    Magic mirror with 2 displays
    23 Posts 2 Posters 10.6k Views 2 Watching
    • E
      Ety60
      I found the error, because I put the 2 screens on top of each other, not x but y = 1920.
      But I have found that the magicmirror2 folder is listening for the config file of the magicmirror folder. How can I adjust this?
        sdetweil @Ety60
        @Ety60 how did u start each mm?
        • E
          Ety60
          I have done npm start on both
            sdetweil @Ety60
            @Ety60 hm… then they should be looking at the config folder under each separate mm folder
            u cannot start it twice from the same folder
            • E
              Ety60
              I used npm start to start both displays
                sdetweil @Ety60
                @Ety60 from the separate mm installation folders, right
                ~/MagicMirror
                and
                ~/MagicMirror2
                assuming there is a coding error someplace, rename like this
                ~/MagicMirror1
                and
                ~/MagicMirror2
                then there is no, MagicMirror folder to use from
                • E
                  Ety60
                  I have done that but it still uses 1 config file. I have found that it always uses the config file of the MagicMirror that I run first.
                    sdetweil @Ety60
                    @Ety60 makes no sense. u are doing
                    cd ~/MagicMirror1
                    npm start
                    in another window
                    cd ~/MagicMirror2
                    npm start
                    right
                    • E
                      Ety60
                      thats correct!
                        sdetweil @Ety60
                        @Ety60 can u show the two console outputs
                        • E
                          Ety60
                          There is an error in the second console output. This one:
                          listen EADDRINUSE:  address already in use  128.0.0.1:8080
                            sdetweil @Ety60
                            @Ety60 u have to change the port on the second one as well
                            sorry, looking back I didn’t mention that
                            • E
                              Ety60
                              no problem, I should have looked at the console output earlier. would you just like to tell me which other port I can choose?
                                sdetweil @Ety60
                                @Ety60 try 8090
