views 2 Watching
    • T
      tootiemac3
      Hi All, I am VERY new to all this so apologies.
      I am having trouble using the scheduler to control my monitor.
      I installed both MMM-Modulescheduler and MMM-RemoteControl
      When i try to place the module in my config.js it causes the Mirror to fail to load.
      my config is an identical copy of the example given and yet it still falls over.
      any help is greatly appreciated.
              module: 'MMM-ModuleScheduler',
                  notification_schedule: [
                      // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
                      {notification: 'REMOTE_ACTION', schedule: '30 7 * * *', payload: {action: "MONITORON"}},
                      // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY DAY
                      {notification: 'REMOTE_ACTION', schedule: '30 22 * * *', payload: {action: "MONITOROFF"}},
                      // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                      {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
        sdetweil @tootiemac3
        @tootiemac3 what is the error displayed
        • T
          tootiemac3
          @sdetweil it tell me it could not validate the config file.
          then this is below that "SyntaxError: Invalid destructuring assignment target
            @tootiemac3 what line number is shown? I don’t see an error like that. show rest of module section in config. use code block pleasr
            T 1 Reply Last reply
            • T
              tootiemac3 @sdetweil
              @sdetweil im not 100% sure what you mean
              • T
                tootiemac3 @tootiemac3
                @sdetweil its showing line 201 has the error.
                  @tootiemac3 ok, I can’t see line 201. show the config. paste the text, select it, and use the code block marker ‘</>’ button to mark the selected text
                  • T
                    tootiemac3
                    Line 201 according to the config file is the line
                    module: “MMM-ModuleScheduler”,
                      @tootiemac3
                      ok, that means the real error occurred BEFORE line 201, and was detected there. so. show us before
                      • T
                        tootiemac3
                        above that is the working news feed module.
                          @tootiemac3 can u show the config please. change 1 or 2 char in any API key to something to make it garbage
                          • T
                            			module: "newsfeed",
                            			position: "bottom_bar",
                            				feeds: [
                            						title: "BBC UK",
                            						url: "https://feeds.bbci.co.uk/news/rss.xml?edition=uk"
                            				showSourceTitle: true,
                            				 showPublishDate: true,
                            				broadcastNewsFeeds: true,
                            				broadcastNewsUpdates: true
                            	]  // < --- this?
                            },  // < --- this?
                                    module: "MMM-ModuleScheduler",
                                            {notification: 'REMOTE_ACTION', schedule: '20 15 * * *', payload: {action: "MONITORON"}},
                                            {notification: 'REMOTE_ACTION', schedule: '25 15 * * *', payload: {action: "MONITOROFF"}},
                                };   //< --- ';' this
                              @tootiemac3 said in MMM-ModuleScheduler for Monitor control:
                              ] //< — what is this?
                              }, // < - what is this?
                              ]; // < – what is ‘;’ this?
                                @tootiemac3
                                i would guess that you pasted the ModuleScheduler module block in the wrong place, after the end for the modules ;[] array closure
                                • T
                                  @sdetweil thank you so much for this. i think this is what i did then messed up the rest of the coding when i tried to move it around.
                                  the advice you gave above about looking at the ] and } was great! i actually managed to get the mirror to boot with scheduler coded and i am now just testing if it will actually work.
                                  Fingers crossed!
                                    temporary fix for npm config:check
                                    edit ~/MagicMirror/js/check_config.js
                                    change line 57 to look like this
                                    		const messages = linter.verify(data);
                                    change line 66 to look like this
                                    	//		throw new Error("Wrong syntax in config file!");
