    Magic mirror with 2 displays
    23 Posts 2 Posters 9.1k Views 2 Watching
    • E Offline
      Ety60
      @sdetweil thanks for your quick and very complete answer. But do I understand that it is not possible to run the software on 2 screens? Could it be possible to run a separate magic mirror on each screen?
        sdetweil @Ety60
        @Ety60 yes, rename one MagicMirror folder to MagicMirror2 and install a second instance, and in the config.js of one use the
        electronOptions:{x:1920}
        to display beyond the 1st display
        • E Offline
          Ety60
          @sdetweil I addded electronOptions: {x: 1920} to my config file and I didn’t get an error but it still only shows up on the first screen. Am I doing something wrong?
            sdetweil @Ety60
            @Ety60 like this, inside the config structure
            var config={
               electronOptions:{ x: 1920 },
                modules :[],
            • E Offline
              Ety60
              Thanks for the quick respons
              Yes, exact like that.
                hm, this is mine, cut and paste, opens on second display
                var config = {
                  electronOptions: { x: 1920},
                are you using docker or MagicMirrorOS
                • E Offline
                  Ety60
                  I found the error, because I put the 2 screens on top of each other, not x but y = 1920.
                  But I have found that the magicmirror2 folder is listening for the config file of the magicmirror folder. How can I adjust this?
                    sdetweil @Ety60
                    @Ety60 how did u start each mm?
                    • E Offline
                      Ety60
                      I have done npm start on both
                        sdetweil @Ety60
                        @Ety60 hm… then they should be looking at the config folder under each separate mm folder
                        u cannot start it twice from the same folder
                        • E Offline
                          Ety60
                          I used npm start to start both displays
                            sdetweil @Ety60
                            @Ety60 from the separate mm installation folders, right
                            ~/MagicMirror
                            and
                            ~/MagicMirror2
                            assuming there is a coding error someplace, rename like this
                            ~/MagicMirror1
                            and
                            ~/MagicMirror2
                            then there is no, MagicMirror folder to use from
                            • E Offline
                              Ety60
                              I have done that but it still uses 1 config file. I have found that it always uses the config file of the MagicMirror that I run first.
                                sdetweil @Ety60
                                @Ety60 makes no sense. u are doing
                                cd ~/MagicMirror1
                                npm start
                                in another window
                                cd ~/MagicMirror2
                                npm start
                                right
                                • E Offline
                                  Ety60
                                  thats correct!
                                    sdetweil @Ety60
                                    @Ety60 can u show the two console outputs
                                    • E Offline
                                      Ety60
                                      There is an error in the second console output. This one:
                                      listen EADDRINUSE:  address already in use  128.0.0.1:8080
                                        sdetweil @Ety60
                                        @Ety60 u have to change the port on the second one as well
                                        sorry, looking back I didn’t mention that
                                        • E Offline
                                          Ety60
                                          no problem, I should have looked at the console output earlier. would you just like to tell me which other port I can choose?
                                            sdetweil @Ety60
                                            @Ety60 try 8090
