    MMM-Spotify
    249 Posts 51 Posters 359.7k Views 54 Watching
    • Z
      zauberclown @requiemmg
      @requiemmg I actually have the exact same problem/challenge. I tried to include the module multiple time, but that did not work. Were you able to solve the problem to display multiple accounts in a family account?
      Thx
        sdetweil @zauberclown
        @zauberclown said in MMM-Spotify:
        Thx
        the module will only show what is playing on one device. this is a Spotify limitation
        • Z
          zauberclown @Guest
          @Bugsounet Good I checked the older messages in this thread to better understand the complexity with multiple accounts. I had no idea it would impact the CPU that much. Thanks for pointing out.
          Being able to change it verbally is currently not an option as I don’t plan to implement vocal for my mirror. But can’t think of an alternative as of now.
          BTW: Thanks a lot for your hard work on this module!
            spoonek @Guest
            @Bugsounet said in MMM-Spotify:
            if Soptify logo not hidden after start, it’s means :
            token missing or token error
            you should have in console something like that :
            [SPOTIFY:ERROR] USERNAME: [your username]
            [SPOTIFY:ERROR] Token Error ! ./[token name].json
            @Bugsounet I have this same error. I got the webpage after running node first_auth.js but it said invalid and then I had to CRTL-Z to stop it. Now when I run node first_auth.js I get errors. Do I need to uninstall MMM-Spotify and start from scratch?
            Also, I already am using MMM-NowPlayingOnSpotify and that is working fine. Can I just reuse my existing Client ID and Client Secret? I’m worried that using both modules is causing the issue. I could be wrong though.
            Thanks!
              A Former User
              It’s means that the token is not set
              maybe callback url is not set
              after if you have used the sudo command for install MM or for install this module, it will not work (not write access)
                A Former User
                yes, I can’t display ALL account in the same time.
                example 2 accounts listen at the same time -> what is the visual (complex to determinate) !?
                for CPU time: X account registred = X * CPU time
                So X * time DNS access, X * traffic to spotify
                that’s why i use a switch for another account
                ? 1 Reply Last reply
                  spoonek @Guest
                  @Bugsounet Good point. I was thinking I needed to reuse my client ID credentials I had already setup for MMM-NowPlayingOnSpotify. DOH! I just created a “New App” on the Spotify Dev page for MMM-Spotify. Should be good to go now.
                    A Former User
                    when it want to works ;)
                      spoonek @Guest
                      pi@raspberrypi:~/MagicMirror/modules/MMM-Spotify $ node first_auth.js
                      [SPOTIFY:ERROR] Token not found! /home/pi/MagicMirror/modules/MMM-Spotify/token.json
                      [SPOTIFY] Spotify v1.0.2 Initialized…
                      [SPOTIFY_AUTH] Opening the browser for authentication on Spotify…
                      events.js:174
                      throw er; // Unhandled ‘error’ event
                      Error: listen EADDRINUSE: address already in use :::8888
                      at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                      at listenInCluster (net.js:1328:12)
                      at Server.listen (net.js:1415:7)
                      at Function.listen (/home/pi/MagicMirror/modules/MMM-Spotify/node_modules/express/lib/application.js:618:24)
                      at Spotify.authFlow (/home/pi/MagicMirror/modules/MMM-Spotify/node_modules/@bugsounet/spotify/index.js:310:8)
                      at Promise (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:20:14)
                      at new Promise ()
                      at authorize (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:17:12)
                      at authorizations (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:33:19)
                      at Object. (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:40:1)
                      Emitted ‘error’ event at:
                      at emitErrorNT (net.js:1307:8)
                      at process._tickCallback (internal/process/next_tick.js:63:19)
                      at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
                      at startup (internal/bootstrap/node.js:283:19)
                      at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                        A Former User
                        @spoonek said in MMM-Spotify:
                        it’s mean that the port 8888 il used by another app… free this port temporarily and retry
                          spoonek @Guest
                          I just started over from scratch and now was able to get the authorization webpage login to work.
                            A Former User
                            when it want to work ;)
                              requiemmg
                              I understand the CPU and traffic issue, but would there be any chance to check at least 2 accounts at the same time in a future version?
                                A Former User @Guest
                                • E
                                  etayl @Guest
                                  @Sean said in MMM-Spotify:
                                  MMM-Spotify
                                  Spotify controller for MagicMirror
                                  Screenshot
                                  default
                                  mini
                                  Main Features
                                  • Showing Current playback of any devices
                                  • Playing Controllable by Notification (Play, pause, next, previous, volume)
                                  • Spotify Controllable by Notification (change device, search and play)
                                  [card:eouia/MMM-Spotify]
                                  My MBP was gone a few weeks ago with 12,000 mp3s which I was collecting for my whole life… :(
                                  I’ve never used any streaming service, but now have to.
                                  So I consider to use Spotify. I know there is already some modules about it. Anyway, I need something different. I was playing with Spotify API for my private purpose.
                                  Just at that moment , @ejay-ibm wanted to control Spotify with voice command through MMM-AssistantMk2. He asked sometimes and I answered. I asked also sometimes he replied…
                                  And then, Wow, Suddenly This module is born.
                                  Special Thanks to @ejay-ibm. He gave me great inspiration and motivation to complete this (and real coworking also).
                                  TODO
                                  I’ll add touch interface to control Spotify. (somedays)
                                    A Former User
                                    @etayl : and ? what’s the problem ?
                                      JAMJAMT @Guest
                                      @Bugsounet I am using Spotify free account do not pay for the Premium,can I just download Spotify to MP3 by using any third-party tool and then add music on my mirror?
                                        A Former User
                                        Hello, I do not see the point of answering this question, MagicMirror and his team will NEVER respond to this
                                          sdetweil @JAMJAMT
                                          @JAMJAMT that is not legal.
                                          none of us could advise u to do such a thing.
                                            raf
                                            hi all
                                            I have installed spotify but can only play the sound on my smartphone and my google nest mini, how can I play the sound through the speakers of the raspberry pi
                                            spotify does appear in the MagicMirror
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
