    Magic mirror with 2 displays
    23 Posts 2 Posters 10.6k Views 2 Watching
      sdetweil @Ety60
      @Ety60 I haven’t been able to make it use both displays on startup… I can drag the image to fill both screens…
      you can fiddle with the display options
      var config = {
           electronOptions : { ????? },
           modules : []
      x and y describe the top left corner of the display
      width and height describe the size and shape of the page
      kiosk mode turns on fullscreen, no title bar, and some other things, not resizable I think… really a pain on mac)
      the defintion of these options are here
      https://www.electronjs.org/docs/api/browser-window
      I use the electronOptions to have MM run on the second display on my desktop system
      electronOptions: { x: 1920 },
      so I tried
       electronOptions: { x: 0, width: 1920, height: 2160, minHeight: 2160, kiosk: false, fullscreen: false,  backgroundColor: "#00000001", autoHideMenuBar :true},
      and it starts fullscreen on the 1st monitor (had to crop the screen shot to get it under 2 meg)
      and
      electronOptions: { x: 1920, width: 1920, height: 2160, minHeight: 2160, kiosk: false, fullscreen: false,  backgroundColor: "#00000001", autoHideMenuBar :true},
      and it starts large, on the second monitor, but not quite full screen as the taskbar is not present on monitor 2.
      neither the system , nor MM know about the physical placement of the displays
        @Ety60 i have played with all kinds of scripts that ‘should’ work, but don’t… all oldish 2-3 years
        • E
          Ety60
          @sdetweil thanks for your quick and very complete answer. But do I understand that it is not possible to run the software on 2 screens? Could it be possible to run a separate magic mirror on each screen?
            sdetweil @Ety60
            @Ety60 yes, rename one MagicMirror folder to MagicMirror2 and install a second instance, and in the config.js of one use the
            electronOptions:{x:1920}
            to display beyond the 1st display
            • E
              Ety60
              @sdetweil I addded electronOptions: {x: 1920} to my config file and I didn’t get an error but it still only shows up on the first screen. Am I doing something wrong?
                sdetweil @Ety60
                @Ety60 like this, inside the config structure
                var config={
                   electronOptions:{ x: 1920 },
                    modules :[],
                • E
                  Ety60
                  Thanks for the quick respons
                  Yes, exact like that.
                    hm, this is mine, cut and paste, opens on second display
                    var config = {
                      electronOptions: { x: 1920},
                    are you using docker or MagicMirrorOS
                    • E
                      Ety60
                      I found the error, because I put the 2 screens on top of each other, not x but y = 1920.
                      But I have found that the magicmirror2 folder is listening for the config file of the magicmirror folder. How can I adjust this?
                        sdetweil @Ety60
                        @Ety60 how did u start each mm?
                        • E
                          Ety60
                          I have done npm start on both
                            sdetweil @Ety60
                            @Ety60 hm… then they should be looking at the config folder under each separate mm folder
                            u cannot start it twice from the same folder
                            • E
                              Ety60
                              I used npm start to start both displays
                                sdetweil @Ety60
                                @Ety60 from the separate mm installation folders, right
                                ~/MagicMirror
                                and
                                ~/MagicMirror2
                                assuming there is a coding error someplace, rename like this
                                ~/MagicMirror1
                                and
                                ~/MagicMirror2
                                then there is no, MagicMirror folder to use from
                                • E
                                  Ety60
                                  I have done that but it still uses 1 config file. I have found that it always uses the config file of the MagicMirror that I run first.
                                    sdetweil @Ety60
                                    @Ety60 makes no sense. u are doing
                                    cd ~/MagicMirror1
                                    npm start
                                    in another window
                                    cd ~/MagicMirror2
                                    npm start
                                    right
                                    • E
                                      Ety60
                                      thats correct!
                                        sdetweil @Ety60
                                        @Ety60 can u show the two console outputs
                                        • E
                                          Ety60
                                          There is an error in the second console output. This one:
                                          listen EADDRINUSE:  address already in use  128.0.0.1:8080
                                            sdetweil @Ety60
                                            @Ety60 u have to change the port on the second one as well
                                            sorry, looking back I didn’t mention that
