    MMM-GoogleAssistant
    Scheduled Pinned Locked Moved Unsolved Development
    18 Posts 3 Posters 4.4k Views 3 Watching
      MrDondoT
      Hello guys,
      I’m wondering (I couldn’t find anywere) if the MMM-GoogleAssistant module can be activated using a personal snowboy hotword detector (*.pmdl).
      If yes, is the config the same?
      				snowboy: {
      				  audioGain: 2.0,
      				  Frontend: true, //use true with other models
      				  Model: "rachele",
      				  Sensitivity: 0.7 //null
      thanks
        sdetweil @MrDondoT
        @MrDondoT yes, and yes.
          MrDondoT
          ouch! thanks!!
          Great stuff
          Btw, I would suggest to write a note about it in the documentation.
            sdetweil @MrDondoT
            @MrDondoT I would open an issue in the GitHub repo.
            I am not the author.
              MrDondoT @sdetweil
              :folded_hands: appreciate
              but the mm will continue restarting with errors.
              I’ve put the rachele.pmdl file in the same dir of the others:
              /home/pi/MagicMirror/modules/MMM-GoogleAssistant/node_modules/@bugsounet/snowboy/resources/models
              and that’s the log:
                sdetweil @MrDondoT
                @MrDondoT and what did u specify in config?
                must the full name rachele.pmdl
                else it will look for the other file type
                  A Former User
                  this feature is not yet supported by GA
                    sdetweil @Guest
                    @Bugsounet booo… how did u break it?
                      A Former User
                      It’s not breaked, just not coded in core of @bugsounet/snowboy
                        MrDondoT @Guest
                        @Bugsounet
                        ahh, that’s why I couldn’t find any support on that.
                        Will you support personal ww?
                        thanks
                          A Former User
                          in the begining, i’m try to make a simple configuration because original snowboy configuration is very … very boring
                          I have planned to add it but not set actually
                          Just official hotkey is supported
                            MrDondoT @Guest
                            @Bugsounet
                            yeah, I’ve seen guys around trying using MMM-Hotword, MMM-Snowboy with your module to get around it, also the old repo https://github.com/gauravsacc/MMM-GoogleAssistant had that option available.
                              A Former User
                              sure,
                              my npm library is NOT the same like original snowboy
                              I use only my own npm library, but i have a lot of module so i have a choice to do for update ;)
                              actually i’m working around MMM-Tools maybe after i will code your feature :)
                              Note:
                              it’s not too complex to add it, just give me time to do it !
                              unfortunately I only have 2 hands … otherwise I will be an octopus mouahahah
                                MrDondoT @Guest
                                @Bugsounet
                                :flexed_biceps:
                                thanks, you did great!
                                  MrDondoT
                                  @Bugsounet
                                  personal model *.pmdl: it works like a charm!
                                  microphone in my rpi4: ReSpeaker Mic Array v2-0
                                  config.js:
                                  snowboy: {
                                  	  usePMDL: true,
                                  	  audioGain: 2.5,
                                  	  Frontend: false, //use true with other models
                                  	  Model: "rachele", //snowboy
                                  	  Sensitivity: 0.6 //null
                                  Frontend: false is better in my case.
                                  tested @3mt away from mic.
                                  Just a typo in MMM-GoogleAssistant.css row 30 and 32 (it was already there in previous version).
                                  Fantastic!
                                    A Former User
                                    thx ;)
                                    I have promise support
                                      MrDondoT @Guest
                                      @Bugsounet :ok_hand:
                                        A Former User
                                        @MrDondoT said in MMM-GoogleAssistant:
                                        thx, i will be corrected for next release
                                        edit:
                                        lol, same in 41 and 43
                                        not really important, but not clean ;)
                                        it can wait again for next release (so go to dev too !)
