    Magic mirror with 2 displays
    23 Posts 2 Posters 9.6k Views 2 Watching
    • E Offline
      Ety60
      hello everyone, I am making a Magic Mirror with an rpi4 and 2 screens that I place on top of each other. When I run the Magic Mirror software, it only shows on 1 screen. Is there a possibility to do this on the 2 screens?
        sdetweil @Ety60
        @Ety60 I haven’t been able to make it use both displays on startup… I can drag the image to fill both screens…
        you can fiddle with the display options
        var config = {
             electronOptions : { ????? },
             modules : []
        x and y describe the top left corner of the display
        width and height describe the size and shape of the page
        kiosk mode turns on fullscreen, no title bar, and some other things, not resizable I think… really a pain on mac)
        the defintion of these options are here
        https://www.electronjs.org/docs/api/browser-window
        I use the electronOptions to have MM run on the second display on my desktop system
        electronOptions: { x: 1920 },
        so I tried
         electronOptions: { x: 0, width: 1920, height: 2160, minHeight: 2160, kiosk: false, fullscreen: false,  backgroundColor: "#00000001", autoHideMenuBar :true},
        and it starts fullscreen on the 1st monitor (had to crop the screen shot to get it under 2 meg)
        and
        electronOptions: { x: 1920, width: 1920, height: 2160, minHeight: 2160, kiosk: false, fullscreen: false,  backgroundColor: "#00000001", autoHideMenuBar :true},
        and it starts large, on the second monitor, but not quite full screen as the taskbar is not present on monitor 2.
        neither the system , nor MM know about the physical placement of the displays
          @Ety60 i have played with all kinds of scripts that ‘should’ work, but don’t… all oldish 2-3 years
          • E Offline
            Ety60
            @sdetweil thanks for your quick and very complete answer. But do I understand that it is not possible to run the software on 2 screens? Could it be possible to run a separate magic mirror on each screen?
              sdetweil @Ety60
              @Ety60 yes, rename one MagicMirror folder to MagicMirror2 and install a second instance, and in the config.js of one use the
              electronOptions:{x:1920}
              to display beyond the 1st display
              • E Offline
                Ety60
                @sdetweil I addded electronOptions: {x: 1920} to my config file and I didn’t get an error but it still only shows up on the first screen. Am I doing something wrong?
                  sdetweil @Ety60
                  @Ety60 like this, inside the config structure
                  var config={
                     electronOptions:{ x: 1920 },
                      modules :[],
                  • E Offline
                    Ety60
                    Thanks for the quick respons
                    Yes, exact like that.
                      hm, this is mine, cut and paste, opens on second display
                      var config = {
                        electronOptions: { x: 1920},
                      are you using docker or MagicMirrorOS
                      • E Offline
                        Ety60
                        I found the error, because I put the 2 screens on top of each other, not x but y = 1920.
                        But I have found that the magicmirror2 folder is listening for the config file of the magicmirror folder. How can I adjust this?
                          sdetweil @Ety60
                          @Ety60 how did u start each mm?
                          • E Offline
                            Ety60
                            I have done npm start on both
                              sdetweil @Ety60
                              @Ety60 hm… then they should be looking at the config folder under each separate mm folder
                              u cannot start it twice from the same folder
                              • E Offline
                                Ety60
                                I used npm start to start both displays
                                  sdetweil @Ety60
                                  @Ety60 from the separate mm installation folders, right
                                  ~/MagicMirror
                                  and
                                  ~/MagicMirror2
                                  assuming there is a coding error someplace, rename like this
                                  ~/MagicMirror1
                                  and
                                  ~/MagicMirror2
                                  then there is no, MagicMirror folder to use from
                                  • E Offline
                                    Ety60
                                    I have done that but it still uses 1 config file. I have found that it always uses the config file of the MagicMirror that I run first.
                                      sdetweil @Ety60
                                      @Ety60 makes no sense. u are doing
                                      cd ~/MagicMirror1
                                      npm start
                                      in another window
                                      cd ~/MagicMirror2
                                      npm start
                                      right
                                      • E Offline
                                        Ety60
                                        thats correct!
                                          sdetweil @Ety60
                                          @Ety60 can u show the two console outputs
                                          • E Offline
                                            Ety60
                                            There is an error in the second console output. This one:
                                            listen EADDRINUSE:  address already in use  128.0.0.1:8080
