    MMM-ModuleScheduler for Monitor control
    16 Posts 2 Posters 5.6k Views 2 Watching
      sdetweil @tootiemac3
      @tootiemac3 ok, I can’t see line 201. show the config. paste the text, select it, and use the code block marker ‘</>’ button to mark the selected text
      • T
        tootiemac3
        Line 201 according to the config file is the line
        module: “MMM-ModuleScheduler”,
          @tootiemac3
          ok, that means the real error occurred BEFORE line 201, and was detected there. so. show us before
          • T
            tootiemac3
            above that is the working news feed module.
              @tootiemac3 can u show the config please. change 1 or 2 char in any API key to something to make it garbage
              T 1 Reply Last reply
              • T
                tootiemac3 @sdetweil
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "BBC UK",
                						url: "https://feeds.bbci.co.uk/news/rss.xml?edition=uk"
                				showSourceTitle: true,
                				 showPublishDate: true,
                				broadcastNewsFeeds: true,
                				broadcastNewsUpdates: true
                	]  // < --- this?
                },  // < --- this?
                        module: "MMM-ModuleScheduler",
                            notification_schedule: [
                                // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
                                {notification: 'REMOTE_ACTION', schedule: '20 15 * * *', payload: {action: "MONITORON"}},
                                // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY  DAY
                                {notification: 'REMOTE_ACTION', schedule: '25 15 * * *', payload: {action: "MONITOROFF"}},
                                // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                                {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
                    };   //< --- ';' this
                  @tootiemac3 said in MMM-ModuleScheduler for Monitor control:
                  ] //< — what is this?
                  }, // < - what is this?
                  ]; // < – what is ‘;’ this?
                    @tootiemac3
                    i would guess that you pasted the ModuleScheduler module block in the wrong place, after the end for the modules ;[] array closure
                    • T
                      @sdetweil thank you so much for this. i think this is what i did then messed up the rest of the coding when i tried to move it around.
                      the advice you gave above about looking at the ] and } was great! i actually managed to get the mirror to boot with scheduler coded and i am now just testing if it will actually work.
                      Fingers crossed!
                        temporary fix for npm config:check
                        edit ~/MagicMirror/js/check_config.js
                        change line 57 to look like this
                        		const messages = linter.verify(data);
                        change line 66 to look like this
                        	//		throw new Error("Wrong syntax in config file!");
