    Changing compliments
    49 Posts 9 Posters 47.7k Views 9 Watching
    • K Offline
      KC5RIL
      Oh, great! Another noob needs help configuring the Compliments module. I’ve sussed through this for two days trying to get this up and running to earn ‘cool dad points.’ I’ve followed along and made changes to the config.js file as described. When I run ‘npm start’ I get the following: ```
      code_text
      > magicmirror@2.12.0 start /home/pi/MagicMirror
      [2020-08-19 20:06:47.257] [LOG]    Starting MagicMirror: v2.12.0
      [2020-08-19 20:06:47.264] [LOG]    Loading config ...
      [2020-08-19 20:06:47.268] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:68
      SyntaxError: Unexpected identifier
          at Module._compile (internal/modules/cjs/loader.js:722:23)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
          at Module.load (internal/modules/cjs/loader.js:645:32)
          at Function.Module._load (internal/modules/cjs/loader.js:560:12)
          at Module.require (internal/modules/cjs/loader.js:685:19)
          at require (internal/modules/cjs/helpers.js:16:16)
          at loadConfig (/home/pi/MagicMirror/js/app.js:67:12)
          at App.start (/home/pi/MagicMirror/js/app.js:202:3)
          at Object.<anonymous> (/home/pi/MagicMirror/js/electron.js:126:7)
          at Module._compile (internal/modules/cjs/loader.js:786:30)
      [2020-08-19 20:06:47.269] [LOG]    Loading module helpers ...
      [2020-08-19 20:06:47.317] [LOG]    Initializing new module helper ...
      [2020-08-19 20:06:47.318] [LOG]    Module helper loaded: updatenotification
      [2020-08-19 20:06:47.321] [LOG]    No helper found for module: helloworld.
      [2020-08-19 20:06:47.322] [LOG]    All module helpers loaded.
      [2020-08-19 20:06:47.445] [LOG]    Starting server on port 8080 ...
      [2020-08-19 20:06:47.458] [LOG]    Server started ...
      [2020-08-19 20:06:47.459] [LOG]    Connecting socket for: updatenotification
      [2020-08-19 20:06:47.460] [LOG]    Sockets connected & modules started ...
      [2020-08-19 20:06:47.556] [LOG]    Launching application.
      What am I looking at? And how can I correct? Bear with a middle aged noob. You might have to explain this in crayon. Thanks for the help.
      Mykle1M S 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @KC5RIL
        @KC5RIL
        Post your config entry for compliments in a code block
          sdetweil @KC5RIL
          @KC5RIL > Unexpected identifier
          90% of the time this means a comma missing on the line above
          K 1 Reply Last reply Reply Quote 1
          • K Offline
            KC5RIL @sdetweil
            @sdetweil Stand by, ya’ll. I’m proofing now. Just caught a misplaced comma.
              sdetweil @KC5RIL
              @KC5RIL npm config:check can show these errors.
              has a bug in 2.12, temp fix posted to the top of the troubleshooting section
              • K Offline
                KC5RIL @Mykle1
                @Mykle1 Here’s the code. Figured this seemed like a popular spot to wet my feet. If I could get through this, I could set the rest up.
                			module: "compliments",
                			position: "lower_third"
                			 	   compliments: {
                			 	   "....-01-01": [
                			 	   "Happy New Year!"
                			    	   "....-01-07": [
                				   "Happy Birthday, Matt!"
                				   "....-01-08": [
                				   "Hail to the King, Baby!",
                				   "I'm all shook up!",
                				   "You ain't nuthin' but a hound dog!"
                				   "....-01-25": [
                				   "yaD etisoppO yppaH"
                				   "2021-02-02": [
                				   "It's Groundhog Day \nAgain!"
                				   "....-02-14": [
                				   "Happy Valentine's Day!"
                				   "2021-02-16": [
                				   "Laissez les bon temps rouler!"
                				   "....-03-14": [
                				   "Time for Pi!"
                				   "2021-03-17": [
                				   "Erin Go Bragh!",
                				   "Kiss Me! \nI'm Irish"
                				   "....-04-01": [
                				   "Your shoes are untied.",
                				   "Made you look.",
                				   "April Fools!"
                				   "2021-04-04": [
                				   "Happy Easter!",
                				   "Rejoice!",
                				   "He is Risen!"
                				   "....-05-04": [
                				   "May the Fourth be with you!"
                				   "....-05-06": [
                				   "Revenge of the Sixth!"
                				   "....-05-09": [
                				   "Happy Mother's Day!"
                				   "....-05-25": [
                				   "Don't forget your towel.",
                				   "42!"
                				   "2021-05-31": [
                				   "Happy Memorial Day!"
                				   "2021-06-20": [
                				   "Happy Father's Day!"
                				   "....-07-04": [
                				   "Celebrate your Independence!",
                				   "Freedom!",
                				   "Happy Fourth of July!"
                				   "....-07-09": [
                				   "Happy Birthday, Noodle!"
                				   "....-08-14": [
                				   "Happy Anniversary!"
                				   "2021-09-06": [
                				   "Happy Labor Day!"
                				   "....-09-11": [
                				   "Never Forget.",
                				   "Some gave all",
                				   "343/61",
                				   "Let's Roll!"
                				   "...-10-..": [
                				   "Boo!"
                				   "....-11-16": [
                				   "Happy Birthday, Susanne!"
                				   "2021-11-25": [
                				   "Gobble! Gobble!",
                				   "Happy Thanksgiving!"
                				   "....-12-07": [
                				   "A day that will live in infamy!"
                				   "....-12-23": [
                				   "Time to air our grievances!",
                				   "Festivus for the rest of us!"
                				   "....-12-25": [
                				   "Merry Christmas, Charlie Brown!",
                				   "Rejoice!",
                				   "Christ the Savior is born!"
                				   anytime: {
                				   "Hey!",
                				   "Hello.",
                				   "Whaddup Dog?",
                				   "Dude!",
                				   "Hej!",
                				   "You stay classy!"
                				   morning: [
                				   "Good Morning!",
                				   "Smile \nIt's a beautiful day!",
                				   "Rise and Shine!",
                				   "Wakey Wakey! \nEggs & Baky!",
                				   "Coffee is ready!"
                				   afternoon: [
                				   "Is it beer-thirty, yet?",
                				   "What a wonderful day!"
                				   evening: [
                				   "Good Evening."
                While ya’ll are looking at that, I’ll check the troubleshooting section. Thanks
                  sdetweil @KC5RIL
                  @KC5RIL
                  why did I say?
                  comma missing on the line before the error
                  position: "lower_third", // < -----
                  • K Offline
                    KC5RIL
                    Okay! It’s coming together for me. I’m catching a couple more syntax errors. I’ll keep proofing to see if I catch more.
                      sdetweil @KC5RIL
                      @KC5RIL general rules for the value to the right of :
                      numbers and true/false, no quotes,
                      otherwise needs quotes, doesn’t matter which as long as they are matched.
                      be careful on quotes, these curly ones " ’
                      are no good, but these text mode are
                      ok
                      also if the next line starts with a word, then this line needs a trailing comma
                      • K Offline
                        KC5RIL @sdetweil
                        @sdetweil I’ve proofed all I can. I don’t see anymore syntax errors. Still won’t run properly. Here’s the config:check ```
                        pi@WALL-e:~/MagicMirror $ npm run config:check
                        magicmirror@2.12.0 config:check /home/pi/MagicMirror
                        node js/check_config.js
                        [2020-08-19 21:11:52.797] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
                        [2020-08-19 21:11:52.858] [LOG] Line 194 col 3 Parsing error: Unexpected token {
                        /home/pi/MagicMirror/js/check_config.js:66
                        throw new Error(“Wrong syntax in config file!”);
                        Error: Wrong syntax in config file!
                        at /home/pi/MagicMirror/js/check_config.js:66:10
                        at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! magicmirror@2.12.0 config:check: node js/check_config.js
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.12.0 config:check script.
                        npm ERR! /home/pi/.npm/_logs/2020-08-20T02_11_52_899Z-debug.log
                        • K Offline
                          KC5RIL
                          EUREKA!
                          The error message at start was bothering me. Figured it out with some playing around. needed a ‘}’ at 195. Problem solved.
                          Thanks for ya’lls help. I’ll more than likely pester you again with more issues. Have your crayons ready!
                            sdetweil @KC5RIL
                            @KC5RIL read this
                            https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners?_=1597892229407
                            • 3 / 3
