    MMM-Spotify
    249 Posts 51 Posters 365.2k Views 54 Watching
      A Former User
      when it want to works ;)
        spoonek @Guest
        @Bugsounet said in MMM-Spotify:
        pi@raspberrypi:~/MagicMirror/modules/MMM-Spotify $ node first_auth.js
        [SPOTIFY:ERROR] Token not found! /home/pi/MagicMirror/modules/MMM-Spotify/token.json
        [SPOTIFY] Spotify v1.0.2 Initialized…
        [SPOTIFY_AUTH] Opening the browser for authentication on Spotify…
        events.js:174
        throw er; // Unhandled ‘error’ event
        Error: listen EADDRINUSE: address already in use :::8888
        at Server.setupListenHandle [as _listen2] (net.js:1280:14)
        at listenInCluster (net.js:1328:12)
        at Server.listen (net.js:1415:7)
        at Function.listen (/home/pi/MagicMirror/modules/MMM-Spotify/node_modules/express/lib/application.js:618:24)
        at Spotify.authFlow (/home/pi/MagicMirror/modules/MMM-Spotify/node_modules/@bugsounet/spotify/index.js:310:8)
        at Promise (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:20:14)
        at new Promise ()
        at authorize (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:17:12)
        at authorizations (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:33:19)
        at Object. (/home/pi/MagicMirror/modules/MMM-Spotify/first_auth.js:40:1)
        Emitted ‘error’ event at:
        at emitErrorNT (net.js:1307:8)
        at process._tickCallback (internal/process/next_tick.js:63:19)
        at Function.Module.runMain (internal/modules/cjs/loader.js:834:11)
        at startup (internal/bootstrap/node.js:283:19)
        at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
          A Former User
          @spoonek said in MMM-Spotify:
          it’s mean that the port 8888 il used by another app… free this port temporarily and retry
            spoonek @Guest
            I just started over from scratch and now was able to get the authorization webpage login to work.
              A Former User
              when it want to work ;)
                requiemmg
                I understand the CPU and traffic issue, but would there be any chance to check at least 2 accounts at the same time in a future version?
                  A Former User @Guest
                  yes, I can’t display ALL account in the same time.
                  example 2 accounts listen at the same time -> what is the visual (complex to determinate) !?
                  • E
                    etayl @Guest
                    @Sean said in MMM-Spotify:
                    MMM-Spotify
                    Spotify controller for MagicMirror
                    Screenshot
                    default
                    mini
                    Main Features
                    • Showing Current playback of any devices
                    • Playing Controllable by Notification (Play, pause, next, previous, volume)
                    • Spotify Controllable by Notification (change device, search and play)
                    [card:eouia/MMM-Spotify]
                    My MBP was gone a few weeks ago with 12,000 mp3s which I was collecting for my whole life… :(
                    I’ve never used any streaming service, but now have to.
                    So I consider to use Spotify. I know there is already some modules about it. Anyway, I need something different. I was playing with Spotify API for my private purpose.
                    Just at that moment , @ejay-ibm wanted to control Spotify with voice command through MMM-AssistantMk2. He asked sometimes and I answered. I asked also sometimes he replied…
                    And then, Wow, Suddenly This module is born.
                    Special Thanks to @ejay-ibm. He gave me great inspiration and motivation to complete this (and real coworking also).
                    TODO
                    I’ll add touch interface to control Spotify. (somedays)
                      A Former User
                      @etayl : and ? what’s the problem ?
                        JAMJAMT @Guest
                        @Bugsounet I am using Spotify free account do not pay for the Premium,can I just download Spotify to MP3 by using any third-party tool and then add music on my mirror?
                          A Former User
                          Hello, I do not see the point of answering this question, MagicMirror and his team will NEVER respond to this
                            sdetweil @JAMJAMT
                            @JAMJAMT that is not legal.
                            none of us could advise u to do such a thing.
                              raf
                              hi all
                              I have installed spotify but can only play the sound on my smartphone and my google nest mini, how can I play the sound through the speakers of the raspberry pi
                              spotify does appear in the MagicMirror
                                sdetweil @raf
                                @raf Spotify requires a supporting player.
                                librespot or raspotify
                                note these are both installed in the base system outside mm.
                                once u install and start them, you should see the pi device in your phone app Spotify player to transfer play to.
                                I have installed the Spotify Connect app.on windows and my desktop linux, and can play on my pi, and see what is playing on mm
                                R 1 Reply Last reply
                                  raf @sdetweil
                                  its only for premium users ?
                                    sdetweil @raf
                                    @raf I think so
                                    • L
                                      Lauren0612
                                      MMM-Spotify
                                      Where is this module? I cant find it on the magic mirror module list anymore :(
                                        sdetweil @Lauren0612
                                        @Lauren0612 bugsounet has removed his modules.
                                          A Former User
                                          open again (temporarily)
                                          L 1 Reply Last reply
                                          • L
                                            Lauren0612 @Guest
                                            @Bugsounet noooo please come back 😥😥
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 10 / 13
