    Magic mirror with 2 displays
    23 Posts 2 Posters 9.6k Views 2 Watching
    • E Offline
      Ety60
      I used npm start to start both displays
        sdetweil @Ety60
        @Ety60 from the separate mm installation folders, right
        ~/MagicMirror
        and
        ~/MagicMirror2
        assuming there is a coding error someplace, rename like this
        ~/MagicMirror1
        and
        ~/MagicMirror2
        then there is no, MagicMirror folder to use from
        • E Offline
          Ety60
          I have done that but it still uses 1 config file. I have found that it always uses the config file of the MagicMirror that I run first.
            sdetweil @Ety60
            @Ety60 makes no sense. u are doing
            cd ~/MagicMirror1
            npm start
            in another window
            cd ~/MagicMirror2
            npm start
            right
            • E Offline
              Ety60
              thats correct!
                sdetweil @Ety60
                @Ety60 can u show the two console outputs
                • E Offline
                  Ety60
                  There is an error in the second console output. This one:
                  listen EADDRINUSE:  address already in use  128.0.0.1:8080
                    sdetweil @Ety60
                    @Ety60 u have to change the port on the second one as well
                    sorry, looking back I didn’t mention that
                    • E Offline
                      Ety60
                      no problem, I should have looked at the console output earlier. would you just like to tell me which other port I can choose?
                        sdetweil @Ety60
                        @Ety60 try 8090
